I am about to have everything I need for a recurboy and I was curious;
In prepping the RPI zero (I have a w) do I need to go through the process of installing the Raspbian OS prior to anything else?
I’m a bit of a noob with this shit and I really don’t want to muck it up.
Any insight is appreciated
As far as I know the only prep for pi zero W is to solder the 2x1 pin header for tv out.
The sd card is flashed with the recurboy image.
docs here https://github.com/cyberboy666/recurBOY
Thanks for the feedback. I thought that might be the case.
I have a recur presently but I know the old pjs typically had the OS already installed.
Moot post as the package came with a SIM card ready to rock!
I am running into a ‘white display screen’ issue currently testing what the issue may be.
