I recently acquired an Innisfree Picasso “spatio-temporal vector harmonics” synth. I’m replacing all electrolytics, as most of them show visual signs of failure. When that is finished I’ll be looking to have some fun with it.
Anyone have a manual (pdf or print)?
I have scopes, but can anyone recommend a good monitor? Maybe the Vectrex?
Hi! I am on a quest to discover the picasso and actually document / record what it does as info is so scarce on the thing. It’s been a long time in the works but I am picking up steam recently.
Here is the manual, it is very technical but quite useful. You need an XYZ CRT monitor to display the image (the vectrex may work), and it has several monitors listed that can be helpful. Personally have tried several monitors and have the best luck with the tektronix 620.
I just finished recapping the entire unit, applied power, and messed around a little, just using a xy scope that I have. I started taking notes on what functions I figured out. I will share that once I’ve sorted all I can.
I don’t have an xyz monitor, but just ordered a tek 602, as I couldn’t find a 620 at a price I could stand. The 602 will need some maintenance before I can use it, but I’ll report back when I’ve got it running.
