Gravity Waaaves DIY instructions (and bug/thread)
I think so. I looked at the product # in the listing because I couldn’t see the amount of RAM installed in the description but it looks like it is the 4GB model.
I ordered one. Let’s see how it goes…
I get the PSU tomorrow. I’ll follow up in this tread. Thanks again!
the two camera connectors are also a good sign, points to it being the right model
Thank you very much! My AJ GW is working great and I just rackmouted it. Now I may end up with 2. I have some ideas about controlling through Ableton. Keep being awesome
Well, win some, loose some. I got the Jetson Nano and tried to boot it, first with a GW1.5 flash. It was spitting out errors. Then with the original SD card that came with my GW and it never made it past the NVIDIA splash. So I took a hard look in the mirror and asked myself ‘Do you really NEED 3 GWs?’ Maybe I’ll find another use for the board. Thanks again!
Hey Everyone,
My GW is freaking out again. It was working for a while, but then it would just start shutting off. On the boot screen, it was throwing throwing a bunch of errors that I didn’t have a chance to photograph and then would hang. Then I got it to boot with no USB peripherals plugged in. While it was in that state, the power button was flickering, and eventually shut off. Now it won’t power up and the fan which normally runs when GW is off isn’t spinning. Maybe I need a PSU that can handle more current? HELP! Thank you.
That sounds like a PSU problem. Make sure you’re running off of the barrel plug because the jetson nano can’t supply enough current through the microUSB to run at the 15W mode.
Hi, everyone. I can’t for the life of me get the DisplayPort to work. Any tips?
