I want to split a composite signal so I can send clean video to multiple glitch hardware boxes (and then switch between them), but when I use a Y splitter wire the distortion will affect the other signals in the chain. Are powered splitters the way to go or will I have the same problem? I just want to know before i spend money on it. Thanks a lot.
Side note, I did buy a powered splitter on amazon and its for a car but the manual says it needs an input composite signal of 2 volts pp, so it won’t detect a normal composite signal and turn on. What kind of signal is it looking for? luckily it was cheap and I’m not out much money.
You need a composite DA (distribution amplifier). It will ensure that each output signal is strong enough without loading down the input or causing crosstalk.
Check eBay for a ‘composite video distribution amplifier’.
