Patch dissection
perhaps a little more than just sharing video output I’d like to see people discussing/dissecting their patches
with the graphviz extension working on scanlines now things are about to get very interesting
So I’ll start out with a painting tutorial video using the LZX memory palace
here is a little flow chart using graphviz showing the basic setup
digraph structs { node [shape=record]; struct1 [shape=record,label= "Visual\nCortex | <h> H | <v> V| <hmv> H-V |<hpv> H+V"]; struct2 [shape=record,label=" Comparators | <1> one| <2> two "]; struct3 [shape=record,label="Memory\nPalace |{ {<a> A |<r> R|<g> G|<b> B}| CV\nInputs } "]; struct1:h -> struct2:1 struct1:v -> struct2:2 struct1:hmv -> Mixer struct2:1 -> Mixer; struct2:2 -> Mixer; Mixer -> "2:1 switch" struct1:hpv -> "2:1 switch" "2:1 switch" -> Doorway Doorway -> MULT MULT -> struct3: a MULT -> struct3: r }
and here is a video going over the ideas behind the patch
this was essentially the same patch we used for of Vidicon presentation this year (a prismatic ray was used to modulate the threshold of the doorway additionally)
lets break things down
Here is a patch backbone we have only recently (the past week?) had the equipment to build that has granted access to a lot of really incredible feedback hyperplanes.
digraph structs {node [shape=record]; { chords:ro -> visual:ar [color = red] chords:go -> visual:ag [color = green] chords:bo -> visual:ab [color = blue] memory:cvbs1 -> mx50:src1 mx50:prog1 -> monitor2 mx50:prog2 -> "CVBS to YPbPr" -> visual:ypbpr_in mx50:prog2 -> mx50:src4 visual:decr -> memory:ri [color = red] visual:decg -> memory:gi [color = green] visual:decb -> memory:bi [color = blue] visual:cvbs1 -> mx50:src2 visual:cvbs2 -> monitor1 -> "???" ->cam -> mx50:src3 visual:expr -> chords:l4r [color = red] visual:expg -> chords:l4g [color = green] visual:expb -> chords:l4b [color = blue] ramps -> key -> chords:l1 key -> memory:ai memory [label="Memory\nPalace |{ {<ai> A | <ri> R | <gi> G | <bi> B} | {<yo> Y | <ro> R | <go> G | <bo> B | <cvbs1> CVBS 1 | <cvbs2> 2 }} "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B | <br> B R | <bg> G | <bb> B | <ypbpr_in> YPbPr } | { <decr> Dec R | <decg> G | <decb> B | <cvbs1> CVBS 1 | <cvbs2> 2 | <expr> Expander R | <expg> G | <expb> B } } } "]; chords [label="Color\nChords|{ { <l1> Layer 1 | <l2> 2 | <l3> 3 | <l4r> 4 R | <l4g> G | <l4b> B }| { <ro> R | <go> G | <bo> B} } } "]; mx50 [label="WJ-MX50|{ { <src1> Src 1 | <src2> 2 | <src3> 3 | <src4> 4 } | { <prog1> Prog 1 | <prog2> 2 } }"]; }}
The idea is kind of to mix between several different “taps” of the same feedback loop. Each feedback path is using some kind of obstruction to inject information into the loop:
  • the key from the Memory Palace, either in warp or paint mode.
  • putting one or more synthesized patterns into the foreground layers of Color Chords, so they lie “on top of”† the VC expander → Color Chords background feedback image
  • physical objects / optical filters / other stuff in the camera feedback path. This one we have not really even begun to explore yet.
  • wipes between channels with the MX50 itself. The MX50 effects can do a ton of work in this patch, I’m especially fond of compression wipes and the Multi screen tiling.
†"You can not refer to image planes as in front of or behind, etc., that is just an illusory human perception. The Cathode Ray Tube knows nothing of this, I can prove it to you.” –Dan Sandin
I think it would be a great idea (for me personally and for the community at large) to go through the LZX 3 patch series and add some patch visualizations.
My goal would be eventually to spiral bind and laminate them for a physical LZX patch book
I’ll be adding pictures and more patches as I go :slight_smile:
Passage 3 Patches
Passage 3 patches video
Patch 1
digraph structs {node [shape=record]; { "H+V in" -> passage:tr passage:ro -> chords:ri chords:rgb -> visual:argb visual:hpv -> "H+V out" visual:comvo -> "Main Output" visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; passage [label="Passage |{ { <tr> Thru 1 } | { <ro> Out 1 } } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; }}
digraph structs {node [shape=record]; { "H+V in" -> passage:tr passage:ro -> stair:s stair:on -> chords:ri pendulum:ao -> passage:ri chords:rgb -> visual:argb visual:hpv -> "H+V out" visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; }}
digraph structs {node [shape=record]; { "H+V in" -> passage:tr passage:go -> stair:s passage:ro -> passage_out passage_in -> passage:tg stair:on -> chords:ri pendulum:ao -> passage:ri chords:rgb -> visual:argb visual:hpv -> "H+V out" visual:comvo -> "Main Output" ray:t -> passage:gi chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; }}
Patch 2 dynamic keying
digraph structs {node [shape=record]; { "liquid light show composite video" -> visual:v chords:rgb -> RGB_out RGB_in -> visual:argb visual:y -> passage:tr passage:ro -> doorway:s passage:go -> chords:gi doorway:k -> chords:ri pendulum:ao -> passage:gi pendulum:bo -> passage:bi visual:hpv -> passage:tb passage:bo -> doorway:t visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; passage [label="Passage |{ { <gi> 2 | <bi> 3 | <tr> Thru 1 | <tb> 3} | { <ro> Out 1 | <bo> 3 | <go> 2 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A | <bo> LFO B} } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB | <v> Composite }| { <y> Y |<hpv> H+V | <comvo> Component} } } "]; }}
Patch 3 multi-dimensional pattern maker
digraph structs {node [shape=record]; { chords:rgb -> RGB_Out RGB_In -> visual:argb visual:hpv -> passage:tb visual:hmv -> passage:tr passage:ro -> stair:s passage:bo -> doorway:s ray:t -> drifting_H -> passage:bi doorway:k -> chords:ri stair:on -> chords:gi pendulum:ao -> passage:ri ray:si -> passage:gi passage:go -> chords:bi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> A } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin | <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hmv> H-V | <hpv> H+V | <comvo> Component} } } "]; }}
Pendulum 3 Patches
Pendulum 3 patches video
Patch 1 Modulated crossfader
digraph structs {node [shape=record]; { Andor -> visual:comvi memory:y -> Still -> pendulum:ai visual:y -> pendulum:bi pendulum:do -> Fade_Out Fade_In -> visual:ar ray:t -> pendulum:cvc visual:comvo -> "Main Output" memory [label="Memory\nPalace |{ {<y> Y }} "]; pendulum [label="Pendulum |{ { <bi> B--C | <ai> A--D | <cvc> Crossfade VC }| { <do> D } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A R | <comvi> Composite vid}| { <comvo> Component | <y> Y } } } "]; }}
Patch 2 Shape synthesis
digraph structs {node [shape=record]; { visual:hpv -> doorway:s pendulum:co -> doorway:t doorway:k -> Key_Out Key_In -> visual:ar ray:t -> pendulum:cvc visual:comvo -> "Main Output" doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; pendulum [label="Pendulum |{ { <cvc> Crossfade VC }| { <co> C } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A R }| { <comvo> Component | <hpv> H+V } } } "]; }}
basic patch above^^
adding in videos below
digraph structs {node [shape=record]; { visual:hpv -> doorway:s pendulum:co -> doorway:t doorway:k -> Key_Out Key_In -> visual:ar ray:t -> pendulum:cvc Andor -> visual:comvi visual:y -> pendulum:bi memory:y -> pendulum:ai visual:comvo -> "Main Output" doorway [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; memory [label="Memory\nPalace |{ {<y> Y }} "]; pendulum [label="Pendulum |{ { <ai> A--D | <cvc> Crossfade VC | <bi> B--C }| { <co> C } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A R | <comvi> Composite vid}| { <y> Y | <hpv> H+V | <comvo> Component} } } "]; }}
Patch 3 More complicated shape synthesis
digraph structs {node [shape=record]; { visual:hpv -> pendulum:ai visual:hmv -> pendulum:bi ray:s -> pendulum:cvc pendulum:co -> stair:s stair:on -> doorway:s pendulum:ao -> doorway:t doorway:k -> Key_Out Key_In -> visual:ar visual:comvo -> "Main Output" doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; pendulum [label="Pendulum |{ { <ai> A--D | <bi> B--C | <cvc> Crossfade VC }| { <co> C | <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <s> Sin } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A R }| { <hpv> H+V | <hmv> H-V | <comvo> Component} } } "]; }}
Staircase 3 Patches
Staircase 3 patches video
Patch 1 basic functionality
Basic patch
digraph structs {node [shape=record];{ visual:hpv -> stair:s stair:on -> Stair_Out Stair_In -> visual:ar visual:comvo -> "Main Output" stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A R }| { <hpv> H+V | <comvo> Component} } } "]; }}
Full staircase colorization
digraph structs {node [shape=record];{ visual:hpv -> stair:s stair:on -> chords:ri [color=red] stair:tw -> chords:gi [color=green] stair:fo -> chords:bi [color=blue] chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2 | <fo> 4 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; }}
Feedback excursion
digraph structs {node [shape=record];{ visual:hpv -> stair:s stair:tw -> Feedback_Out Feedback_In -> stair:f stair:on -> chords:ri chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" stair [label="Staircase |{ { <f> Frequency | <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; chords [label="Color\nChords|{ { <ri> R }| { <rgb> RGB } } } "]; }}
Full staircase colorization w/ modulator
digraph structs {node [shape=record];{ visual:hpv -> stair:s stair:on -> chords:ri [color=red] stair:tw -> chords:gi [color=green] stair:fo -> chords:bi [color=blue] ray:t -> or or -> stair:f,stair:p chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" stair [label="Staircase |{ { <f> Frequency | <p> Phase | <s> Source }| { <on> /1 | <tw> /2 | <fo> 4 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <comvo> Component} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; }}
Patch 2 staircase as a voltage controlled oscillator
basic patch
digraph structs {node [shape=record];{ visual:h -> stair:s stair:on -> chords:ri chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <h> H | <comvo> Component} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; }}
adding in modulation
digraph structs {node [shape=record];{ visual:h -> stair:s stair:tw -> chords:gi chords:rgb -> RGB_Out RGB_In -> visual:argb pendulum:ao -> stair:p ray:t -> chords:ri stair:on -> ray:f visual:hpv -> stair:f visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <f> Frequency }| { <t> Tri } } } "]; stair [label="Staircase |{ { <p> Phase | <f> Frequency | <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB }| { <hpv> H+V | <h> H | <comvo> Component} } } "]; }}
Patch 3 Processing External video
digraph structs {node [shape=record];{ "External video" -> visual:comvi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:y -> passage:ri passage:ro -> stair:s stair:on -> chords:ri pendulum:ao -> stair:p visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <p> Phase | <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB | <comvi> Composite}| { <y> Y | <comvo> Component} } } "]; }}
digraph structs {node [shape=record];{ "External video" -> visual:comvi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:y -> passage:ri passage:ro -> stair:s stair:on -> chords:ri [color=red] stair:tw -> chords:gi [color=green] stair:fo -> chords:bi [color=blue] passage:go -> stair:f pendulum:ao -> stair:p visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <p> Phase | <s> Source | <f> Frequency }| { <on> /1 | <tw> /2 | <fo> /4} } } "]; visual [label="Visual\nCortex |{ { <argb> Channel A RGB | <comvi> Composite}| { <y> Y | <comvo> Component} } } "]; }}
Color chords 3 Patches
Color chords 3 patches video
Patch 1 Basic use
digraph structs {node [shape=record];{ chords:rgb -> RGB_Out RGB_In -> visual:argb visual:hpv -> chords:ri visual:hmv -> stair:s stair:on -> chords:gi visual:h -> doorway:s doorway:k -> chords:bi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> Channel A RGB }| { <hpv> H+V | <hmv> H-V | <h> H | <comvo> Component} } } "]; }}
Patch 2 Color chords as a matrix mixer
digraph structs {node [shape=record];{ visual:v -> passage:tr pendulum:ao -> passage:ri ray:t -> chords:gi memory:y -> chords:bi chords:ro -> doorway:s doorway:k -> visual:ar passage:ro -> Passage_Out Passage_In -> chords:ri chords:go -> stair:s stair:on -> doorway:b chords:bo -> doorway:f visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <ro> R | <go> G | <bo> B } } } "]; doorway [label="Doorway|{ { <s> Source | <b> Background | <f> Foreground }| { <k> Key } } } "]; memory [label="Memory\nPalace |{ {<y> Y}} "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> R }| { <v> V | <comvo> Component} } } "]; }}
Patch 3 Combining Color Chords with Visual Cortex for precise color picking
digraph structs {node [shape=record];{ memory:y -> chords:ri visual:hmv -> passage:tr pendulum:bo -> passage:ri passage:ro -> stair:s stair:on -> chords:gi visual:v -> doorway:s doorway:k -> chords:bi pendulum:ao -> doorway:t Eternal_Video -> visual:comvi visual:y -> luma_out Luma_In -> visual:br visual:hpv -> Circle_Out Circl_In -> visual:k chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; memory [label="Memory\nPalace |{ {<y> Y}} "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1} } } "]; pendulum [label="Pendulum |{ { <bo> LFO B | <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <br> B R | <k> Key | <comvi> Composite}| { <hmv> H-V | <v> V | <y> Y | <comvo> Component | <hpv> H+V } } } "]; }}
variation using a multed luma out from the external video coming into visual cortex as a layer on color chords.
