Graphviz for video systems
Graphviz is a wonderful addition to the scanlines forum that is finally working!
This will allow us to make all kinds of patch/signal flow diagrams
lets step through some techniques
Basics
so first of all you can easily connect objects to each other with graphviz but we need to start with a blank slate. Lets say the header and foot we will work on filling in the body.
 [graphviz engine=dot]
        digraph structs {node [shape=record];
         (module connections go here)
     [/graphviz]
digraph structs {node [shape=record]; { }}
now something as simple as
a → b
will get you started patching
    a -> b
 [/graphviz]
digraph structs {node [shape=record]; { a -> b }}
if you want to connect one module to more than one module at a time just use a comma to separate the module.
    a -> b
    b -> c,a
 [/graphviz]
digraph structs {node [shape=record]; { a -> b b -> c,a }}
This works in the other direction too where you can connect more than one module to one.
        a -> b
        b -> c,a
        d,e -> b
     [/graphviz]
digraph structs {node [shape=record]; { a -> b b -> c,a d,e -> b }}
You can also color the patch connections easily by just adding [color=green] to the end.
a -> b
b -> c,a
d,e -> b
c -> a [color=green]
[/graphviz]
digraph structs {node [shape=record]; { a -> b b -> c,a d,e -> b c -> a [color=green] }}
you don’t have to use letters you could use module names like doorway.
a -> b
b -> c,a
d,e -> b
b -> doorway
[/graphviz]
digraph structs {node [shape=record]; { a -> b b -> c,a d,e -> b c -> a [color=green] b -> doorway }}
if you want to label your connections use [label=“channel 1”] after the connection
a -> b
b -> c,a
d,e -> b
b -> doorway
doorway -> vc [label="channel 1"]
[/graphviz]
digraph structs {node [shape=record]; { a -> b b -> c,a d,e -> b c -> a [color=green] b -> doorway doorway -> vc [label="channel 1"] }}
you can also write a longer single line patch as below.
a,b -> c -> b -> passage, doorway, prismatic -> mixer
[/graphviz]
digraph structs {node [shape=record]; { a,b -> c -> b -> passage, doorway, prismatic -> mixer }}
Advanced
IN THE EXAMPLES BELOW I AM ONLY COPYING THE BODY NOT THE HEADER AND FOOT.
one thing you may want to do is make structures instead of just a single node which will better represent modules.
a -> passage
digraph structs {node [shape=record]; {a -> passage}}
there are many inputs and outputs to a passage module so while a simple node may work for some signal flow diagrams it won’t for others.
a -> passage
passage [label="Passage |
{ 1 | 2 | 3}"];
digraph structs {node [shape=record]; {a -> passage passage [label="Passage |{ 1 | 2 | 3}"]; }}
you can see that we are just adding a definition for “passage” here under the connection . Within the [label] we add “|” lines to separate parts and sections go in “{ }” brackets.
so this is helpful and gives us some inputs or outputs but for the way I prefer laying things out inputs should be on the top and outputs on the bottom so this won’t work.
a -> passage
{1 | 2 | 3} }"];
digraph structs {node [shape=record]; {a -> passage passage [label="Passage |{ {1 | 2 | 3} }"]; }}
If we add an additional set of “{}” brackets within passage you can change the orientation of the sections.
a -> passage
{ {In 1 | 2 | 3 | Thru 1 | 2 | 3} }"];
digraph structs {node [shape=record]; {a -> passage passage [label="Passage |{ {In 1 | 2 | 3 | Thru 1 | 2 | 3} }"]; }}
Now we can add in the correct labels for our input section.
We also need to add a section on the output now.
a -> passage
{In 1 | 2 | 3 | Thru 1 | 2 | 3} |
{Out 1 | 2 | 3} }"];
digraph structs {node [shape=record]; {a -> passage passage [label="Passage |{ {In 1 | 2 | 3 | Thru 1 | 2 | 3} | {Out 1 | 2 | 3} }"]; }}
so as you can see we added another “|” line and then another section within “{}” brackets. This gives us an input and output section.
We are also going to want to be able to send connections directly to specific parts of each module so we need to label the parts. Add “<>” before the parts in each section to indicated the label to that part. Then instead of a connection saying “a → passage” we can instead specify “a → passage:tr” for the Thru R input.
