Hi guys, im desperate for some help on some papers for a chip. Its about this Chip: CA31883E
I can only find 2 differents types of Datasheets, and there is no pin-description. Is there a way to read out data, to see where are Ground and Volt Pins?
Pin 4 is ground. Usually with the notch on your left (so pin 1 is bottom left) the ground is bottom right pin (pin 4 on an 8-pin chip) and + is top left pin (pin 8 on an 8-pin chip). Also, as soon as I saw the image, I knew what chip it was!
Schematics are funny things and the visual language and style of electronic schematics changes as time goes on. Old styles fall out of fashion and new styles bubble up. Some symbols have been determined to be outdated and some new symbols need to be invented to represent new concepts. That being said, all of these are Ground
Awesome, you guys really helping! Thanks again bsom and revjon! If you totally new its really tough. This Symbols great, i was pretty unsure, because i knew that “chasis ground” symbol is ground, i called it devils-scepter. But now i know there are some different symbols for ground. Amazing, through that chip-encrypment, i got finally a stable videosynth! THANKS!
Otherwise, i know now that VEE or VCC definetly not ground. I cant help myself, im really reading this whole datasheet, there is no description for those g2b, g1b, g2a, g1a points, what are ground on this ?`
Have VEE and VCC on 5 & 10
The Ti version of the chip has a much more legible datasheet and basically you can choose three levels of gain by connecting different combinations of pins or none connected at all. The notes in the Ti data sheet are easier to read and explain it
Also Vee can be ground, or negative current. More info on Vss Vdd Vcc and Vee here