digraph structs {node [shape=record];{ visual:hmv -> passage:tr pendulum:ao -> passage:ri passage:ro -> stair:s memory:y -> chords:ri stair:on -> chords:gi visual:y -> MULT -> Luma_Out,chords:bi Eternal_Video -> visual:comvi Luma_In -> visual:br visual:hpv -> Circle_Out Circl_In -> visual:k chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; memory [label="Memory\nPalace |{ {<y> Y}} "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <br> B R | <k> Key | <comvi> Composite}| { <hmv> H-V | <y> Y | <comvo> Component | <hpv> H+V } } } "]; }}
Doorway 3 Patches
Doorway 3 patches video
Basic example
digraph structs {node [shape=record];{ visual:hpv -> doorway:s doorway:k -> chords:ri wota:a -> doorway:f chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <f> Foreground | <s> Source }| { <k> Key } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; wota [label="War\nOf\nThe\nAnts |{ { <a> Animation } } "]; }}
Patch 1 Creating complex shapes
Summing PR and a V ramp through staircase
–Step 1 - Setting up your shape
digraph structs {node [shape=record];{ visual:hpv -> chords:gi visual:v -> stair:s ray:t -> passage:ri stair:on -> passage:tr passage:ro -> chords:ri chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <v> V |<hpv> H+V | <comvo> Component } } } "]; }}
–Step 2 - Creating a key
digraph structs {node [shape=record];{ visual:hpv -> chords:gi visual:v -> stair:s ray:t -> passage:ri stair:on -> passage:tr passage:ro -> doorway:s doorway:k -> chords:ri chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <v> V | <hpv> H+V | <comvo> Component } } } "]; }}
–Step 3 - Adding modulation
digraph structs {node [shape=record];{ visual:hpv -> chords:gi visual:v -> stair:s ray:t -> passage:ri stair:on -> passage:tr passage:ro -> doorway:s doorway:k -> chords:ri pendulum:ao -> doorway:t wota:t -> doorway:f chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <f> Foreground | <t> Threshold | <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <v> V |<hpv> H+V | <comvo> Component } } } "]; wota [label="War\nOf\nThe\nAnts |{ { <t> Texture } } "]; }}
Patch 2 Doorway as a simple VCO
–Step 1 - Simple VCO
digraph structs {node [shape=record];{ visual:h -> doorway:s doorway:k -> chords:ri chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <h> H | <comvo> Component } } } "]; }}
–Step 2 - Creating different shapes
digraph structs {node [shape=record];{ visual:h -> doorway:s doorway:k -> chords:ri visual:hpv -> doorway:t chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <h> H | <comvo> Component } } } "]; }}
–Step 3 - Adding movement
digraph structs {node [shape=record];{ visual:h -> doorway:s doorway:k -> chords:ri visual:hpv -> passage:tr pendulum:ao -> passage:ri passage:ro -> doorway:t chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 | } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <h> H| <comvo> Component } } } "]; }}
–Step 4 - Using this setup as a VCO
digraph structs {node [shape=record];{ visual:h -> doorway:s doorway:k -> Mult -> ray:f, ray:p visual:hpv -> passage:tr pendulum:ao -> passage:ri passage:ro -> doorway:t ray:t -> chords:ri passage:go -> chords:gi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 | } | { <ro> Out 1 | <go> 2 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <f> Frequency | <p> Pedestal }| { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <h> H | <comvo> Component } } } "]; }}
Patch 3 Processing external video and making wipes
–Step 1 - Processing external video
digraph structs {node [shape=record];{ visual:y -> doorway:s doorway:k -> chords:ri External_Video -> visual:comvi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite }| { <y> Y | <comvo> Component } } } "]; }}
–Step 2 - Setting up a wipe
digraph structs {node [shape=record];{ visual:y -> doorway:f visual:hpv -> doorway:s doorway:k -> chords:ri External_Video -> visual:comvi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <f> Foreground | <s> Source }| { <k> Key } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite }| { <y> Y | <hpv> H+V | <comvo> Component } } } "]; }}
–Step 3 - combining both techniques
image key & wipe
digraph structs {node [shape=record];{ visual:y -> pendulum:ai visual:hpv -> pendulum:cvc pendulum:do -> doorway:s doorway:k -> chords:ri memory:y -> chords:gi ray:t -> nosync -> doorway:f External_Video -> visual:comvi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <f> Foreground | <s> Source }| { <k> Key |} } } "]; memory [label="Memory\nPalace |{ {<y> Y }} "]; pendulum [label="Pendulum |{ { <ai> A--D | <cvc> Crossfade VC }| { <do> D } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite }| { <y> Y | <hpv> H+V | <comvo> Component } } } "]; }}
Bridge 3 patches
Bridge 3 patches video
Patch 1 Working with TB 303 / CV & GATE instrument
–Step 1 - Connecting a CV/Gate source
digraph structs {node [shape=record];{ memory:y -> visual:k TB_303_CV -> bridge:ai TB_303_Gate -> bridge:bi bridge:ao -> memory:z bridge:bo -> memory:h memory:rgbo -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B }| { <ao> A | <bo> B } } } "]; memory [label="Memory\nPalace |{ { <z> Zoom | <h> Hue } | { <rgbo> RGB | <y> Y } }} "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <k> Key }| { <comvo> Component } } } "]; }}
–Step 2 - Using a fader to modulate a CV source
digraph structs {node [shape=record];{ memory:y -> visual:k TB_303_CV -> bridge:ai TB_303_Gate -> bridge:bi bridge:ao -> Fader_Out Fader_In -> bridge:fa bridge:bo -> memory:h bridge:fo -> memory:z ray:t -> bridge:fv memory:rgbo -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B | <fa> Fader A | <fv> VC }| { <ao> A | <bo> B | <fo> Fader } } } "]; memory [label="Memory\nPalace |{ { <h> Hue | <z> Zoom } | { <rgbo> RGB | <y> Y }} "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <k> Key }| { <comvo> Component } } } "]; }}
–Step 3 - Using a mixer to modulate a Gate
digraph structs {node [shape=record];{ memory:y -> visual:k TB_303_CV -> bridge:ai TB_303_Gate -> bridge:bi bridge:ao -> Fader_Out Fader_In -> bridge:fa bridge:fo -> memory:z bridge:bo -> Mixer_Out ray:s -> bridge:mm Mixer_In -> bridge:mpa ray:t -> bridge:fv bridge:mo -> memory:h bridge:ao -> visual:com memory:rgbo -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B | <fa> Fader A | <fv> VC || <mpa> Mixer + | <mm> - }| { <ao> A | <bo> B | <fo> Fader | <mo> Mixer} } } "]; memory [label="Memory\nPalace |{ { <z> Zoom | <h> Hue } | { <rgbo> RGB | <y> Y }} "]; ray [label="Prismatic\nRay |{ { <t> Tri | <s> Sin } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <k> Key | <com> Composite}| { <comvo> Component } } } "]; }}
Patch 2 Using crossfader and mixer to create more intricate patterns and shapes
–Step 1 - setting up the fader
digraph structs {node [shape=record];{ visual:hpv -> bridge:fa visual:hmv -> bridge:fb bridge:fo -> chords:ri ray:si -> passage:ri passage:ro -> bridge:fv chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <fa> Fader A | <fb> B | <fv> VC }| { <fo> Fader } } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <hmv> H-V | <comvo> Component } } } "]; }}
–Step 2 - the modulation isn’t going to show too well as it is similar to the other ramps still.