I’m using ri,gi,bi,tr,tg,tb,ro,go,bo to label passage
“RGB” throughout
“i” for ins
“o” for outs
“t” for the Thru ins
a -> passage:tr
{ <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} |
{ <ro> Out 1 | <go> 2 | <bo> 3} } } "];
digraph structs {node [shape=record]; { a -> passage:tr passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; }}
Now if we add this passage definition to the last patch from the basic section we get this
digraph structs {node [shape=record];{ a,b -> c -> b -> passage, doorway, prismatic -> mixer passage [label="Passage |{{ <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; }}
Here we add a doorway definition to the previous patch.
doorway [label="Doorway|{
{ <t> Threshold | <s> Source | <g> Gain | <b> Background | <f> Foreground}|
{ <k> Key } }  } "];
digraph structs {node [shape=record]; { a,b -> c -> b -> passage, doorway, prismatic -> mixer passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source | <g> Gain | <b> Background | <f> Foreground}| { <k> Key } } } "]; }}
so if we take away the connections from before and make some of our own now that we have a couple modules we can do some fun stuff like this. I’ve added a second doorway by just changing the label slightly
doorway:k -> Mult_K -> passage:ri,passage:gi,passage:bi,doorway2:s
passage:ro,passage:go,passage:bo -> mixer
doorway2:k -> mixer
doorway2:k -> mult_k2 -> passage:tr,passage:tg,passage:tb
{ <k> Key } }  } "];
doorway2 [label="Doorway2|{
{ <k> Key } }  } "];
digraph structs {node [shape=record]; { doorway:k -> Mult_K -> passage:ri,passage:gi,passage:bi,doorway2:s passage:ro,passage:go,passage:bo -> mixer doorway2:k -> mixer doorway2:k -> mult_k2 -> passage:tr,passage:tg,passage:tb passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source | <g> Gain | <b> Background | <f> Foreground}| { <k> Key } } } "]; doorway2 [label="Doorway2|{ { <t> Threshold | <s> Source | <g> Gain | <b> Background | <f> Foreground}| { <k> Key } } } "]; }}
Patches
to see a LOT more patch visualizations check out the Patch dissection link at the bottom of this post
digraph structs {node [shape=record]; { memory:rgbo -> polar:rgbi polar:rgbo -> passage:trgb passage:rgbo -> visual:brgb memory:yo -> mult_y -> arch:a,mapper:h,doorway:s polar:nk -> mult_neg polar:pk -> mult_pos mult_pos, mult_neg -> switch switch -> arch:b arch:i -> mapper:s arch:c -> mapper:y mapper:rgbo -> matrix:rgbi matrix:rgbo -> visual:argb arch:xor -> rect_out rect_in -> arch:r arch:m -> matrix:inv doorway:k -> visual:color mult_pos -> arch:g arch:l -> visual:comp visual:comvo -> "Main Output" memory [label="Memory\nPalace |{ { <rgbo> RGB | <yo> Y} } "]; polar [label="Polar\nFringe |{ { <rgbi> RGB } | { <rgbo> RGB | <pk> Pos Key | <nk> Neg Key}} "] passage [label="Passage |{ { <trgb> Thru RGB} | { <rgbo> RGB } } } "]; visual [label="Visual\nCortex |{ { <brgb> B RGB | <comp> Composite | <argb> A RGB | <color> Colorize }| { <comvo> Component} } } "]; arch [label="Arch|{ { <g> Gamma | <b> B | <r> Rectifier | <a> Logic A }| { <xor> XOR | <l> Log | <m> Mirror | <i> Intersection | <c> Clip } } } "]; mapper [label="Mapper|{ { <s> Saturation | <y> Y Brightness | <h> Hue}| { <rgbo> RGB } } } "]; matrix [label="Matrix\nMixer|{ { <inv> INV | <rgbi> RGB }| { <rgbo> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; }}
code
memory:ro -> polar:ri [color = red]
