Triple voltage controlled comparator module for the Gijs Gieskes 3TrinsRGB-1c Videosynthesizer.
Description:
Each Comparator channel (total of three) has 2×1 signal input, 1 CV input, 1 bias potmeter and 2×2 outputs (positive and negative result)
The module is powered by the 3TrinsRGB patchbay. (HIGH and GND)
It is designed to accept Eurorack CV voltages. (+10 volt envelopes and -5v +5v LFO signals)
Negative voltages will be clipped and the input voltage is scaled to 0 to 2.5v.
This new version (v6) has a 8HP black panel and a large pin patchbay for easy patching.
The CV inputs are normalled to the next channels, so you can control all three channels with one CV input patched, or each channel separately with all channels patched.
Features:
3x Bias potmeter
3x CV jack normalised downwards
patchbay with 2×3 inputs, 2×6 outputs, 3x HIGH, 3x GND
Specifications:
Power usage: powered by the 3TrinsRGB1-c
Reverse polarity protection
8HP Black panel, black / light grey knobs
Depth: 25mm
Signals: Video and CV
Credits:
Gijs Gieskes for the original schematic
LZX for the help with the CV input
(note: the final version has black / grey knobs)
https://www.reverselandfill.org/triple-comparator-v6/
prices:
pcb set: 35,-
Full kit: 70,-
Module: 105,-
Shipping is 15,- euro tracked worldwide
(combined shipping is possibe, PM me)
reply in this topic if you want one, the parts are in stock