digraph structs {node [shape=record];{ visual:hpv -> bridge:fa visual:hmv -> bridge:fb bridge:fo -> doorway:s doorway:k -> chords:ri ray:si -> passage:ri passage:ro -> bridge:fv visual:h -> bridge:mm visual:v -> bridge:mpa bridge:mo -> doorway:t chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <fv> VC | <fa> Fader A | <fb> B | <mpa> Mixer + | <mm> - }| { <fo> Fader | <mo> Mixer} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <hmv> H-V | <v> V | <h> H | <comvo> Component } } } "]; }}
–Step 3 - adding modulation with additional passage channels
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> bridge:fa visual:hmv -> "H-V Out" "H-V In" -> bridge:fb bridge:fo -> doorway:s doorway:k -> chords:ri ray:si -> passage:ri passage:ro -> bridge:fv visual:h -> passage:tg pendulum:ao -> passage:gi passage:go -> bridge:mm visual:v -> passage:tb pendulum:bo -> passage:bi passage:bo -> bridge:mpa bridge:mo -> doorway:t chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <fa> Fader A | <fb> B | <fv> VC | <mm> - | <mpa> Mixer + }| { <fo> Fader | <mo> Mixer} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> A | <bo> B } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <h> H | <v> V | <hpv> H+V | <hmv> H-V | <comvo> Component } } } "]; }}
–Step 4 - running into a staircase for extra complexity
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> bridge:fa visual:hmv -> "H-V Out" "H-V In" -> bridge:fb bridge:fo -> doorway:s doorway:k -> chords:ri ray:si -> passage:ri passage:ro -> bridge:fv visual:h -> passage:tg pendulum:ao -> passage:gi passage:go -> bridge:mm visual:v -> passage:tb passage:bo -> bridge:mpa bridge:mo -> stair:s stair:on -> doorway:t stair:tw -> chords:gi chords:rgb -> RGB_Out RGB_In -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <fa> Fader A | <fb> B | <fv> VC | <mm> - | <mpa> Mixer + }| { <fo> Fader | <mo> Mixer} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <ao> A } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2} } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <h> H | <v> V | <hpv> H+V | <hmv> H-V | <comvo> Component } } } "]; }}
Patch 3 Using bridge as a keyer
–Step 1 - Setting up the key
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> bridge:ai bridge:ao -> visual:ar visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A }| { <ao> A } } } "]; visual [label="Visual\nCortex |{ { <ar> A R }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 2 - Colorize for more fun
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> passage:ri passage:ro -> bridge:ai bridge:ao -> visual:col visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A }| { <ao> A } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; visual [label="Visual\nCortex |{ { <col> Colorize }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 3 - Add memory palace animation with fader
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> passage:ri passage:ro -> bridge:ai bridge:ao -> Fade_Out memory:y -> bridge:fa Fade_In -> bridge:fv bridge:fo -> visual:col visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <fa> Fader A | <fb> B | <fv> VC }| { <ao> A | <fo> Fader } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; memory [label="Memory\nPalace |{ { <y> Y }} "]; visual [label="Visual\nCortex |{ { <col> Colorize }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 4 - adding prismatic ray texture
digraph structs {node [shape=record];{ visual:hpv -> "H+V Out" "H+V In" -> passage:ri passage:ro -> bridge:ai bridge:ao -> Fade_Out memory:y -> bridge:fa Fade_In -> bridge:fv, ray:p bridge:fo -> visual:col ray:t -> bridge:fb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <fa> Fader A | <fb> B | <fv> VC }| { <ao> A | <fo> Fader } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; memory [label="Memory\nPalace |{ { <y> Y }} "]; ray [label="Prismatic\nRay |{ { <p> Pedestal }| { <t> Tri} } } "]; visual [label="Visual\nCortex |{ { <col> Colorize }| { <hpv> H+V | <comvo> Component } } } "]; }}
Marble Index 3 patches
Marble Index 3 patches video
Patch 1 Basic starter
–Step 1 - component video into the visual cortex then take the decoder output into marble index channel a and then into visual cortex channel a
digraph structs {node [shape=record];{ marble:rgb -> visual:argb visual:rgbo -> RGB_Out RGB_In -> marble:argb External_Video -> visual:comvi visual:comvo -> "Main Output" marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite}| { <rgbo> Dec RGB | <comvo> Component } } } "]; }}
–Step 2 - Adding second source
digraph structs {node [shape=record];{ marble:rgb -> visual:argb ray:t -> chords:ri chords:rgb -> RGB_Out_B RGB_IN_B -> marble:brgb visual:hpv -> passage:ri passage:ro -> ray:s visual:rgbo -> RGB_Out RGB_In -> marble:argb External_Video -> visual:comvi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <brgb> B RGB }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; ray [label="Prismatic\nRay |{ { <s> Sync }| { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <comvi> Component | <argb> A RGB }| { <rgbo> Dec RGB | <hpv> H+V | <comvo> Component } } } "]; }}
–Step 3 - Adding opacity modulation
digraph structs {node [shape=record];{ marble:rgb -> visual:argb ray:t -> chords:ri chords:rgb -> RGB_Out_B RGB_IN_B -> marble:brgb visual:hpv -> passage:ri passage:ro -> ray:s passage:go -> doorway:s doorway:k -> Opacity_Out_B Opacity_In_B -> marble:ob visual:rgbo -> RGB_Out RGB_In -> marble:argb External_Video -> visual:comvi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <ob> Opacity B | <brgb> B RGB }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 | <go> 2 } } } "]; ray [label="Prismatic\nRay |{ { <s> Sync }| { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <comvi> Component | <argb> A RGB | <k> Key }| { <rgbo> Dec RGB | <hpv> H+V | <comvo> Component } } } "]; }}
Patch 2 Complex shape and pattern generation
–Step 1 - simple pattern from staircase
digraph structs {node [shape=record];{ chords:rgb -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out visual:hpv -> passage:tr pendulum:bo -> passage:ri passage:ro -> stair:s passage:go -> chords:bi stair:on -> chords:ri stair:tw -> chords:gi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 | <go> 2 } } } "]; pendulum [label="Pendulum |{ { <bo> LFO B } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 2 - Make key for opacity on marble index
digraph structs {node [shape=record];{ chords:rgb -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out visual:hpv -> passage:tr pendulum:bo -> passage:ri passage:ro -> MULT -> stair:s,doorway:s doorway:k -> marble:oa passage:go -> chords:bi stair:on -> chords:ri stair:tw -> chords:gi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <oa> Opacity A | <argb> A RGB }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 | <go> 2 } } } "]; pendulum [label="Pendulum |{ { <bo> LFO B } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 3 - Add second channel to marble index
digraph structs {node [shape=record];{ chords:rgb -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out visual:hpv -> passage:tr pendulum:bo -> passage:ri passage:ro -> mult_B -> stair:s,doorway:s doorway:k -> marble:oa passage:go -> chords:bi stair:on -> chords:ri stair:tw -> chords:gi ray:t -> marble:br visual:hmv -> passage:tb pendulum:ao -> passage:bi passage:bo -> mult_A -> ray:p,ray:f visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <oa> Opacity A | <argb> A RGB | <br> B R }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <bo> LFO B | <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <p> Pedestal | <f> Frequency }| { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <hmv> H-V | <comvo> Component} } } "]; }}
–Step 4 - Adding complexity with more modulation (opacity B, phase, Memory palace)
digraph structs {node [shape=record];{ chords:rgb -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out visual:hpv -> passage:tr pendulum:bo -> passage:ri passage:ro -> mult_B -> stair:s,doorway:s doorway:k -> marble:oa passage:go -> chords:bi stair:on -> chords:ri stair:tw -> chords:gi ray:t -> marble:br visual:hmv -> passage:tb pendulum:ao -> passage:bi passage:bo -> mult_A -> ray:p,ray:f ray:si -> marble:ob ray:pa -> stair:p memory:rgb -> marble:bgrgb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <bgrgb> BG RGB | <oa> Opacity A | <argb> A RGB | <ob> Opacity B | <br> B R | }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pendulum [label="Pendulum |{ { <bo> LFO B | <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <p> Pedestal | <f> Frequency }| { <pa> Parabola | <si> Sin | <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase}| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <hmv> H-V | <comvo> Component} } } "]; memory [label="Memory\nPalace |{ { <rgb> RGB } } } "]; }}
Patch 3 Combining 3 full color images with marble index
–Step 1 - Getting an external video into marble index and patching that back into the visual cortex
digraph structs {node [shape=record];{ visual:rgbo -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out External_Video -> visual:comvi visual:comvo -> "Main Output" marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB |<comvi> Component }| { <rgbo> Dec RGB | <comvo> Component} } } "]; }}
–Step 2 - Create pattern with staircase to use as background, including cross modulation from external video source (Y)
digraph structs {node [shape=record];{ visual:hpv -> passage:tg passage:go -> stair:s stair:on -> chords:ri stair:tw -> chords:gi chords:rgb -> marble:bgrgb visual:y -> stair:p pendulum:ao -> passage:gi visual:rgbo -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out External_Video -> visual:comvi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; marble [label="Marble\nIndex |{ { <bgrgb> BG RGB | <argb> A RGB }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <gi> In 2 | <tg> Thru 2 } | { <go> 2 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <p> Phase | <s> Source }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <y> Y | <hpv> H+V | <rgbo> Dec RGB | <comvo> Component} } } "]; }}
–Step 3 - Memory palace to B RGB channel (MI), add key to opacity B
digraph structs {node [shape=record];{ visual:hpv -> passage:tg passage:go -> stair:s stair:on -> chords:ri stair:tw -> chords:gi chords:rgb -> marble:bgrgb visual:y -> Mult_Y -> stair:p,doorway:s pendulum:ao -> passage:gi doorway:k -> marble:ob visual:hmv -> doorway:t memory:rgb -> marble:brgb visual:rgbo -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out External_Video -> visual:comvi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <bgrgb> BG RGB | <ob> Opacity B | <argb> A RGB | <brgb> B RGB }| { <rgb> RGB } } } "]; memory [label="Memory\nPalace |{ { <rgb> RGB } } } "]; passage [label="Passage |{ { <gi> In 2 | <tg> Thru 2 } | { <go> 2 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <hpv> H+V | <y> Y | <hmv> H-V | <rgbo> Dec RGB | <comvo> Component} } } "]; }}
–Step 4 - Y (MP) to opacity A (MI)