memory:go -> polar:gi [color = green]
memory:bo -> polar:bi [color = blue]
polar:ro -> passage:tr [color = red]
polar:go -> passage:tg [color = green]
polar:bo -> passage:tb [color = blue]
passage:ro -> visual:br [color = red]
passage:go -> visual:bg [color = green]
passage:bo -> visual:bb [color = blue]
memory:yo -> mult_y
mult_y -> arch:a
switch -> arch:b
arch:i -> mapper:s
arch:c -> mapper:y
mult_y -> mapper:h
mapper:ro -> matrix:ri [color = red]
mapper:go -> matrix:gi [color = green]
mapper:bo -> matrix:bi [color = blue]
matrix:ro -> visual:ar [color = red]
matrix:go -> visual:ag [color = green]
matrix:bo -> visual:ab [color = blue]
rect_in -> arch:r
mult_y -> doorway:s
mult_pos -> arch:g
{<ai> A | <ri> R | <gi> G | <bi> B} |
{<yo> Y | <ro> R | <go> G | <bo> B} } "];
{ <ri> R | <gi> G | <bi> B} |
{ <ro> R | <go> G | <bo> B} } |{
{ <pk> Pos Key | <nk> Neg Key}} "]
{ <tr> Thru 1 | <tg> 2 | <tb> 3} |
{ <ar> A R | <ag> G | <ab> B | <br> B R | <bg> G | <bb> B | <color> Colorize | <comp> Composite }|
arch [label="Arch|{
{ <a> Logic A | <b> B | <r> Rectifier | <g> Gamma}|
{ <xor> XOR | <i> Intersection | <c> Clip | <l> Log | <m> Mirror } }  } "];
{ <h> Hue | <s> Saturation | <y> Y Brightness}|
{ <yo> Y | <uo> U | <vo> V | <ro> R | <go> G | <bo> B} }  } "];
{ <ri> R | <gi> G | <bi> B | <inv> INV}|
{ <ro> R | <go> G | <bo> B} }  } "];
{ <s> Source }|
{ <k> Key } }  } "];
digraph structs {node [shape=record]; { audio -> sensory:audio sensory:a -> slew:ai sensory:b -> slew:bi sensory:c -> slew:ci sensory:d -> slew:di sensory:e -> memory_zoom slew:ao -> mult_A slew:bo -> mult_B slew:co -> mult_C slew:do -> mult_D mult_A -> passage_r, polar_y, polar_fringe mult_B -> passage_g, memory_x, memory_hue mult_C -> passage_b, memory_y, memory_cont mult_D -> polar_x, memory_rot, polar_diam sensory [label="Sensory\nTranslator|{ { <audio> Audio}| { <a> A | <b> B | <c> C | <d> D | <e> E } } } "]; slew [label="Quad\nSlew|{ { <ai> A | <bi> B | <ci> C | <di> D}| { <ao> A | <bo> B | <co> C | <do> D} } } "]; }}
code
slew:ao -> mult_A
slew:bo -> mult_B
slew:co -> mult_C
slew:do -> mult_D
{ <audio> Audio}|
digraph structs { node [shape=record]; struct1 [shape=record,label= "Visual\nCortex | <h> H | <v> V| <hmv> H-V |<hpv> H+V"]; struct2 [shape=record,label=" Comparators | <1> one| <2> two "]; struct3 [shape=record,label="Memory\nPalace |{ {<a> A |<r> R|<g> G|<b> B}| CV\nInputs } "]; struct1:h -> struct2:1 struct1:v -> struct2:2 struct1:hmv -> Mixer struct2:1 -> Mixer; struct2:2 -> Mixer; Mixer -> "2:1 switch" struct1:hpv -> "2:1 switch" "2:1 switch" -> Doorway Doorway -> MULT MULT -> struct3: a MULT -> struct3: r }
code
 struct3 [shape=record,label="Memory\nPalace | { { <a> A |<r> R|<g> G|<b> B}| CV\nInputs }  "];
struct2:1 -> Mixer;
struct2:2 -> Mixer;
Doorway -> MULT
 MULT -> struct3: a
 MULT -> struct3: r
a list of module definitions
Patch Dissection
todo:
add section after advanced about visualizing knob settings
rename advanced section to creating modules
This is so cool - thanks for writing this guide to graphviz- can see it being v useful here !
Bump! (that is, I’m replying just to have this discussion pop up among the recent ones)
I tagged #graphviz the threads about Graphviz I found, please let me know if you spot more of them. All tags can be found here: https://scanlines.xyz/tags - please message me or other staff if you have suggestions
