When I am setting my display from my laptop to my tv I have the option to set it as 4:3 in the display manager. The issue im running into is when i do it looks as if you put 4:3 on a 16:9 display. But if I do choose to put the imput as a 16:9 resolution it stretches the picture. Does anyone know a work around
from this?
What are you using to convert to a composite signal?
Thank you for your responce
This is the link to what i am using i got it on amazon
HDMI to RCA, 1080p HDMI to AV 3RCA CVBs Composite Video Audio Converter Adapter Supports PAL/ NTSC for TV Stick, Roku, Chromecast, Apple TV, PC, Laptop, Xbox, HDTV, DVD-Black https://a.co/d/2VFef9Q
…there might be a possibility to select different resolutions on the monitor…
…there is for sure some way to call up an ‚onscreen menu‘ where the relevant options are available…
Try setting your windows display resolution to 640×480. That’s what works best for me
Thank you ill try that out
swap out your monitor with a crt
