Hi all,
I have a Panasonic MX-50 in pretty good working condition, some of the buttons are a bit jammy from time to time but all of the properties work well, except the AV-sync. For some reason when I press the button, it does not light up or do anything. The button itself is in the best condition out of pretty much all of them, indicating to me that it has not taken the same level of abuse in the past. Boardside everything seems fine, but I haven’t dared pull out the soldering iron, as nothing is loose or looks like an obvious culprit. Anyone else have the same issue?
Another thing I wanted to ask is has anyone used the GPI input for remote controlling Auto-Take? It seems like a pretty cool way of A/B take automation, if I could somehow wire up a switch to handle CV to GPI, theoretically I could then use my Eurorack to feed it trigger signals. The only problem I have is that the manual is super vague on the specs of the GPI, and after copious searching online I can’t find a direct reference to its specifics. I know there are other devices that utilize GPI, but the specs vary wildly and I don’t want to accidentally break my beloved MX-50. Any tips of the correct wiring of a make-contact switch that could take CV trigger to ground the GPI signal (as I understand it to work), or just general information on the MX-50 GPI would be greatly appreciated. All I know right now is that the MX-50 can be setup to Auto-Take when the GPI goes from high to low, and that the connector is BNC 75, tbh it would be nice to know the voltage and amps of the GPI if possible. (I’m a noob at electronics, be gentle
EDIT update: of course 6 months of intermittant googling about CV controlled GPI got me nowhere fast, but within an hour of posting this, I found the Elk Elektronik ELKLIK that could conceivably be used as a normally open relay for operating the GPI safely. ![]()