digraph structs {node [shape=record];{ visual:hpv -> passage:tg passage:go -> stair:s stair:on -> chords:ri stair:tw -> chords:gi chords:rgb -> marble:bgrgb visual:y -> Mult_Y -> stair:p,doorway:s pendulum:ao -> passage:gi doorway:k -> marble:ob visual:hmv -> doorway:t memory:y -> passage:bi bridge:ao -> marble:oa passage:bo -> bridge:ai memory:rgb -> marble:brgb visual:rgbo -> marble:argb RGB_In -> visual:argb marble:rgb -> RGB_Out External_Video -> visual:comvi visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A }| { <ao> A } } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <oa> Opacity A | <bgrgb> BG RGB | <brgb> B RGB | <ob> Opacity B | <argb> A RGB }| { <rgb> RGB } } } "]; memory [label="Memory\nPalace |{ { <y> Y | <rgb> RGB } } } "]; passage [label="Passage |{ { <gi> In 2 | <bi> 3 | <tg> Thru 2 } | { <bo> 3 | <go> 2 } } } "]; pendulum [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase }| { <on> /1 | <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <hpv> H+V | <y> Y | <hmv> H-V | <rgbo> Dec RGB | <comvo> Component} } } "]; }}
Prismatic Ray 3 patches
Prismatic Ray 3 patches video
Patch 1 Alternate sync sources
–Step 1 - PR to VC
digraph structs {node [shape=record];{ ray:t -> visual:ar visual:comvo -> "Main Output" ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component } } } "]; }}
–Step 2 - Second PR to Frequency modulate first PR
digraph structs {node [shape=record];{ ray2:s -> visual:ar ray:t -> ray2:f visual:comvo -> "Main Output" ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <f> Frequency }| { <s> Square } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component } } } "]; }}
–Step 3 - Using a H+V ramp to sync a PR
digraph structs {node [shape=record];{ ray2:s -> visual:ar "H+V In"-> ray2:sy visual:comvo -> "Main Output" visual:hpv -> "H+V Out" ray2 [label="Prismatic\nRay2 |{ { <sy> Sync }| { <s> Square } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 4 - Adding modulation section for H+V ramp and second PR FMing first
digraph structs {node [shape=record];{ ray:t -> ray2:f visual:hpv -> "H+V Out" ray2:s -> visual:ar "H+V In"-> passage:ri passage:ro -> ray2:sy visual:comvo -> "Main Output" passage [label="Passage |{ { <ri> In 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <sy> Sync | <f> Frequency }| { <s> Square } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 5 - Adding 3rd PR via passage
digraph structs {node [shape=record];{ ray:t -> ray2:f visual:hpv -> "H+V Out" ray2:s -> visual:ar "H+V In"-> passage:ri passage:ro -> "Passage Out" "Passage In" -> passage:tg ray3:t-> passage:gi passage:go-> ray2:sy visual:comvo -> "Main Output" passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <tg> Thru 2 } | { <ro> Out 1 | <go> 2 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <sy> Sync | <f> Frequency }| { <s> Square } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 6 - Adding complexity to the sync source
digraph structs {node [shape=record];{ ray:t -> ray2:f visual:hpv -> "H+V Out" ray2:s -> visual:ar "H+V In"-> passage:ri passage:ro -> "Passage Out" "Passage In" -> passage:tg ray3:t -> passage:gi passage:go -> stair:s stair:on -> ray2:sy visual:comvo -> "Main Output" passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <tg> Thru 2 } | { <ro> Out 1 | <go> 2 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <sy> Sync | <f> Frequency }| { <s> Square } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <hpv> H+V | <comvo> Component } } } "]; }}
Patch 2 PR gradients with doorway and staircase, pedestal and multiply PR modulation
–Step 1 - initial shape generator
digraph structs {node [shape=record];{ ray:t -> chords:ri ray2:t -> "Or" -> ray:m,ray:p chords:rgb -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; ray [label="Prismatic\nRay |{ { <m> Multiply | <p> pedestal }| { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <sy> Sync | <f> Frequency }| { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
–Step 2 - adding doorway for keying, 3rd PR for modulation
digraph structs {node [shape=record];{ ray2:t -> ray:p ray:t -> "Mult" -> doorway:s, stair:s doorway:k -> chords:ri chords:rgb -> visual:argb ray3:t -> ray2:m stair:on -> chords:gi visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <p> pedestal }| { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <m> Multiply}| { <t> Tri } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
–Step 3 - Add PR mult out and ramp for modulation
digraph structs {node [shape=record];{ ray2:t -> ray:p ray:t -> "Mult" -> doorway:s, stair:s doorway:k -> chords:ri chords:rgb -> visual:argb ray3:t -> ray2:m stair:on -> chords:gi visual:hpv -> "H+V Out" "H+V In" -> ray:m visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <m> Multiply | <p> pedestal }| { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <m> Multiply}| { <t> Tri } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 4 - Additional PR output to Color chords
digraph structs {node [shape=record];{ ray2:t -> ray:p ray:t -> "Mult" -> doorway:s, stair:s doorway:k -> chords:ri chords:rgb -> visual:argb ray3:t -> ray2:m stair:on -> chords:gi ray:si -> chords:bi visual:hpv -> "H+V Out" "H+V In" -> ray:m visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <m> Multiply | <p> pedestal }| { <t> Tri | <si> Sin } } } "]; ray2 [label="Prismatic\nRay2 |{ { <m> Multiply}| { <t> Tri } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
Patch 3 mixing oscillators before going into staircase/doorway
–Step 1 - combine oscillators via passage then view them each on different layers of color chords
digraph structs {node [shape=record];{ ray:t -> passage:tr ray2:t -> passage:ri passage:ro -> "Passage Out" "passage In" -> passage:tg ray3:t -> passage:gi passage:go -> "Mult" -> stair:s, doorway:s doorway:k -> chords:ri stair:on -> chords:gi chords:rgb -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2} } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <t> Tri } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
–Step 2 - Sync oscillators via ramps
digraph structs {node [shape=record];{ ray:t -> passage:tr ray2:t -> passage:ri passage:ro -> "Passage Out" "passage In" -> passage:tg ray3:t -> passage:gi passage:go -> "Mult" -> stair:s, doorway:s doorway:k -> chords:ri stair:on -> chords:gi visual:hpv -> "H+V Out" "H+V In" -> ray:sy chords:rgb -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; passage [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2 } } } "]; ray [label="Prismatic\nRay |{ { <sy> Sync }| { <t> Tri } } } "]; ray2 [label="Prismatic\nRay2 |{ { <t> Tri } } } "]; ray3 [label="Prismatic\nRay3 |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
Escher sketch 3 patches
Escher sketch 3 patches video
Patch 1 basic Escher sketch painting with memory palace
–Step 1 - basic paint patch with memory palace
digraph structs {node [shape=record];{ memory:rgb sketch:y -> memory:y sketch:x -> memory:x memory:rgb -> visual:argb visual:comvo -> "Main Output" sketch [label="Escher\nSketch |{ { <g> Gate }| { <x> X | <y> Y } } } "]; memory [label="Memory\nPalace |{ { <x> X | <y> Y }| { <rgb> RGB } }} "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
–Step 2 -
digraph structs {node [shape=record];{ memory:rgb sketch:y -> memory:y sketch:x -> memory:x sketch:p -> memory:z sketch:v -> memory:rot memory:rgb -> visual:argb visual:comvo -> "Main Output" sketch [label="Escher\nSketch |{ { <g> Gate }| { <x> X | <y> Y | <p> Prs | <v> Vel } } } "]; memory [label="Memory\nPalace |{ { <x> X | <y> Y | <z> Zoom | <rot> Rotation } | { <rgb> RGB }} "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Patch 2 More complex use for escher sketch and memory palace
–Step 1 - Using a still on memory palace along with the RGB inputs
digraph structs {node [shape=record];{ sketch:y -> memory:y sketch:x -> memory:x sketch:p -> memory:z sketch:v -> memory:h sketch:gb -> memory:gate stair:on -> chords:ri stair:tw -> chords:gi chords:rgb -> memory:rgbi visual:hpv -> "H+V Output" "H+V In" -> stair:s memory:rgb -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y | <p> Prs | <v> Vel | <gb> Gate 2} } } "]; memory [label="Memory\nPalace |{ { <rgbi> RGB | <x> X | <y> Y | <z> Zoom | <h> Hue | <gate> Gate} | { <rgb> RGB }} "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <tw> /2} } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 2 - Adding Escher Sketch
digraph structs {node [shape=record];{ sketch:p -> memory:rot sketch:y -> "Mult Y" -> memory:z, stair:f sketch:x -> "Mult X" -> memory:asp, stair:p stair:on -> chords:ri stair:tw -> chords:gi chords:rgb -> memory:rgbi visual:hpv -> "H+V Output" "H+V In" -> stair:s memory:rgb -> visual:argb visual:comvo -> "Main Output" chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; sketch [label="Escher\nSketch |{ { <g> Gate }| { <x> X | <y> Y | <p> Prs } } } "]; memory [label="Memory\nPalace |{ { <asp> Aspect | <rgbi> RGB | <z> Zoom | <rot> Rotation } | { <rgb> RGB }} "]; stair [label="Staircase |{ { <p> Phase | <s> Source | <f> Frequency }| { <on> /1 | <tw> /2} } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
Patch 3 More complex use for escher sketch and memory palace
–Step 1 - Using Escher sketch without a Memory palace
digraph structs {node [shape=record];{ "External Video Input" -> visual:comvi chords:rgb -> marble:bgrgb visual:hpv -> "H+V Output" visual:hmv -> "H-V Output" visual:rgb -> marble:brgb bridge:mo -> stair:s stair:on -> marble:ar stair:tw -> chords:ri stair:fo -> chords:gi pendulum:do -> stair:p ray:as -> bridge:mpa ray2:t -> bridge:mpb "H+V In" -> doorway:s "H-V In" -> "Mult H-V" -> ray2:m,pendulum:ai marble:rgb -> "RGB Output" "RGB In" -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <mpa> Mixer + | <mm> - | <mpb> + }| { <mo> Mixer } } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <as> Anti Sin} } } "]; ray2 [label="Prismatic\nRay2 |{ { <m> Multiply }| { <t> Tri } } } "]; marble [label="Marble\nIndex |{ { <brgb> B RGB | <bgrgb> BG RGB | <ar> A R }| { <rgb> RGB } } } "]; pendulum [label="Pendulum |{ { <ai> A--D }| { <do> D } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase}| { <tw> /2 | <fo> /4 | <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <hpv> H+V | <hmv> H-V | <comvo> Component | <rgb> Dec RGB } } } "]; }}
–Step 2 - Adding in Escher sketch
digraph structs {node [shape=record];{ "External Video Input" -> visual:comvi chords:rgb -> marble:bgrgb visual:hpv -> "H+V Output" visual:hmv -> "H-V Output" visual:rgb -> marble:brgb bridge:mo -> stair:s stair:on -> marble:ar doorway:k -> "Key Out" "Key In" -> bridge:fb ray:as -> bridge:mpa bridge:ao -> pendulum:cvc passage:ro -> bridge:mpb sketch:p -> bridge:fv sketch:x -> bridge:ai bridge:fo -> marble:ob bridge:ao -> doorway:t sketch:y -> passage:ri ray2:t -> passage:tr stair:tw -> chords:ri stair:fo -> chords:gi pendulum:do -> stair:p "H+V In" -> doorway:s "H-V In" -> "Mult H-V" -> ray2:m,pendulum:ai marble:rgb -> "RGB Output" "RGB In" -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <fb> B | <fv> VC | <ai> Mult A | <mpa> Mixer + | <mm> - | <mpb> + }| { <fo> Fader | <ao> A | <mo> Mixer} } } "]; chords [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgb> RGB } } } "]; doorway [label="Doorway|{ { <s> Source | <t> Threshold}| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <as> Anti Sin} } } "]; ray2 [label="Prismatic\nRay2 |{ { <m> Multiply }| { <t> Tri } } } "]; sketch [label="Escher\nSketch |{ { <p> Prs | <x> X | <y> Y } } } "]; marble [label="Marble\nIndex |{ { <brgb> B RGB | <ob> Opacity B | <bgrgb> BG RGB | <ar> A R }| { <rgb> RGB } } } "]; passage [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pendulum [label="Pendulum |{ { <cvc> Crossfade VC | <ai> A--D }| { <do> D } } } "]; stair [label="Staircase |{ { <p> Phase | <s> Source}| { <tw> /2 | <fo> /4 | <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <hpv> H+V | <hmv> H-V | <comvo> Component | <rgb> Dec RGB } } } "]; }}
