Whats everyone working on these days?
Techno improvisation on Analog4 and Analog Rytm - moving from melodic techno into deeper territories (written for - and performed on private party on 23.08.2025 @ Funcke).
First half of the set are synthesis only - second half is performed on the Rytm only with a mix of melodic samples and synthesized drums. Live recorded in a single take.
Main outs of A4 and Rytm go straight into 1010 BlueBox, used as recording device only. All FX are used from the Elektrons only.
Video snippets sampled via Korg Kaptivator, glitched with a circuit bent JVC JX-C7 by Modified Machinery rescanned with a Black Magic Pocket 4K from Sony PVMs.
I’ve worked on a lot of electronics lately - some things -
Replacing the back colour selector switch on an MX15 with an electronic switching circuit.
Clocked by an LFO this uses a 4051 analoge switch and 4017 binary counter, and 4553 (I think!) it’s a priority encoder - to flip through the back colour setting on the mixer.
This will look great in a feedback loop. Whats nice about the MX15 is that the switch is a resistive ladder setup, it’s not MCU based (well partially)
I’m working on an XORSHIFT circuit now which is a PRNG (pseudo random number generator)
using CMOS chips, to randomise thi colour selection.
I have been micro soldering and hardware hacking a Roland DIF AT, to effect a repair. Lots of fun here using the microscope, replacing at least 15 solder pads sub .5mm pitch.
Learning a lot about embedded systems.
Working on my Cassette Synthesizer v2.2. This is going great, has a lovely panel now (FR4 PCB material drawn in Kicad.
Using Moritz Klein VCA, Envelope, VCF designs, I have extended the functionality of the envelope by implementing opamp functions to get multiple simultaneous inverted, non inverted envelope signals to control the Filter, VCA and external synths.
The cassette is basically the synth voice, and it responds to CV pitch to change motorspeed.
The linear nature of tape sounds very similar to vinyl scratching, and amazing with drumloops too.
I also added a pulse wave end of onset output, generated with a comparator from the envelope signal, and also a trigger output from the Env signal too.
These can be used for a square wave or pulse wave voice, when env is triggered very rapidly. Pulse width is cv and manual controllable.
I found a great kids digital camera too, in the Action. 1080p for 8e! Very bendable. I found there is an unpopulated header for the CMOS sensor, which I will solder a flat flex cable to, and with a .5 to 2.54 mm breakout board, the bend experiments will be made easy. It is tricky to solder the .5mm pitch header, but not so tricky as trying to connect individual bends there. I already found some great bends, and it has some quite nice mirror and negative fx too which look interesting. When the sensor is bent, this should look v. cool.
As I am new to this, my projects are pretty basic. I just started working on a LoFiFuture GBS8100 glitch/feedback unit.
I also have been messing with the ‘homebrew vga feedback circuit’ from LoFiFuture. I made a panel to mount for it with buttons for the direction, zoom and menu controls, as well as knobs for red green and blue.
The last project I am working on is circuit bending an old Vanguard video editor. I’m just started messing with that one. So far I have marked out all the voltage pins so I know not to touch them.
@PAUL_TEMPLE this was a really interesting read. that thing looks freaking coool!
i just discovered the great artist Kim Cascone the other day and thus a creation was made. hope you like it! * _ *
thank you! I love the look also. The deck bolts on with 3mm bolts, through the bottom of the case. So it will look like its just sat on the console case, all the wiring will go through the case body on the inside.
I had a nice idea about the kids video camera, when I get the flatflex connector. I will try and combine the cmos sensor signals with some logic, before sending them to different pins on the sensor. (instead of just connecting them together, via a pot or switch)
I’m trying to rekindle my creative practice after a several-months pause. Revisiting some material and techniques, I have been experimenting with combining my moiré generator and Compressure, to see how compression and interference artifacts play together.
Working on a fair amount of software. I just got this working finally, a GLSL engine written in Rust + Syphon & MIDI.
I found a demo video of my MK1 tape synth -
I’m getting closer to finish MK2 - it’s the same technique just with more capable synth parts (including VCF this time!)
I’m uploading more videos of hardware I’ve made these days. I like delays, analogue are best for me, tape, BBD, I used to have an oil can delay at one time as well, digital (early for preference, 90s can be good though too)
Digital can be usually be re-clocked and CV controlled which can sound very analoguey in it’s output. RAM bends can work well in many cases on digital delays, if RAM is accessible.
…actually, i am really intimidated posting in this thread as people are doing such impressive things - all the time! - and i cannot compete with those artists and geniuses, at all…
…but, this conception might be missing the point of this thread - the idea should perhaps rather be ‘what am i doing these days’ - as in ‘just share what you’re doing’ - so, here it is: finally managed to find the time and make an audio-reactive patch on my modular (for a piece of music made for the ‘one synth challenge: all sounds come from one synth only) :
…ah! - and: this is not rescanned, but imported via a Magewell-unit, and Youtube is unfortunately not able to show even only a fraction of what i saw here on the screens - what a pity…
great little Acid banger!
…a little playing around with cables, modules and video - yesterday Hardware-Jams-Weekend-Challenge contribution…
…video out of the Mac into the LZX Videomancer, from there into the video-modular (audio-reactive-patch) and back into the Mac:
Just released a music video yesterday. This is for our friend Maeve’s music project Porcelain Girls. We used claymation/stop motion and borrowed a friend’s photo studio for a proper one-day shoot with a fog machine and disco ball. For video art techniques we used a variety of techniques including rescanning off of a CRT, recording to VHS and then re-digitizing, playing with chroma key and mixer feedback on an MxPro and V-8, and a little Waaave Pools.
working on this CHDK (canon hack dev kit) enabled camera.
Modified the firmware a bit more for clean video out (no menu overlays)
Currently scripting leds to flash on the camera and using those voltage outputs (I wired to them) processed and isolated to trigger external events. Camera is synced to USB input (script looks for sync and locks to it)
Plan to integrate an mcu with motors, for an AV instrument, which can control itself, external gear, and be controlled by ext gear also. Mcu will be a midi/voltage sequencer processor. mcu boards have wireless capability which will be interesting.
All parts of the project have been recovered/repaired/reverse engineered.
In the video the camera is triggering 4066 to connect bend points together. More notes in the description -
Hi everyone,
I’m TT, a creator based in Japan.
I wanted to share a project I’m currently working on called “u_ray”, which is a video looper. I often draw inspiration from guitar pedals, and for this specific project, I’m heavily inspired by the Line 6 DL4.
At the moment, I’ve built a functional mock-up using HTML. My goal for this year is to develop a prototype that supports MIDI control and eventually transition it into standalone hardware using a Raspberry Pi.
Excited to be here and looking forward to sharing more updates soon!
Awesome! :heart:
Not analog, nor video, but I made some interesting photographs of “windows” with generative AI:
Programming a cpld as several logic gates, and using it to combine CCD address sensor signals and logic bits provided by camera status LED pulses (these pulse in tempo, controlled by a script) - also some (other) .lua scripts running on the camera. Next up for the camera node is a matrix switching circuit, possibly controlled over SPI.
The camera node is part of a larger AV instrument comprising of modified Camera, Monitor, Video Mixer, all accepting midi CC messages from a central sequencer/commander, which will also run stepper motors for physical control elements. Midi control is mostly implemented for all nodes.
I loved the tears coming out her face
thank you!
