Heyo! When I try and extract the images for Spectral Mesh or Temporal Vortex I get the error “Checksum error in P:\TV_4_NTSC.img. The file is corrupt” I was just wondering if anyone else was having this problem or if it’s something on my end. Wave pool extracted fine and I’ve re-downloaded the SM and TV images but the error persists.
what client are you using to unzip the files? perhaps you could try a different one.
So far I’ve tried the windows 10 default one and Winrar. I was able to download the older version of TV which is fine with me for now
try redownloading and just pointing balena at the .zips
That worked! Thank you!
I’ve also had some difficulty with the Spectral Mesh image. Balena either wasn’t working or the RPi couldn’t boot with a kernel panic. When I did a sudo dd if=SM_4_NTSC.img of=/dev/disk2 bs=1m it finally worked. Kind of strange.