Fortress 6 patches
Fortress 3 patches video 1 (patches 1-3)
Fortress 3 patches video 2 (patches 4-6)
Patch 1 Basics of Fortress oscillators
–Step 1 - Basic understanding of the oscillator outputs on fortress
digraph structs {node [shape=record];{ fort:h,fort:v,fort:lf -> "or" -> visual:br visual:comvo -> "Main Output" fort [label="Fortress |{ { <h> H | <v> V | <lf> LF} } "]; visual [label="Visual\nCortex |{ { <br> B R }| { <comvo> Component } } } "]; }}
H out looking at the B channel on the Visual cortex
switching through count setting
V out
LF not shown as it is at strobe rates and wouldn’t come through via a picture.
Patch 2 Using oscillators with other modules
–Step 1 - combining modules with fortress
digraph structs {node [shape=record];{ fort:ho -> pass:ri fort:vo -> pass:tr pass:ro -> pend:ai pend:ao -> "P LFO Out" "P LFO In" -> pend:cvc ray:t -> fort:hi fort:lfo -> "F LFO Out" "F LFO In" -> ray:p visual:hpv -> "H+V Out" "H+V In" -> fort:ri pend:do -> "Crossfade Out" "Crossfade In" -> fort:gi fort:rgbo -> visual:argb visual:comvo -> "Main Output" fort [label="Fortress |{ { <hi> VC H | <ri> ADC R | <gi> G } | { <ho> H | <vo> V | <lfo> LF | <rgbo> RGB } } "]; ray [label="Prismatic\nRay |{ { <p> Pedestal } | { <t> Tri } } } "]; pass [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pend [label="Pendulum |{ { <cvc> Crossfade VC | <ai> A--D }| { <ao> LFO A | <do> D } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
different mode
Patch 3 Combining the 3 ADC with external signals
–Step 1 - H+V to ADC 1
digraph structs {node [shape=record];{ visual:hpv -> fort:ri fort:rgbo -> "RGB Out" "RGB In" -> visual:argb visual:comvo -> "Main Output" fort [label="Fortress |{ { <ri> ADC R } | { <rgbo> RGB } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component } } } "]; }}
–Step 2 - adding staircase modulation
digraph structs {node [shape=record];{ visual:hpv -> fort:ri visual:h -> stair:s stair:tw -> fort:gi fort:rgbo -> "RGB Output" "RGB In" -> visual:argb visual:comvo -> "Main Output" fort [label="Fortress |{ { <ri> ADC R | <gi> G} | { <rgbo> RGB } } "]; stair [label="Staircase |{ { <s> Source }| { <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <h> H | <comvo> Component } } } "]; }}
shift register mode
cellular autonoma
Linear feedback shift register
–Step 3 - filling the last ADC
digraph structs {node [shape=record];{ visual:hpv -> "Mult" -> fort:ri,pass:tr visual:h -> stair:s stair:tw -> fort:gi pass:ro -> fort:bi ray:t -> pass:ri fort:rgbo -> "RGB Output" "RGB In" -> visual:argb visual:comvo -> "Main Output" fort [label="Fortress |{ { <bi> ADC B | <ri> R | <gi> G } | { <rgbo> RGB } } "]; pass[label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <tw> /2 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <h> H | <comvo> Component } } } "]; }}
Patch 4 External video into fortress
–Step 1 - Basic colorizer
digraph structs {node [shape=record];{ marble:rgb -> "RGB Output" "RGB In" -> visual:argb visual:y -> bridge:bi fort:rgbo -> marble:argb bridge:bo -> fort:ri "External video In" -> visual:comvi visual:comvo -> "Main Output" bridge [label="Bridge |{ { <bi> Mult B }| { <bo> B } } } "]; fort [label="Fortress |{ { <ri> ADC R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
RGB shift register mode
feedback shift register mode
cellular autonoma mode
–Step 2 - Processing 2nd mult with additional ADC
digraph structs {node [shape=record];{ marble:rgb -> "RGB Output" "RGB In" -> visual:argb visual:y -> bridge:bi fort:rgbo -> marble:argb bridge:bo -> fort:ri bridge:bo -> pass:tr pend:ao -> pass:ri pass:ro -> fort:hi pend:bo -> pass:gi pass:go -> fort:bi "External video In" -> visual:comvi visual:comvo -> "Main Output" bridge [label="Bridge |{ { <bi> Mult B }| { <bo> B } } } "]; fort [label="Fortress |{ { <hi> VC H | <bi> ADC B | <ri> R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 } | { <ro> Out 1 | <go> 2 } } } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> B } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
–Step 3 - Adding a key to opacity
digraph structs {node [shape=record];{ marble:rgb -> "RGB Output" "RGB In" -> visual:argb visual:y -> bridge:bi fort:rgbo -> marble:argb bridge:bo -> fort:ri bridge:bo -> pass:tr pend:ao -> pass:ri pass:ro -> fort:hi bridge:bo -> door:s door:k -> marble:ob pend:bo -> pass:gi pass:go -> fort:bi "External video In" -> visual:comvi visual:comvo -> "Main Output" bridge [label="Bridge |{ { <bi> Mult B }| { <bo> B } } } "]; door [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; fort [label="Fortress |{ { <hi> VC H | <bi> ADC B | <ri> R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <ob> opacity B}| { <rgb> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 } | { <ro> Out 1 | <go> 2 } } } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> B } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
Patch 5 Adjusting the RGB output of fortress
–Step 1 - Setting up the basic patch
digraph structs {node [shape=record];{ fort:rgbo -> marble:argb visual:y -> "Y Output" "Y In" -> fort:ri marble:rgb -> "RGB Output" "RGB In" -> visual:argb "External video In" -> visual:comvi visual:comvo -> "Main Output" fort [label="Fortress |{ { <ri> ADC R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
–Step 2 - RGB color picking with color chords
digraph structs {node [shape=record];{ fort:rgbo -> chord:rgbi chord:rgbo -> marble:argb visual:y -> "Y Output" "Y In" -> fort:ri marble:rgb -> "RGB Output" "RGB In" -> visual:argb "External video In" -> visual:comvi visual:comvo -> "Main Output" chord [label="Color\nChords|{ { <rgbi> RGB }| { <rgbo> RGB } } } "]; fort [label="Fortress |{ { <ri> R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <br> B R | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
using different areas on the XY pad of escher sketch as color presets
digraph structs {node [shape=record];{ fort:rgbo -> pass:trgb pass:rgbo -> chord:rgbi chord:rgbo -> marble:argb visual:y -> "Y Output" "Y In" -> fort:ri sketch:x -> pass:ri sketch:y -> pass:gi sketch:p -> pass:bi marble:rgb -> "RGB Output" "RGB In" -> visual:argb "External video In" -> visual:comvi visual:comvo -> "Main Output" chord [label="Color\nChords|{ { <rgbi> RGB }| { <rgbo> RGB } } } "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y | <p> Prs } } } "]; fort [label="Fortress |{ { <ri> R } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB }| { <rgb> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <trgb> Thru 123 } | { <rgbo> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y } } } "]; }}
–Step 4 - Fortress DAC as a key for MI opacity, additional color input
digraph structs {node [shape=record];{ fort:rgbo -> pass:trgb pass:rgbo -> chord:rgbi chord:rgbo -> marble:argb visual:y -> "Y Output" "Y In" -> fort:ri sketch:x -> pass:ri sketch:y -> pass:gi sketch:p -> pass:bi visual:hpv -> "H+V Out" "H+V In" -> fort:gi fort:dac -> marble:ob marble:rgb -> "RGB Output" "RGB In" -> visual:argb "External video In" -> visual:comvi visual:comvo -> "Main Output" chord [label="Color\nChords|{ { <rgbi> RGB }| { <rgbo> RGB } } } "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y | <p> Prs } } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G } | { <rgbo> RGB | <dac> DAC} } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <ob> opacity B}| { <rgb> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <trgb> Thru 123 } | { <rgbo> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <hpv> H+V | <comvo> Component | <y> Y } } } "]; }}
Patch 6 Complex fortress colorizer
digraph structs {node [shape=record];{ visual:drgb -> fort:rgbi fort:ho -> chord:ri fort:vo -> chord:gi visual:y -> fort:hi fort:dac -> chord:bi fort:lfo -> marble:ob fort:rgbo -> marble:argb chord:rgbo -> marble:brgb marble:rgb -> "RGB Output" "RGB In" -> visual:argb "External video In" -> visual:comvi visual:comvo -> "Main Output" chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; fort [label="Fortress |{ { <hi> H | <rgbi> ADC RGB } | { <ho> H | <vo> V | <dac> DAC | <rgbo> RGB | <lfo> LFO} } "]; marble [label="Marble\nIndex |{ { <brgb> B RGB | <argb> A RGB | <ob> opacity B}| { <rgb> RGB } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <comvo> Component | <y> Y | <drgb> Dec RGB} } } "]; }}
Diver 3 patches
Diver 3 patches video
Patch 1 Using diver as a ramp generator
digraph structs {node [shape=record];{ diver:hpv -> stair:s ray:t -> diver:hp stair:on -> visual:ar visual:vo -> "V Out" "V In" -> diver:w visual:comvo -> "Main Output" diver [label="Diver |{ { <hp> H Phase | <w> Wave } | { <hpv> H+V } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source}| { <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <ar> A R }| { <comvo> Component | <vo> V } } } "]; }}
Patch 2 Audio -> 2d ramp
Step 1 Setting up your basic shape
digraph structs {node [shape=record];{ diver:hpv -> door:s diver:hmv -> stair:s diver:vo -> stair:p diver:ho -> door:t door:k -> visual:ar stair:on -> visual:ag stair:fo -> visual:ab ray:t -> diver:w visual:vo -> "V Out" "V In" -> diver:hp visual:comvo -> "Main Output" diver [label="Diver |{ { <w> Wave } | { <ho> H | <hpv> H+V | <hmv> H-V | <vo> V } } "]; door [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase}| { <on> /1 | <fo> /4 } } } "]; visual [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component } } } "]; }}
withouth V ramp from VC
with V ramp from VC
Patch 3 Using external audio into diver
Step 1 Sample using wave input (audio input mode)
digraph structs {node [shape=record];{ diver:hpv -> fort:ri fort:rgbo -> visual:argb "External audio in" -> diver:w ray:t -> diver:hi visual:comvo -> "Main Output" diver [label="Diver |{ { <hi> H | <w> Wave } | { <hpv> H+V } } "]; fort [label="Fortress |{ { <ri> ADC R } | { <rgbo> RGB } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Orion series 3 patches
Orion series 3 patches video
Patch 1 Basic orion
digraph structs {node [shape=record];{ diver:hpv -> fort:ri diver:hmv -> mem:ai fort:rgbo -> marble:argb mem:rgbo -> marble:brgb mem:y -> bridge:bi pend:ao -> stair:s pend:bo -> diver:w stair:fo -> mem:h stair:tw -> diver:hp stair:on -> diver:vp bridge:bo -> fort:gi bridge:bo -> marble:oa bridge:bo -> marble:ob visual:y -> "Y Out" "Y In" -> mem:ri marble:rgbo -> visual:argb "External Composite in" -> visual:comvi visual:comvo -> "Main Output" bridge [label="Bridge |{ { <bi> Mult B }| { <bo> B } } } "]; diver [label="Diver |{ { <hp> H | <vp> V | <w> Wave } | { <hpv> H+V | <hmv> H-V } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <oa> Opacity A | <ob> Opacity B | <brgb> B RGB }| { <rgbo> RGB } } } "]; mem [label="Memory\nPalace |{ { <ai> A | <ri> R | <h> Hue } | { <y> Y | <rgbo> RGB } } }} "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; stair [label="Staircase |{ { <s> Source }| { <tw> /2 | <on> /1 | <fo> /4 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite In }| { <y> Y | <comvo> Component } } } "]; }}
