I recently scored a V4-EX for a pretty good price. The only issue is that the touch display isn’t fully functional. It displays everything just fine, but the touch functionality isn’t working properly. It only recognizes the first touch after booting, and then it stops responding entirely.
While the touch panel isn’t critical for my use, it’s definitely handy for things like BPM settings.
Does anyone know if replacement touch displays are available somewhere? I tried Googling and mostly found some generic chinese panels on eBay, but I’m not sure if they’re compatible or reliable. Has anyone had experience fixing this or sourcing a replacement?
Open the case and reseat the cable to the touch panel. If there are more connectors between the touchpanel’s connected PCB and the mainboard, reseat these too.
…second for trying a factory-reset first: i bought a second hand V4-EX a few weeks ago too and it showed some peculiar behaviour - after a factory reset everything is now working as expected…
Hmmm, no luck with that. I’ve opened it up, checked all the buses and connections, nothing seems to be off. Still, the touchscreen works just for one touch, then doesn’t respond.
I’ve written to their support, and they were very helpful, guiding me to perform touchscreen test in test mode. Unfortunately, the test revealed a faulty touchscreen. So I’ve written to an official Roland spare supplier in my country. We’ll see how it goes.
Roland are generally great at support. Hope you get it sorted, at least you know what it is now. I’m sure spares are available and you could even install yourself.
