Hey guys I went ahead and threw together a repo with some of the changes made to the original waaave pool project to get it running on pi 5. It’s not perfect but in my testing it is pretty great for what I needed it for!
I wanted to do this to see if it was possible and as something that I could integrate into my own toolbox for live shows, although I aspire to be great at c++ heady graphics programming I am nowhere near the level it requires to think about the maths and stuff to get this stuff to work super optimized so don’t expect something super crazy!
Hi there, I flashed the SD card with the imager. When I try to check it on the pi 5 it opens a window asking for cyberwave login: I have no idea what to do there. If I manage to pass the login there’s a code line. What am I supposed to do? Thanks in advance.
The first picture is the first screen after plugging the RBP. The second pic is what happens after I type the login: pi and password: Cyberwave. I have connected the suggested Korg midi controller, the HDMI to a USB capture card, mouse and keyboard.
Thanks for sending photos. That’s really strange though are you sure you have the correct image? The user I set up is miapi and there should be a splash screen that’s different.
I tried reflashing the .img.xz file using the raspberry pi imagerv2.0.11.1. It shows an error: Error extracting archive: Lzma library error Corrupted input data.
Very strange indeed it worked great when I flashed it on a new sd card earlier. Just to confirm you are using the right image, what is the file name of the image you are trying to flash? Genuinely have no idea what “cyberwave” is, I hadn’t set that up as a user on the OS.
I boot the image. It turns on and goes through the boot sequence, starting from the Bunnybuntu screen. Then it goes to a black screen — it shows two lines and a black screen. Is the USB webcam necessary to use it? I am only using the MIDI controller.
Glad you were able to get it to launch! A webcam is necessary yeah or a capture card since it will need a video input to actually manipulate. The midi control layout is set to the original wave pool nanokontrol 2 scene, you gotta flash it from the scene file found on Andrei’s website. If you want to get it to work with any midi controller or have it playback videos for you, you would have to mess with the software on the image but it is absolutely possible