Patch 2 Another base patch
digraph structs {node [shape=record];{ diver:hpv -> stair:s diver:hmv -> marble:oa diver:ho -> marble:ob fort:dac -> stair:f mem:y -> stair:p sketch:x -> bridge:ai sketch:y -> bridge:bi bridge:ao -> Mult_A -> mem:z,diver:hp,fort:hi [color=purple] bridge:bo -> Mult_B -> mem:asp,diver:vp,fort:vi [color=pink] fort:rgbo -> mem:rgbi stair:rgbo -> marble:argb mem:rgbo -> marble:brgb marble:rgbo -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B }| { <ao> A | <bo> B } } } "]; diver [label="Diver |{ { <hp> H | <vp> V } | { <hmv> H-V | <ho> H | <hpv> H+V } } "]; fort [label="Fortress |{ { <hi> Phase H | <vi> V } | { <dac> DAC | <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <oa> Opacity A | <ob> Opacity B | <argb> A RGB | <brgb> B RGB }| { <rgbo> RGB } } } "]; mem [label="Memory\nPalace |{ { <rgbi> RGB | <z> Zoom | <asp> Apect} | { <y> Y | <rgbo> RGB } } }} "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y } } } "]; stair [label="Staircase |{ { <s> Source | <f> Frequency | <p> Phase}| { <rgbo> /1,2,4 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Patch 3 MP Paint based
digraph structs {node [shape=record];{ visual:v -> "V Out" [color=green] "V In" -> stair:s [color=green] visual:hpv -> "H+V Out" [color=blue] "H+V In" -> pass:ri [color=blue] diver:hpv -> pass:gi pend:ao -> pass:tg pend:bo -> pass:tb pend:co -> pass:tr pend:do -> mem:h pass:ro -> fort:ri pass:go -> fort:gi pass:bo -> mem:ai fort:dac -> marble:oa mem:y -> "Y Mult"-> marble:ob,marble:ar stair:tw -> diver:w stair:on -> "/1 Out" [color=gray] "/1 In" -> fort:hi [color=gray] sketch:x -> bridge:ai sketch:y -> bridge:bi bridge:ao -> Mult_A -> stair:f,"X Out" [color=purple] bridge:bo -> Mult_B -> stair:p,"Y Out" [color=pink] "X In 2" -> fort:bi[color=purple] "X In 1" -> mem:xi[color=purple] "Y In" -> mem:yi[color=pink] fort:rgbo -> mem:rgbi mem:rgbo -> marble:brgb marble:rgbo -> visual:argb visual:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B }| { <ao> A | <bo> B } } } "]; diver [label="Diver |{ { <w> Wave} | { <hpv> H+V } } "]; fort [label="Fortress |{ { <hi> Phase H | <bi> ADC B | <ri> R| <gi> G } | { <dac> DAC | <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <oa> Opacity A | <ar> A R | <ob> Opacity B | <brgb> B RGB }| { <rgbo> RGB } } } "]; mem [label="Memory\nPalace |{ { <rgbi> RGB | <ai> A | <h> Hue | <xi> X | <yi> Y} | { <y> Y | <rgbo> RGB } } }} "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pend [label="Pendulum |{ { <co> C | <ao> LFO A | <bo> LFO B | <do> D } } } "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y } } } "]; stair [label="Staircase |{ { <f> Frequency | <s> Source | <p> Phase}| { <tw> /2 | <on> /1 } } } "]; visual [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component | <v> V} } } "]; }}
Navigator 3 patches
Navigator 3 patches video
Patch 1 Basic shape creation
digraph structs {node [shape=record];{ vis:ho -> "H Out" "H In" -> nav:hi vis:vo -> "V Out" "V In" -> nav:vi nav:ho -> pass:ri nav:vo -> pass:tr pass:ro -> stair:s stair:tw -> door:s door:k -> vis:ar ray:t -> nav:x pend:ao -> nav:y vis:comvo -> "Main Output" door [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; nav [label="Navigator |{ { <hi> H | <vi> V | <x> X | <y> Y }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pend [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source }| { <tw> /2 } } } "]; vis [label="Visual\nCortex |{ { <ar> A R }| { <ho> H | <vo> V | <comvo> Component } } } "]; }}
Patch 2 More complex shape creation
digraph structs {node [shape=record];{ vis:ho -> "H Out" "H In" -> pass:tr vis:vo -> "V Out" "V In" -> pass:tg pass:ro -> bridge:ai pass:go -> bridge:bi bridge:ao -> nav:hi bridge:bo -> nav:vi bridge:ao -> chord:gi bridge:bo -> chord:bi pass:bo -> stair:s pend:ao -> pass:ri pend:bo -> pass:gi ray:t -> nav:x stair:on -> nav:y nav:ho -> door:t nav:vo -> door:s door:k -> chord:ri chord:rgb -> vis:argb vis:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B }| { <ao> A | <bo> B } } } "]; chord [label="Color\nChords|{ { <gi> G | <bi> B | <ri> R }| { <rgbo> RGB } } } "]; door [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; nav [label="Navigator |{ { <hi> H | <vi> V | <x> X | <y> Y }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <ho> H | <vo> V | <comvo> Component } } } "]; }}
Step 2 Using the key we just setup
digraph structs {node [shape=record];{ vis:ho -> "H Out" "H In" -> pass:tr vis:vo -> "V Out" "V In" -> pass:tg pass:ro -> bridge:ai pass:go -> bridge:bi bridge:ao -> nav:hi bridge:bo -> nav:vi bridge:ao -> fort:ri bridge:bo -> fort:gi fort:rgbo -> marble:argb pass:bo -> stair:s pend:ao -> pass:ri pend:bo -> pass:gi ray:t -> nav:x stair:on -> nav:y nav:ho -> door:t nav:vo -> door:s door:k -> marble:ob marble:rgb -> vis:argb vis:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A | <bi> Mult B }| { <ao> A | <bo> B } } } "]; door [label="Doorway|{ { <t> Threshold | <s> Source }| { <k> Key } } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G } | { <rgbo> RGB } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <ob> Opacity B }| { <rgbo> RGB } } } "]; nav [label="Navigator |{ { <hi> H | <vi> V | <x> X | <y> Y }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <bi> 3 | <tr> Thru 1 | <tg> 2 | <tb> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <ho> H | <vo> V | <comvo> Component } } } "]; }}
Patch 3 Using Diver for more complex H,V ramps to process
digraph structs {node [shape=record];{ diver:ho -> nav:hi diver:vo -> nav:vi nav:ho -> chord:ri nav:vo -> chord:gi chord:ro -> door:s door:k -> pass:ri pass:rgbo -> marble:argb chord:go -> stair:s stair:on -> marble:oa ray:t -> chord:bi pend:ao -> nav:x pend:bo -> nav:y marble:rgbo -> vis:argb vis:comvo -> "Main Output" chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <ro> R | <go> G | <bo> B} } } "]; diver [label="Diver |{ { <ho> H | <vo> V } } "]; door [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; marble [label="Marble\nIndex |{ { <argb> A RGB | <oa> Opacity A }| { <rgbo> RGB } } } "]; nav [label="Navigator |{ { <hi> H | <vi> V | <x> X | <y> Y }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 } | { <rgbo> RGB }} } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Shapechanger 3 patches
Shapechanger 3 patches video
Patch 1 Taking several outs from shapechanger
digraph structs {node [shape=record];{ vis:ho -> "H Out" "H In" -> nav:hi vis:vo -> "V Out" "V In" -> nav:vi nav:ho -> shape:hi nav:vo -> shape:vi chord:rgbo -> vis:argb shape:st -> bridge:mpa shape:g -> bridge:bi bridge:bo -> "Grad Out" "Grad In" -> bridge:mm bridge:bo -> pass:tr pend:ao -> pass:ri pass:ro -> chord:bi shape:ho -> door:s shape:vo -> door:t bridge:mo -> stair:s stair:on -> chord:ri door:k -> chord:gi vis:comvo -> "Main Output" bridge [label="Bridge |{ { | <mpa> Mixer + | <bi> Mult B | <mm> Mixer - }| { <bo> B | <mo> Mixer} } } "]; chord [label="Color\nChords|{ { <gi> G | <bi> B | <ri> R }| { <rgbo> RGB} } } "]; door [label="Doorway|{ { <s> Source | <t> Threshold}| { <k> Key } } } "]; nav [label="Navigator |{ { <hi> H | <vi> V }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 | <tr> Thru 1 } | { <ro> Out 1 } } } "]; pend [label="Pendulum |{ { <ao> LFO A } } } "]; shape [label="Shapechanger |{ { <hi> H | <vi> V }| { <ho> H | <vo> V | <st> Stencil | <g> Gradient } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1} } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <ho> H | <vo> V | <comvo> Component } } } "]; }}
Patch 2 Shapechanger -> navigator
digraph structs {node [shape=record];{ diver:ho -> shape:hi diver:vo -> shape:vi ray:t -> shape:sk shape:ho -> nav:hi shape:vo -> nav:vi shape:g -> fort:gi nav:ho -> pass:ri nav:vo -> pass:tr pass:ro -> "R Out" "R In" -> pass:tg pass:go -> fort:ri pend:ao -> "LFO Out" "LFO In" -> pass:gi pend:co -> shape:c pend:do -> shape:si fort:rgbo -> vis:argb vis:comvo -> "Main Output" diver [label="Diver |{ { <ho> H | <vo> V } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G | <bi> B} | { <rgbo> RGB } } "]; nav [label="Navigator |{ { <hi> H | <vi> V }| { <ho> H | <vo> V } } } "]; pass [label="Passage |{ { <gi> 2 | <ri> In 1 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2 } } } "]; pend [label="Pendulum |{ { <ao> LFO A | <co> C | <do> D } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; shape [label="Shapechanger |{ { <hi> H | <vi> V | <c> Curve | <si> Size | <sk> Skew }| { <ho> H | <vo> V | <g> Gradient } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Patch 3 Shapechanger processing external video
digraph structs {node [shape=record];{ vis:y -> shape:hi vis:vo -> pass:tr pass:ro -> "R Out" "R In" -> pass:tg ray:t -> pass:gi pass:go -> shape:vi pend:ao -> pass:ri shape:g -> stair:s stair:on -> chord:ri shape:ho -> chord:gi vis:hpv -> chord:bi chord:rgbo -> "RGB Out" "RGB In" -> vis:argb "External Video" -> vis:comvi vis:comvo -> "Main Output" chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tg> Thru 2 | <tr> 1 } | { <ro> Out 1 | <go> 2 } } } "]; pend [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; shape [label="Shapechanger |{ { <vi> V | <hi> H }| { <g> Gradient | <ho> H } } } "]; stair [label="Staircase |{ { <s> Source }| { <tw> /2 |<on> /1} } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite }| { <vo> V | <y> Y | <hpv> H+V | <comvo> Component } } } "]; }}
Sensory Translator 3 patches
Sensory Translator 3 patches video
Patch 1 Sensory translator into Memory palace
digraph structs {node [shape=record];{ diver:ho -> nav:hi diver:vo -> nav:vi nav:ho -> shape:hi nav:vo -> shape:vi shape:g -> fort:ri sens:b -> nav:rot sens:c -> shape:r sens:d -> shape:sk sens:e -> diver:hp sens:640 -> diver:w fort:rgbo -> vis:argb vis:comvo -> "Main Output" diver [label="Diver |{ { <w> Wave | <hp> H Phase } | { <ho> H | <vo> V } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G | <bi> B} | { <rgbo> RGB } } "]; nav [label="Navigator |{ { <hi> H | <vi> V | <rot> Rotation }| { <ho> H | <vo> V } } } "]; shape [label="Shapechanger |{ { <hi> H | <vi> V | <r> Ratio | <sk> Skew }| { <g> Gradient } } } "]; sens [label="Sensory\nTranslator|{ { <audio> Audio}| { <640> 640 | <e> E | <b> B | <c> C | <d> D } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component} } } "]; }}
Patch 2 Using all the Sensory translator envelope outputs
