Sony DFS-500 advice
I recently acquired a Sony DFS-500 video switcher/digital effects unit and have been having issues getting video signal into the inputs.
I am using BNC-to-RCA adapters and plugging in the component output for a Handycam, but PGM output plugged into TV is just showing a grey (not black) screen with a few glitchy crackles when wiggling the composite cable.
I have messed with Edirol V-4 and Panasonic WJ and MX mixers a bit and never had an issue plugging in the same video camera, so I’m trying to figure out if device is faulty or if I’m doing something wrong or if it’s a Genlock issue, etc.
It looks like the effects/wipes, color bars, background hues are working fine, but no luck on any of the four video inputs.
Also curious if anyone has modded one of these or discovered anything cool/glitchy with feedback loops on a stock one
i think that unit is supposed to have a frame synchronizer, so i don’t think you are supposed to need to genlock/sync the input device to it. that said, these big old rack switcher things can be very confusing and mysterious tbh. it sounds like an interesting thing to play with though. have you tried plugging any other video sources in to test or just the handycam?
i had a sony dfs 700 and all analog inputs on that one needed to be genlocked. If it was only one analog signal i was dealing with then i could just use a little DA to send a copy of the same signal in as video ref to genlock. for multiple analog signals i needed to start chaining mixers together with genlock, using an mx-70.
sony dfs systems seem really optimized for SDI in my experiences, the SDI feedback on mine was super fun. just loop the sdi, play around with the color correction menu, and start cycling through all the wipes and should have some fun times!
From what I’ve read so far, the stock DFS-500 does NOT natively use SDI, but there is an SDI board that can be installed as an add-on. I don’t yet know if anyone upgraded my unit with the SDI card, but so far haven’t seen any evidence that anyone installed an additional board for SDI or Drop Shadow/Trail effects.
I am gonna delve deeper into this unit this weekend and see if there’s any luck with getting a signal from a different video camera and/or video source
