Howdy folks,
I recently picked up an old Titlemaker 2000, and it works great. However, when plugging in a source to the input to composite titles over the source, SOMETIMES (I can’t reliably reproduce it) the titles/backgrounds generated by the Titlemaker will cycle colors while the source is unaffected. Unplugging the source bring the output back to normal. Sometimes the colors cycle very fast, sometimes slow.
I’ve only tried connecting a Raspberry Pi 4 using native composite-out, as well as running the Pi through a VCR. I haven’t been able to reproduce the issue when I use the VCR only with no Pi in the chain, however if I use a bad VHS tape, the titles generated will “follow” the distortion of the tape.
From poking around here and other places online, I am guessing there is some kind of chroma signal timing that the Titlemaker doesn’t like/messes with, but I am sadly not too knowledgeable about video. I don’t believe the Pi’s analog output can be tweaked too much beyond NTSC/PAL settings and a few aspect ratios, but I’m willing to try anything!