digraph structs {node [shape=record];{ mem:rgbo -> vis:argb fort:rgbo -> mem:rgbi sens:a -> mem:z sens:b -> mem:cen sens:c -> mem:h sens:d -> pend:ai pend:ao -> "LFO Out" "LFO In" -> pend:cvc sens:e -> mem:g pend:do -> mem:asp vis:comvo -> "Main Output" fort [label="Fortress |{ { <rgbo> RGB } } "]; mem [label="Memory\nPalace |{ { <rgbi> RGB | <z> Zoom | <g> Gate | <cen> Center | <h> Hue | <asp> Aspect} | { <rgbo> RGB } }} "]; pend [label="Pendulum |{ { <ai> A--D | <cvc> Crossfade VC }| { <do> D | <ao> LFO A } } } "]; sens [label="Sensory\nTranslator|{ { <audio> Audio}| { <a> A | <e> E | <b> B | <c> C | <d> D } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component} } } "]; }}
Patch 3 External video into Sensory translator
digraph structs {node [shape=record];{ vis:dy -> bridge:bi bridge:ao -> pend:ai sens:10 -> nav:hi sens:6 -> nav:vi nav:ho -> fort:ri nav:vo -> fort:gi bridge:ao -> fort:bi fort:rgbo -> "RGB Out" "RGB In" -> vis:argb pend:ao -> "LFO Out" "LFO In" -> pend:cvc pend:do -> sens:ai "External video" -> vis:comvi vis:comvo -> "Main Output" bridge [label="Bridge |{ { <ai> Mult A }| { <ao> A } } } "]; fort [label="Fortress |{ { <ri> ADC R | <gi> G | <bi> B } | { <rgbo> RGB } } "]; nav [label="Navigator |{ { <hi> H | <vi> V }| { <ho> H | <vo> V } } } "]; pend [label="Pendulum |{ { <cvc> Crossfade VC | <ai> A--D }| { <ao> LFO A | <do> D } } } "]; sens [label="Sensory\nTranslator|{ { <ai> Audio}| {<10> 10240 | <6> 640 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Component }| { <dy> Dec Y | <comvo> Component} } } "]; }}
Topogram 3 patches
Topogram 3 patches video
Patch 1 Basic topogram use
digraph structs {node [shape=record];{ vis:hpv -> top:s pend:ao -> top:l ray:si -> top:u top:fa -> chord2:ri top:ma -> chord2:gi top:mb -> chord2:bi top:mc -> chord:ri top:md -> chord:gi top:re -> chord:bi top:t -> "Thru Out" "Thru In"-> top:g chord:rgbo -> chord2:brgb chord2:rgbo -> "RGB Out" "RGB In" -> vis:argb vis:comvo -> "Main Output" chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; chord2 [label="Color\nChords2|{ { <ri> R | <gi> G | <bi> B | <brgb> BG RGB }| { <rgbo> RGB } } } "]; pend [label="Pendulum |{ { <ao> LFO A } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; top [label="Topogram |{ { <s> Source | <g> Gain | <l> Lower | <u> Upper } | { <t> Thru | <fa> Pos 1 | <ma> Min A | <mb> B | <mc> C | <md> D | <re> 5 } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component | <hpv> H+V } } } "]; }}
Patch 2 Processing CV rate signals with topogram
“4 module patch” haha…
digraph structs {node [shape=record];{ diver:ho -> nav:hi diver:vo -> nav:vi nav:ho -> shape:hi nav:vo -> shape:vi shape:g -> stair:s pend:ao -> top:s pend:bo -> top:g top:pa -> nav:r top:pc -> nav:y top:pd -> diver:vp top:pe -> stair:p top:mb -> shape:r top:md -> shape:c top:nb -> nav:x top:nc -> diver:w ray:si -> top:l stair:on -> "RGB Out" "RGB In" -> vis:argb vis:comvo -> "Main Output" diver [label="Diver |{ { <w> Wave | <vp> V Phase } | { <ho> H | <vo> V } } "]; nav [label="Navigator |{ { <r> Rotation | <hi> H | <vi> V | <x> X | <y> Y }| { <ho> H | <vo> V } } } "]; pend [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <si> Sin } } } "]; shape [label="Shapechanger |{ { <hi> H | <vi> V | <r> Ratio | <c> Curve }| { <g> Gradient } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase}| { <on> /1 } } } "]; top [label="Topogram |{ { <s> Source | <g> Gain | <l> Lower } | { <pa> Pos 1 | <nc> Neg 3 | <pd> Pos 4 | <nb> NEG 2 | <pc> Pos 3 | <mb> MIN B | <md> MIN D | <pe> Pos 5 } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component | <hpv> H+V } } } "]; }}
Patch 3 6 band external video colorizer
digraph structs {node [shape=record];{ vis:y -> top:s top:fa -> chord2:ri top:ma -> chord2:gi top:mb -> chord2:bi top:mc -> chord:ri top:md -> chord:gi top:re -> chord:bi chord:rgbo -> chord2:brgb chord2:rgbo -> "RGB Out" "RGB In" -> vis:argb "Composite In" -> vis:comvi vis:comvo -> "Main Output" chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; chord2 [label="Color\nChords2|{ { <ri> R | <gi> G | <bi> B | <brgb> BG RGB }| { <rgbo> RGB } } } "]; top [label="Topogram |{ { <s> Source } | { <pa> Pos 1 | <ma> Min A | <mb> B | <mc> C | <md> D | <ne> 5 } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <comvi> Composite }| { <y> Y | <comvo> Component } } } "]; }}
Polar Fringe 3 patches
Polar fringe 3 patches video
Patch 1 Basic use
digraph structs {node [shape=record];{ mem:rgbo,fort:rgbo -> "Or" -> pol:rgbi pol:rgbo -> vis:argb pol:n -> vis:k dive:hpv -> pol:y ray:t -> pol:d vis:comvo -> "Main Output" dive [label="Diver |{ { <hpv> H+V } } "]; fort [label="Fortress |{ { <rgbo> RGB } } "]; mem [label="Memory\nPalace |{ { <rgbo> RGB } }} "]; pol [label="Polar\nFringe |{ { <rgbi> RGB | <d> Diameter | <y> Y } | { <rgbo> RGB | <n> Neg Key} } "] ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <k> Key }| { <comvo> Component | <hpv> H+V } } } "]; }}
Memory palace
Fortress
Patch 2 Polar fringe as a shape generator
digraph structs {node [shape=record];{ for:rgbo -> pol:rgbi pol:rgbo -> vis:argb pol:n -> vis:k pol:p -> "POS Key Out" "POS Key In" -> for:bi dive:hmv -> door:s door:k -> pol:y ray:t -> pass:tr dive:vo -> pass:tg pen:ao -> pass:ri pen:bo -> pass:gi pass:ro -> arc:ai pass:go -> arc:bi dive:hpv -> stair:s arc:x -> "XOR Out" "XOR In" -> arc:r arc:m -> for:ri arc:a -> for:gi arc:c -> pol:d stair:on -> vis:br stair:fo -> vis:bg vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B | <r> Rectifier }| { <m> Mirror | <a> AND | <c> Clip | <x> XOR } } } "]; door [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; dive [label="Diver |{ { <vo> V | <hmv> H-V | <hpv> H+V } } "]; for [label="Fortress |{ { <bi> ADC B | <ri> R | <gi> G } | { <rgbo> RGB } } "]; pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B} } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2} | { <ro> Out 1 | <go> 2 } } } "]; pol [label="Polar\nFringe |{ { <rgbi> RGB | <d> Diameter | <y> Y } | { <p> Pos Key | <rgbo> RGB | <n> Neg Key} } "] ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 | <fo> /4 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <k> Key | <br> B R | <bg> G }| { <comvo> Component | <hpv> H+V } } } "]; }}
Patch 3 Combining ramps and other sources with Polar fringe
digraph structs {node [shape=record];{ dive:ho -> pol:ri ray:t -> pass:tr pen:do -> pass:ri pass:ro -> pol:gi dive:vo -> pol:bi pol:p -> stair:s pol:n -> door:s stair:on -> for:ri door:k -> for:gi pen:ao -> pol:x pen:bo -> pol:y pol:bo -> for:bi for:rgbo -> vis:argb vis:comvo -> "Main Output" door [label="Doorway|{ { <s> Source }| { <k> Key } } } "]; dive [label="Diver |{ { <ho> H | <vo> V } } "]; for [label="Fortress |{ { <ri> ADC R | <gi> G | <bi> B } | { <rgbo> RGB } } "]; pen [label="Pendulum |{ { <do> D | <ao> LFO A | <bo> LFO B} } } "]; pass [label="Passage |{ { <tr> Thru 1 | <ri> In 1} | { <ro> Out 1 } } } "]; pol [label="Polar\nFringe |{ { <gi> G | <ri> R | <bi> B | <x> X | <y> Y } | { <p> Pos Key | <n> Neg Key | <bo> B } } "] ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Arch 3 patches
Arch 3 patches video
Patch 1 Square based pattern generator with background
digraph structs {node [shape=record];{ dive:ho -> pass:tr dive:vo -> pass:tg pen:ao -> arc:r arc:s -> "Square Out" "Square In" -> pass:gi arc:i -> "Intersection Out" "Intersection In" -> arc:g arc:m -> "Mirror Out" "Mirror In" -> pass:ri top:pc -> chord:ri arc:d -> bridge:mpa arc:li -> bridge:mm bridge:mo -> stair:s stair:on -> chord:gi pass:ro -> arc:ai pass:go -> arc:bi arc:o -> top:s chord:rgbo -> vis:argb vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B | <r> Rectifier | <g> Gamma}| { <i> Intersection | <s> Square | <m> Mirror | <o> OR | <d> Darks | <li> Lights} } } "]; bridge [label="Bridge |{ { <mpa> Mixer + | <mm> - }| { <mo> Mixer} } } "]; chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; dive [label="Diver |{ { <ho> H | <vo> V } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2 } } } "]; pen [label="Pendulum |{ { <ao> LFO A } } } "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; top [label="Topogram |{ { <s> Source } | { <pc> Pos 3 } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Patch 2 More complex shape generator
digraph structs {node [shape=record];{ ray:t -> arc:ai dive:vo -> stair:s stair:on -> "Stair Out" "Stair In" -> arc:bi arc:x -> "XOR Out" "XOR In" -> arc:r dive:hpv -> arc:g arc:s -> pen:ai arc:l -> pen:bi pen:do -> chord:bi pen:ao -> "LFO A Out" "LFO A In" -> pen:cvc pen:bo -> "LFO B Out" "LFO B In" -> stair:p arc:d -> bridge:mpa arc:li -> bridge:mpb bridge:mo -> chord:ri arc:m -> chord:gi chord:rgbo -> vis:argb vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B | <r> Rectifier | <g> Gamma}| { <s> Square | <l> Log | <x> XOR | <m> Mirror | <d> Darks | <li> Lights} } } "]; bridge [label="Bridge |{ { <mpa> Mixer + | <mm> - | <mpb> +}| { <mo> Mixer} } } "]; chord [label="Color\nChords|{ { <bi> B | <gi> G | <ri> R }| { <rgbo> RGB } } } "]; dive [label="Diver |{ { <hpv> H+V | <vo> V } } "]; pen [label="Pendulum |{ { <cvc> Crossfade VC | <ai> A--D | <bi> B--C }| { <ao> LFO A | <bo> LFO B | <do> D } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; stair [label="Staircase |{ { <s> Source | <p> Phase}| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Patch 3 Arch based colorizer
digraph structs {node [shape=record];{ mem:yo -> arc:g arc:s -> "Square Out" "Square In" -> arc:ai arc:i -> "Intersection Out" "Intersection In" -> arc:r arc:x -> chord:ri arc:m -> chord:gi arc:c -> chord:bi arc:l -> "Log Out" "Log In" -> arc:bi chord:rgbo -> vis:argb vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B | <r> Rectifier | <g> Gamma}| { <x> XOR | <m> Mirror | <c> Clip | <i> Intersection | <s> Square | <l> Log } } } "]; chord [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; mem [label="Memory\nPalace |{ {<yo> Y } }} "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <comvo> Component } } } "]; }}
Curtain 3 patches
Curtain 3 patches video
Patch 1 Basic use
digraph structs {node [shape=record];{ vis:hpv -> curt:fi dive:vo -> curt:w curt:mo -> top:s top:ma -> "R Out" top:mb -> "G Out" top:mc -> "B Out" "R In" -> vis:ar "G In" -> vis:ag "B In" -> vis:ab vis:comvo -> "Main Output" curt [label="Curtain |{ { <fi> Filter | <w> Width }| { <mo> Mix } } } "]; dive [label="Diver |{ { <vo> V } } "]; top [label="Topogram |{ { <s> Source } | { <ma> Min A | <mb> B | <mc> C } } "]; vis [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component | <hpv> H+V } } } "]; }}
Patch 2 More complex pattern generator
digraph structs {node [shape=record];{ dive:ho -> curt:m fort:ho -> curt:f vis:hpv -> "H+V Out" "H+V In" -> curt:w curt:fo -> arc:ai curt:mo -> arc:bi arc:a -> "R Out" "R In" -> fort:ri fort:rgbo -> vis:argb vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B }| { <a> AND } } } "]; curt [label="Curtain |{ { <f> Filter | <m> Mix | <w> Width }| { <fo> Filter | <mo> Mix } } } "]; dive [label="Diver |{ { <ho> H } } "]; fort [label="Fortress |{ { <ri> ADC R } | { <rgbo> RGB | <ho> H } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component} } } "]; }}
Patch 3 External images into Curtain
