has anyone found a way to achieve a vertical and horizontal line mesh combo? like if you combined the two to form a grid?
its already in the code and available in spectral mesh, there just weren’t enuf buttons to keep it on the controller when i added the audio reactive biz. you can just go into the code and swap out a different button for that one if you want it back
thank you for the reply. ill switch up to spectral mesh to see if its worth it.
