Hi Scanlines.xyz
Can distorted video signals be recorded with the AJA IO-HD machine using the “Reference I/O” connectors? I didn’t succeed. Maybe I have to use the REF I/O connectors?
From the manual it is not clear how I should connect the video signal and if AJA io-hd has an internal tbc or should I connect a TBC machine in the REFERENCE I/O connectors first.
Since December 2022 I’ve been trying to digitally record video clips with line signals by making cut-ups with a passive switch and with effects for signal distortion visible only on TV.
I tried digitizing the video going from AVE5 with a video result of 50% compared to the performance, then with Sony xv-c900 which perhaps has no TBC result 0% black screen in recording.
Does AJA IO-HD have internal TBC? How would you cable the reference i/o signals?
