I woke up this morning and thought I’d do a little patching exercise to try and make a 5-point star shape like those old-school star wipe transitions on my modular video synth. Turns out it’s much harder than I initially thought – I mainly used 3 modules from Syntonie – Rampes (ramp generator), Solaire (rectifier and mixer), and Seuils (hard keyer). The closest I was able to get was a star shape that looked more like that image of Patrick Star in fishnets and boots. Not quite the star I was going for.
But this has gotten me curious – when did the Star Wipe first appear on mixers? What changed technologically that allowed for that shape to be made? Was it a digital advancement and and not an analog one? Or is there a circuit that exists that can do radial mirroring? If that exists, how exactly does it work? And if radial mirroring exists in analog form, what combo of ramps make up that star shape?
I figured there would be someone on this forum that may have some history knowledge on how the Star Wipe came to be. Let me know what you know!
i don’t have a neat answer to your question, about either the analog generation, or the history part. i can make some educated guesses and stoned hypotheses, in case it’s of interest. this is such an oddly specific and impractical question, i’ve been thinking about it on and off since i read it earlier today.
i’m gonna go out on a limb and say that i think most video mixers/switchers that have star and heart wipes are generating them digitally. i can’t say for sure that is globally true, i know that some simple wipes such as linear H and V wipes were generated via analog methods at some point, but when digital mixers (with internal digital logic, obviously the output is still analog video) came out, people kind of went crazy with the novelty wipe patterns.
if you generated five different ramps at different angles, there’s probably some kind of complicated mixing logic that could get you a five pointed star. you would need to set them to be rotated at intervals of 2pi/5 and take each possible combination of 4 and run them through some kind of logic to find the max. then do some more stuff so your output becomes any area where at least 1 of the previous outputs are active.
apparently you can generate ramps at any angle of rotation by adding H and V ramps together in different amounts. that said i think the aspect ratio will become weird unless you scale them differently, since the output image is 4:3. so starting from an H and V ramp, you would need four different mixes of both to create the differently angled ramps, plus also the direct output from the vertical ramp. again none of this is practical but interesting to think about.
…yesterday i re-watched two Syntonie-Videos, and i think to remember that in one of them they make a star-shape with very little effort and only two(?) modules; it was somewhere in the middle of these videos:
…it might have been a four-pointed star they made though, i just remember…
@palomakop “oddly specific and impractical questions” is all I got up in this here noggin’ of mine lol!
I kinda see what you’re saying about the mixing logic option, feels like something to try in a visual programming environment like TouchDesigner or Max. You’re right about the H+V ramp combos and it’s totally possible to get a star with an even amount of points (like @fairplay mentioned with the Syntonie videos), but trying to get an odd amount of points is what’s so bizarre. There is one video module from LZX (Navigator) that I know of that does X/Y shifting and has a rotation knob, but it’s been discontinued for a few years now. Unless you have that one (to my knowledge), the ramps only want to rotate at 90deg intervals.
I did continue to do some research to see if I could find any info on when the Star Pattern first showed up on video mixers. I wanted to see if I could confirm whether it was created via analog or digital means. The Grass Valley Group 1600 series switchers came up and I was able to find an catalog from 1975 as well as an instruction manual on The Internet Archive. And lo and behold, these switcher used analog pattern generators! In fact, they have “3 pattern generators that provide both rotary and conventional wipe transitions”! Now, why does it has 3 pattern generators and not just 2? I’m not totally sure, but I wonder if it has something to do with how this rotary circuit works? Or it could be a boolean logic thing where they utilize something like an (A+B)-C to get more complicated patterns?
At any rate, it does seem like there’s something to 3 ramps being used. Here’s a picture of the “Patrick Star in boots” star I was talking about earlier as an example –
I used a rectified cross mixed with a diamond, mixed with an inverted (I think) vertical ramp. This is what it looks like from the first channel logic output on Sueils –
The thing it’s not symmetrical like the star pattern I’m thinking of, which is where I starting thinking maybe it has to do with rotation and not folding –
All wildly impractical things to think about, but still interesting. I wonder if someone has an LZX Navigator and can try to make this to see if it’ll work.
star wipe, heart wipe, anything more complex than a rectangle/triangle wipe is necessarily using lookups from frame stored in ROM as a key matte. afaik you only find them on mixers with built in framebuffers. i don’t see star patterns in grass valley 1600 series, just mixtures of rectangle & triangles which would be what you’d expect from using ramps & pulse waves for key generators. (tho i did find some amusing ai trash slop sites claiming to provide info on them when i did a quick refresh on the topic…)
grass valley 1600 have 3 pattern generators b/c they have 3 mixing stages (not including DSK)
the problem of doing any symmetrical transform beyond flip/mirror horizontal and flip/mirror vertical at like video rates without a framebuffer look up is you need to have some look up tables for sine/cosine values + a math coprocessor built to to all the transcendental function math. (transcendental fucntions ~= all trig, e^x, ln(x)). this is non trival stuff. much simpler to store a frame and look up from there.
the old school pre-framebuffer method for complex wipe patterns would be optical: cut out a star shape from black tagboard, put it on top of white tagboard, zoom the camera in, use that as key matte for logic.
if you want to use analog computers to do this kind of stuff look at like scanimate documentation, that was more or less the state of the art for doing real time nonlinear geometrical calculations. and even they would start from putting black tagboard on a white background, because then at least then you could do it precisely and repeatably.
