Edirol V4 Repair
Does anyone know what kind of potentiometer I need to use to replace the black / white Output Fade control on an Edirol V4?
The service manual gives the following info:
Partcode: 02784689
Part name: 9m/m rotary pot
Descritption: EVUF3KFK4B14
This is the only item that I could find online which comes up for the partcode.
It just seems crazy expensive when it could just be a generic part.
According to the schematic, that is a 10k pot with a center detent. The detent is the little ‘click’ you feel when the pot it turned exactly to 12 o’clock. It makes it easier to rest the pot in the exact center of its sweep.
9mm rotary pots are pretty standard stuff, but with a center detent is a bit more rare. You could probably swap in any 9mm 10k ‘snap-in’ pot, like an Alpha or Bourns, that doesn’t have the center detent but finding the exact middle of the sweep range could be tricky.
Untitled
I just had the exact same problem, it won’t stay centered and intermittently fades. Hoping to solve this as well! In the meantime, you can turn this knob off in the utilities menu if you move to memory 2-8.
you can get center-dented bourns from mouser for quite cheap - something like this will prob do - PTV09A-4220F-B103 - can measure shaft length of another pot on v4 and try to match
