Hi!
Step-Up Convertor works! Edit: (No, it doesn’t)
Built a power board for the battery contacts, a switch and the step-up convertor.
PCB stack design is done!
Parts ordered, PCBs ordered, fingers crossed!
Hi!
Rooting for you, @January !! This looks so awesome!
Heyyyyy!! Battery power works on the Stack, doesn’t work on the Gameboy build. Screen turns on for both, but I’m getting the white screen of death! I’m also getting the white screen on my original Recurboy so not sure what’s happening. I think my SD card got corrupted when I dropped my Raspberry Pi last week.
Some of my measurements were off on both builds, so I’ll have to do another revision for the PCBs. I’ll do that once I get the Recurboy software working. Fairly close to the end though!!
Pics of the GameBoy Build:
Pics of the Stack Build:
HI!
Been working on this project. The problem is the raspberry Pi not receiving enough power,
I tried a step up convertor also called a boost convertor.
Realized that was a mistake as I would be getting 6v from the 4 x AA battery I would need to step down to 5v. I would need a step down or buck convertor. But what about when the batteries drain below 5v? More research led me to a step up/step down or buck/boost convertor. I ordered a bunch of each. Unfortunately, none of them work.
Have one more part on order: Pololu - 5V Step-Up/Step-Down Voltage Regulator S9V11F5
It’s a little pricey but it it works it will be worth the cost. Fingers crossed.
There is another route to take tho. Luckily, I came across this video:
He builds a raspberry pi zero powered by 4 x AA batteries inside a first gen gameboy! With a screen!! AND IT WORKS!!
He uses a Over-discharge Protection Circuit and is very nice to have uploaded a picture of the schematic!
I added the Over-discharge Protection Circuit to the power board for this project:
One last thing. This is an educational project for me, I’m not affiliated with underscores_. I’m just a big fan of cyberboy and the recurboy project. Lately I’ve been thinking a lot about the importance of fan art and really that’s what this is. I’m building my dream recurboy, but I was also planning to give away the schematics and gerbers online for free if other people would like to build their own. I think it’s great thing that cyberboy gives away the recurboy software for free and just want to help add to this community,
Anyway, PCB and parts on order. I really hope this new design works.
Cheers!
The S9V11F5 Voltage Regulator works!!
So happy! Bless this man and the video he made!! Especially around the 31 minute mark
I tested it on a fresh pair of batteries it ran for 4 hours easy maybe 5 on idle with no button input and no video output. It ran so long I fell asleep around the 4 hour mark I woke up when the timer was approaching 6 hours and it did not have enough power to run. I was hoping for at least an hour, four hours is plenty! I will do a full test with button input and video output soon. Right now, I’m just so happy it works!!
I am still going to try the Over-discharge Protection Circuit, if it works I’ll choose the better, more power efficient solution. But if it doesn’t work, at least the S9V11F5 Voltage Regulator works!
Final build coming soon! So happy I can finish this project and move on to my next one!
@homegrown I’ll send you a completed build once it’s done if you want one. Also going to send one to cyberboy. I will upload the gerbers, bill of materials and a step by step guide showing how to build it, for others if they want to make their own.
Congrats on driving this to completion! I admire your ability to R&D this it’s impressive. And that’s very generous of you, I’d be happy to pay for the shipping costs and what not.
Lfggggggg so amazing! I will totally make this.
Hi!
I’m back. Kept getting the White Screen of Death and could not figure out why. I thought it was a problem with my design, so I went back to check everything in the circuit. Double checked all traces. Reprint PCBs, re-test, still no luck, WSOD.
A little disheartened… worked on other projects, enjoyed the summer. Still no clue on how to fix it. Got some good advice to test every single step. Testing everything. It was a faulty SD card.
It works. It always did. Next post will probably be a complete build.
This is amazing! I’d love to build one. Please let me know if you’re willing to sell any PCBs. Thank you for your amazing work!
Hi!! @EchoEs-Bats
I’ll be uploading the gerbers, BOM and a build guide and how to video all free to download, so it will be easy to build your own.
However, I might have a few extra PCBs and I can send you one to build. Give me a couple of weeks, I still need to finish testing everything.
It works!!!
Stack Build:
Classic Build:
Video Test:
Missing some diodes, can’t test the CV inputs until I get them, but everything seems to work. Very tiny changes need to be made, still good enough to use for now. Going to test everything. Will put together a GitHub so others can download the files.
Have to give some kudos to @cyberboy666
Really love the format of the recurBOY!! The controls are extremely easy and very fun to use! For years I had been using the r_e_c_u_r, which can have a lot of menu diving and at times too many controls. recurBOY takes the best parts of r_e_c_u_r and makes them fun to use and easy to access. Excited to make a bunch of these and pass them out. It is a great tool for beginners and seasoned visual artists. A perfect edition to your gear, especially useful for a mobile setup. Can’t wait for other people to use this, it’s SO MUCH FUN!!!
Next post will probably be a link to downlond the files, but it will take me about two or threes weeks to put everything together.
Just stumbled onto this post. Congrats on getting the build done! Looking forward to checking out the github
Hello!!!
Getting ready to upload everything, wanted to make few adjustment before I do, (bigger buttons, add red LED light, etc).
Working on a PDF Build Tutorial. Wanted a couple of people to make the build while using the tutorial and give me any feedback you may have before I upload.
Let me know if you’re interested by leaving a message in a reply. I will mail you the PCB and a kit with all the components.
If you’re interested, in your reply please let me know which version you would like:
The “Stack Build” is a stack of three PCBs, you solder all the components on the middle PCB and it’s an EASY build.
The “Classic Build” is two PCBs which fit inside of an Original GameBoy case, but it is a far more DIFFICULT build as it requires intermediate soldering skills and some modifications to the case.
So if you would like your own working Hand-Held RecurBoy, leave me a message in the reply and then I will contact you later with a Direct Message to get your information on where to send it.
Cheers!
Hey I’m down for trying either build. I’m in Canada if that matters.
@retrocactus Sure thing! I will send you one, Canda shipping is no problem.
@EchoEs-Bats You asked about buying PCBs, I can send you the PCBs for free if you are still interested.
@saddleuptherobots If you still would like to make this build I can send you one too! Just leave a message to let me know and I’ll contact you through DM.
@homegrown Thanks for sparking the start of this build! I promised you one once it was done. Would you like a kit to build yourself? Or would you like me to send you the completed build I am making for the tutorial.
@cyberboy666 Would love if you were an early tester, but I know you are working on some big projects right now. I can send you a completed build if you would like? Or I can send you a kit. Just let me know.
For anyone else interested, I will be ordering extra PCBs. If you would like to build one, leave a message in a reply and I will send you a direct message to sort out your shipping details.
im happy to build a kit if you send me one :)) great work thanks for contributing !
I’ll definitely send one out to you @cyberboy666
In the middle of a project right now that’s due at the end of the month.
Once I’m done with that I will get back to working on this.
I don’t have access to a pi0 at the moment unfortunately, but well done! Can’t wait to try one
I sent you a PM! Please check it ![]()
Hey all! Almost done with the other project I’m working on, it’s due next week.
Seems there was a little confusion with my request. Just so we’re clear I’m ordering the parts, putting them into kits and gifting to the five people I selected in the earlier post. I’ll also be paying for the shipping. So no need to Venmo me. I’ll reach out to everyone for shipping details once the kits are ready.
Only thing I’m looking for is feedback on your experience making the build.
@homegrown I’ll include the pi0 so no need to worry.
@EchoEs-Bats I responded to your text, no need to pay me.
