Recur_boy midi control - play/fwd/rwd
Hey all. Can anyone point me to info on using midi as a control source for the Recur_Boy?
Ultimately I’m looking for a way to control the play/stop but also hoping there’s a way to either choose specific video files (ie by number order in the file list) or just have the ability to use midi to forward and back the files being played to the next / previous video file.
Thanks
Here is the midi map
It mainly just exposes the existing controls - u can modify effect params and shader params at same time tho rather than needing to switch focus…
also you can modify the code/ map to add other things u might like :wink:
If you want to play the next video send a movedown message followed by a enter message
Thank you.
