Hello everyone! Once again back for some advice converting my av signals to HDMI. Recently my converter for some reason has been sending out a negative signal or no signal at all, never had this problem so I figured I’d ask. For reference I’m capturing the av converter with my el gato HD60s. The capture card still has been working fine but the converter for some reason gave out. I am using one of these……… I’m open to taking recommendations for converters or even a new capture card so I can capture the footage via capture card. Thank you to everyone in this community I appreciate you all
TBH I’ve just used one of those that you’ve linked to with the output going into a cheap USB HDMI capture with acceptable results. I’m sure that there is better out there but for ~$15 (probably $20 now) it’s kind of hard to beat.
Maybe try a RetroScaler2x? It’s marketed to the retro video game market but might be a good fit.
Or this unit from KanexPro:
