Edirol V8 issues - subtle flicker/strobe always
Hi new to the group :slight_smile:
I just got an edirol V8 from Europe (but I’m in US) and everything works perfectly except there’s a subtle flicker that happens at the same frequency with the menu letters and happens more intense on the two channels when effects are selected and especially when in a feedback loop. It’s always the same speed/frequency. It’s also really hard to capture on my camera, whenever I film my crt screen at 60 fps (like you should) it appears to be fine from the camera.
Things I’ve tried:
  • 4 crt’s present the flicker at the same amount, so not the monitors
  • have tried 3 power adapters and doesn’t change
  • have unplugged everything in my house to kill any ground loop and doesn’t change
  • tried different cables/adapters power outlets, unplugging everything from mixer
  • I’ve tried every setting in the v8 including sync threshold and other things in menu settings like PAL/NTSC
The thing is, all video signals like VCR’s/cameras/VGA all come in with a stable image but as soon as you put on an effect or do a feedback loop, something on the screen is flickering from varying intensities. I’ve used Panasonic video mixers and know that you can occasional get strobing when using effects/feedback loops, but never encountered a mixer that strobes so quickly and always stays at a similar rate. It’s like there a slight doubled overlay slightly out of sync whenever the mixer gets pushed in any way.
Im happy with the results when I capture it from my phone but just have a hard time looking at the screen, really hurting my brain haha. Let me know if y’all have any suggestions or ideas, or if the feedback on the V8 is just usually a bit stroby in general.
Thanks!
Can you capture the problem in a video?
i have a v4 and a v4ex, not a v8 but very similar - and haven’t experienced anything like that, it doesn’t sound like normal behavior. have you tried plugging it into any LCD monitors or digital capture devices ?
is the power supply for this mixer legit?
What i learned from phase interference visible on web cams: The power frequency in Europe is 50 Hz. But 60 Hz in US.
Thanks for the input so far - for some reason the effect (subtle ghost jitter) only appears on my CRT’s, and can’t capture it well on my phone. I used my crappy usb capture device and doesn’t show up on that either, I think because the quality is so compressed or maybe it’s missing frames? A little jitter comes through on phone/capture but like 10 % of what’s on the CRT. I promise I’m not losing my mind haha - I don’t have an LCD screen yet, I should bring it over to my friend’s house and check that out m.
Also, I was able to try a time base corrector and that didn’t help at all either…
I’m a new user so can’t upload videos of the issue directly on here yet, but I’ll try and put up a YouTube link soon :slight_smile:
thank you for pointing this out…
:mage::boom::woman_mage:
…you should now be able to upload videos
anyone else with the same problem please let us know!
(this limitation was likely to be a Discourse default one, we had lifted it in the past but apparently it’s got back to the default settings. let’s move the discussion about this to Discourse "Trust Levels" / limitations and permissions for new/active/old users - #5 by cyberboy666)
Alright, here are some examples of the strobe issue with my V8. I just realized this strobe is apparent no matter what the input source is, so even my clean vcr signals are always jiggling at this same rate. The strobe is much more apparent when effects are engaged tho, and is more intense than the videos I was able to capture, but still show what is happening.
Also, the power supply I have is the correct Roland one.
yeah, that looks like it would be quite painful to stare at for a long time
any ideas how to make it stop, you think it’s an internal issue with the V8? those things are tanks and not even that old
no idea unfortunately. i have a v4 that i have to turn on and off a bunch to “warm it up” before it outputs a non-glitched signal. and a v4ex that sometimes drops to a much lower frame rate at random times when i’m using the s-video output. so while i love the edirol mixers i don’t exactly think of them as tanks.
are you in the US using only NTSC gear?
it does seem like a board issue to me, which i can’t really advise on as these mixers are highly digital and rather beyond me in terms of repair. if it happened to me i’d probably spend a lot of time deep diving in the menu to rule out any causes in the settings. it also looks like it could maybe somehow be related to interlacing although i can’t tell for sure.
I thought I’m the only one with this multiple startups and convincing the v4 to wake up and work properly issue. I have to say it gets kinda annoying sometimes. Especially when you arrive at the venue, connect everything to the projector and then everyone’s looking at you and you’re like “it’s gonna work, just give it some time, ok?”.
i knoooow right :sweat_smile:
offtopic just to point out the videos in this topics will not play on my Linux Ubuntu computer (either on Chromium or Firefox), but they play on Windows. I wonder if this is a local problem in my system or it affects other users here
Im having similar issues. Anytime I include the v8 in my feedback signal path i get this rapid jittering that I dispise. Im going to go through all the menu option tonight and see if changing things around lessens it. Let me know if you’ve figured anything out!
Really hoping thats not just an inherent characteristic of the V-8’s feedback, Something about it feels very stiff and digitala and really clashes with the flavour of feedback the rest of my rig generates. Sucks cause i have been saving up for one for a while but so far i have a lot more fun with my MX-1.
Here is another example of this issue
Original Feedback Loop
Feedback Loop with V-8 in signal path (No effects added)
edit: There is a function on the under the v-8 utility menu labeled “Sync Threshold” but sadly adjusting this setting in either direction does nothing until a certain threshold where the signal just falls out completely. No luck with any of the other utility settings either. Starting to think the v-8 just has a shitty built in TBC that cant handle video glitch/feedback signals well. Often times the signal will fall out completely on the v-8 with stuff my MX-1 does absolutely fine with.
edit2: Just tried adding a tbc into the signal path directly before the V-8 to see if that would help, that just made it worse.
Is the power supply EU or US with an adapter? PSU’s for the US should be a PSB120/PSB1U
Sorry if you’ve answered this already.
kind of late to this convo but (assuming it doesn’t happen in a non-feedback signal) i’m pretty sure that strobing is due to the image in the two different fields of the interlaced scan pattern kind of diverging from each other. this is something that can happen with feedback, i’ve even had it happen with camera feedback too. i have addressed this in recordings by converting to 29.97fps progressive and dropping one field (line doubling). i dont have a great solution for live tho.
Any other possible fixes for this? hoping to revive this thread! if i didnt have this issue with my v-8, it would open up so many creative opportunities in my feedback setup. Hoping to figure this out some day. Hoping this is infact an issue and not that the V-8 just isnt suited to my preffered aesthetic of video feedback.