digraph structs {node [shape=record];{ mem:y -> bridge:ai bridge:ao -> arc:ai curt:fo -> arc:bi bridge:ao -> curt:f dive:hpv -> stair:s stair:on -> curt:w arc:a -> vis:col vis:comvo -> "Main Output" arc [label="Arch|{ { <ai> Logic A | <bi> B }| { <a> AND } } } "]; bridge [label="Bridge |{ { <ai> Mult A }| { <ao> A } } } "]; curt [label="Curtain |{ { <f> Filter | <w> Width }| { <fo> Filter } } } "]; dive [label="Diver |{ { <hpv> H+V } } "]; mem [label="Memory\nPalace |{ { <y> Y } }} "]; stair [label="Staircase |{ { <s> Source }| { <on> /1 } } } "]; vis [label="Visual\nCortex |{ { <col> Colorize }| { <comvo> Component } } } "]; }}
Mapper 3 patches
Mapper 3 patches video
Patch 1 Basic colorizer
digraph structs {node [shape=record];{ vis:hpv -> top:s vis:vo -> map:s top:pc -> map:h dive:hpv -> map:y map:yuvo -> "YUV Out" "YUV In" -> vis:brgb map:rgbo -> "RGB Out" "RGB In" -> vis:argb vis:comvo -> "Main Output" dive [label="Diver |{ { <hpv> H+V } } "]; map [label="Mapper|{ { <s> Saturation | <h> Hue | <y> Y Brightness}| { <yuvo> YUV | <rgbo> RGB } } } "]; top [label="Topogram |{ { <s> Source} | { <pc> Pos 3 } } "]; vis [label="Visual\nCortex |{ { <argb> A RGB | <brgb> B RGB }| { <vo> V | <hpv> H+V | <comvo> Component} } } "]; }}
Patch 2 More complex colorizer
digraph structs {node [shape=record];{ dive:hpv -> pass:ri vis:hpv -> pol:ri pol:p -> "Pos Key Out" "Pos Key In" -> pass:gi pol:n -> "Neg Key Out" "Neg Key In" -> map:y pass:ro -> bridge:mpa pass:go -> bridge:mpb bridge:mo -> map:h map:rgbo -> vis:argb vis:comvo -> "Main Output" bridge [label="Bridge |{ { <mpa> Mixer + | <mm> - | <mpb> + }| { <mo> Mixer} } } "]; dive [label="Diver |{ { <hpv> H+V } } "] map [label="Mapper|{ { <h> Hue | <y> Y Brightness}| { <rgbo> RGB } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2} } } "]; pol [label="Polar\nFringe |{ { <ri> R } | { <p> Pos Key | <n> Neg Key} } "] vis [label="Visual\nCortex |{ { <argb> A RGB }| { <hpv> H+V | <comvo> Component} } } "]; }}
Patch 3 Ramp processing
digraph structs {node [shape=record];{ ray:t -> map:y dive:ho -> map:h dive:vo -> map:s map:uo -> pass:ri map:vo -> pass:gi vis:ho -> "H Out" "H In" -> pass:tr vis:vo -> "V Out" "V In" -> pass:tg pass:ro -> bridge:mpa pass:go -> bridge:mpb bridge:mo -> top:s top:pb -> vis:ar top:mc -> vis:ag top:ne -> vis:ab vis:comvo -> "Main Output" bridge [label="Bridge |{ { <mpa> Mixer + | <mm> - | <mpb> + }| { <mo> Mixer} } } "]; dive [label="Diver |{ { <ho> H | <vo> V } } "]; map [label="Mapper|{ { <h> Hue | <s> Saturation | <y> Y Brightness}| { <uo> U | <vo> V } } } "]; pass [label="Passage |{ { <ri> In 1 | <gi> 2 | <tr> Thru 1 | <tg> 2 } | { <ro> Out 1 | <go> 2 } } } "]; ray [label="Prismatic\nRay |{ { <t> Tri } } } "]; top [label="Topogram |{ { <s> Source } | { <pb> Pos 2 | <mc> Min C | <ne> Neg 5 } } "]; vis [label="Visual\nCortex |{ { <ar> R | <ag> G | <ab> B }| { <ho> H | <vo> V | <comvo> Component} } } "]; }}
Memory palace 3 patches
patch 1
digraph structs {node [shape=record]; { mem:rbgo -> vis:argbi vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <rbgo> RGB } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB }| { <comvo> Component} } } "]; }}
patch 2
digraph structs {node [shape=record]; { ray:pa -> mem:ai dive:vo -> mem:aux mem:ro -> vis:ar mem:go -> vis:ag mem:bo -> vis:ab vis:comvo -> "main out" dive [label="Diver |{ { <vo> V } } "]; mem [label="Memory\nPalace |{ { <ai> A | <aux> Aux } | { <ro> R | <go> G | <bo> B } }} "]; ray [label="Prismatic\nRay |{ { <pa> Parabola } } "]; vis [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component} } } "]; }}
patch 3
digraph structs {node [shape=record]; { dive:hmv -> mem:aux dive:ho -> mem:ri dive:hpv -> mem:gi dive:vo -> mem:bi sketch:x -> mem:z sketch:y -> mem:r mem:ro -> vis:ar mem:go -> vis:ag mem:bo -> vis:ab mem:yo -> "y_to_wave_in" "y_to_wave_out" -> dive:w vis:comvo -> "main out" dive [label="Diver |{ { <w> Wave } | { <ho> H | <hpv> H+V | <vo> V | <hmv> H-V } } "]; sketch [label="Escher\nSketch |{ { <x> X | <y> Y } } } "]; mem [label="Memory\nPalace |{ { <ri> R | <gi> G | <bi> B | <aux> Aux | <z> Zoom | <r> Rotation } | {<yo> Y | <ro> R | <go> G | <bo> B } }} "]; vis [label="Visual\nCortex |{ { <ar> A R | <ag> G | <ab> B }| { <comvo> Component} } } "]; }}
fkg3 3 patches
patch 1
digraph structs {node [shape=record]; { pen:bo -> mem:d mem:rgbo -> fkg:fgrgbi fort:rgbo -> fkg:bgrgbi fkg:rgbo -> vis:argbi ray:po -> fkg:ti vis:hpv -> "H+V_Ramp_send" "H+V_Ramp_return" -> fkg:kri vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <d> Delay } | { <rgbo> RGB } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB} | {<hpvo> H+V | <comvo> Component} } } "]; pen [label="Pendulum |{ { <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <po> Parabola} } } "]; fkg [label="FKG3|{ { <bgrgbi> BG RGB | <fgrgbi> FG RGB | <kri> Key R | <ti> Thresh }| { <rgbo> RGB} } } "]; fort [label="Fortress |{ { <rgbo> RGB } } "]; }}
patch 2
digraph structs {node [shape=record]; { mem:yo -> stair:si mem:ro -> fort:hi cho:rgbo -> fkg:fgrgbi fort:rgbo -> fkg:bgrgbi fort:vo -> fkg:si dive:hpvo -> fkg:ti ray:po -> fkg:kri mem:go -> fkg:kgi fort:ho -> fkg:kbi fkg:rgbo -> vis:argbi stair:fo -> cho:ri stair:to -> cho:gi stair:oo -> cho:bi vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <yo> Y | <go> G | <ro> R } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB} | { <comvo> Component} } } "]; dive [label="Diver |{ { <hpvo> H+V } } "]; stair [label="Staircase |{ { <si> Source }| { <fo> /4 | <to> /2 | <oo> /1 } } } "]; ray [label="Prismatic\nRay |{ { <po> Parabola } } } "]; cho [label="Color\nChords|{ { <ri> R | <gi> G | <bi> B }| { <rgbo> RGB } } } "]; fkg [label="FKG3|{ { <ti> Thresh | <fgrgbi> FG RGB | <kri> Key R | <kgi> G | <kbi> B | <si> softness | <bgrgbi> BG RGB }| { <rgbo> RGB} } } "]; fort [label="Fortress |{ { <hi> H } | { <ho> H | <vo> V | <rgbo> RGB } } "]; }}
patch 3
digraph structs {node [shape=record]; { ray:po -> stair:si stair:oo -> vis:argbi fkg:ro -> ray:pi fkg:go -> ray:mi fkg:bo -> stair:fi dive:hpvo -> fkg:bgri fort:ho -> fkg:bggi mem:yo -> fkg:bgbi fort:vo -> fkg:ti vis:hpvo -> "circle_out" "circle_in" -> fkg:kri vis:comvo -> "main out" pen:ao -> fkg:fgri pen:bo -> fkg:fggi pen:co -> fkg:fgbi pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B | <co> C } } } "]; mem [label="Memory\nPalace |{ { <yo> Y } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB} | { <hpvo> H+V | <comvo> Component} } } "]; dive [label="Diver |{ { <hpvo> H+V } } "]; stair [label="Staircase |{ { <si> Source | <fi> Frequency }| { <oo> /1 } } } "]; ray [label="Prismatic\nRay |{ { <pi> Pedestal | <mi> Multiply }| { <po> Parabola } } } "]; fkg [label="FKG3|{ { <fgri> FG R | <fggi> G | <fgbi> B | <kri> Key R | <ti> Thresh | <bggi> BG G | <bgri> R | <bgbi> B }| { <ro> R | <go> G | <bo> B } } } "]; fort [label="Fortress |{ { <vo> V | <ho> H } } "]; }}
SMX3 3 Patches
Patch 1
digraph structs {node [shape=record]; { mem:yo -> smx:cgi pen:bo -> smx:bbi dive:hpvo -> smx:ari pen:ao -> smx:bri ray:po -> smx:cri mem:rgbo -> fkg:bgrgbi smx:rgbo -> fkg:fgrgbi fkg:rgbo -> vis:argbi vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <yo> Y | <rgbo> RGB } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB }| { <comvo> Component} } } "]; dive [label="Diver |{ { <hpvo> H+V } } "]; smx [label="SMX3|{ {<ari> A R | | <bri> B R | <bbi> B | <cri> C R | <cgi> G }| { <rgbo> RGB |} } } "]; fkg [label="FKG3|{ { <fgrgbi> FG RGB | <bgrgbi> BG RGB }| { <rgbo> RGB } } } "]; pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <po> Parabola } } } "]; }}
patch 2
digraph structs {node [shape=record]; { top:pbo -> map:hi top:pdo -> map:yi pen:ao -> smx:ari pen:bo -> smx:abi ray:po -> "parabola out" "parabola in" -> smx:bri mem:yo -> smx:cri smx:ro -> top:ui smx:go -> stair:pi smx:bo -> ray:mi dive:hpvo -> stair:si stair:to -> top:si map:rgbo -> fkg:fgrgbi fkg:rgbo -> vis:argbi vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <yo> Y } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB }| { <comvo> Component} } } "]; dive [label="Diver |{ { <hpvo> H+V } } "]; smx [label="SMX3|{ { <ari> A R | <abi> B | <bri> B R | <cri> C R }| { <go> G | <ro> R | <bo> B } } } "]; fkg [label="FKG3|{ { <fgrgbi> FG RGB }| { <rgbo> RGB } } } "]; pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; ray [label="Prismatic\nRay |{ { <mi> Multiply }| { <po> Parabola } } } "]; map [label="Mapper|{ { <hi> Hue | <yi> Y Brightness}| { <rgbo> RGB } } } "]; top [label="Topogram |{ { <si> Source | <ui> Upper } | { <pbo> 2 | <pdo> 4 } } "]; stair [label="Staircase |{ { <si> Source | <pi> Phase}| { <fo> /4 | <to> /2 | <oo> /1 } } } "]; }}
Patch 3
digraph structs {node [shape=record]; { mem:yo -> dive:hi mem:ro -> map:hi mem:go -> map:yi smx:rgbo -> vis:argbi smx:rgbo -> fkg:fgrgbi dive:hpvo -> smx:ari map:rgbo -> smx:brgbi fkg:rgbo -> "feedback_out" "feedback_in" -> smx:crgbi vis:comvo -> "main out" mem [label="Memory\nPalace |{ { <rbgo> RGB | <yo> Y | <ro> R | <go> G } }} "]; vis [label="Visual\nCortex |{ { <argbi> A RGB }| { <comvo> Component} } } "]; dive [label="Diver |{ { <hi> H Phase } | { <hpvo> H+V } } "]; smx [label="SMX3|{ { <ari> A R | <brgbi> B RGB | <crgbi> C RGB }| { <rgbo> RGB } } } "]; fkg [label="FKG3|{ { <fgrgbi> FG RGB }| { <rgbo> RGB } } } "]; map [label="Mapper|{ { <hi> Hue | <yi> Y Brightness}| { <rgbo> RGB } } } "]; }}
DSG3 3 Patches
Patch 1
digraph structs {node [shape=record]; { dsg:oao -> pro:ari sen:co -> pro:bri pro:ro -> esg:ri dsg:oso -> esg:gi dsg:omao -> esg:bi esg:co -> "main out" dsg [label="DSG3|{ { <oso> 1 SUM | <omao> MAX | <oao> ABS} } } "]; esg [label="ESG3|{ { <gi> G | <bi> B | <ri> R }| { <co> Component } } } "]; pro [label="Proc |{ { <ari> A 1 | <bri> B 1 } | { <ro> Out 1 } } } "]; sen [label="Sensory\nTranslator|{ { <co> C } } } "]; }}
Patch 2
digraph structs {node [shape=record]; { dsg:tmao -> "Internal_feedback_out" "Internal_feedback_in" -> dsg:tvi "Audio_oscillator_in" -> bri:fai pen:ao -> bri:fvi bri:fo -> dsg:ohi dsg:oao -> esg:ri dsg:oso -> esg:gi dsg:tao -> esg:bi esg:co -> "main out" dsg [label="DSG3|{ { <ohi> 1 H | <tvi> 2 V }| { <oso> 1 SUM | <oao> ABS | <tao> 2 ABS | <tmao> MAX } } } "]; esg [label="ESG3|{ { <gi> G | <ri> R | <bi> B }| { <co> Component } } } "]; pen [label="Pendulum |{ { <bo> LFO B } } } "]; bri [label="Bridge |{ { <fai> Fader A | <fvi> VC }| { <fo> Fader } } } "]; }}
Patch 3
digraph structs {node [shape=record]; { "Audio_oscillator_in_1" -> dsg:ovi key:go -> "Feedback_out" "Feedback_in" -> dsg:ohi dsg:omao -> sta:ri dsg:tmao -> sta:pi dsg:tao -> key:rki dsg:oao -> key:rci "Audio_oscillator_in_2" -> key:gci sta:tho -> esg:ri key:ro -> esg:gi esg:co -> "main out" dsg [label="DSG3|{ { <ohi> 1 H | <ovi> V }| { <omao> 1 MAX | <tmao> 2 MAX | <oao> 1 ABS | <tao> 2 ABS } } } "]; esg [label="ESG3|{ { <ri> R | <gi> G | <bi> B }| { <co> Component } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 | <gci> CV 2 } | { <ro> Out 1 | <go> 2 } } } "]; sta [label="Stairs |{ { <ri> R | <pi> Phase }| { <tho> /32 } } } "]; }}
DWO 3 patches
patch 1
digraph structs {node [shape=record]; { smx:rgbo -> esg:rgbi dwo:oso -> key:rci dwo:tso -> key:rki key:ro -> smx:ari key:go -> smx:bri key:bo -> smx:cri dwo:oqo -> key:gci dwo:tqo -> key:gki dwo:oto -> key:bci dwo:tto -> key:bki dsg:tao -> dwo:ori dwo:two -> DWO_feedback_out DWO_feedback_in -> dwo:ofci esg:co -> "main out" dsg [label="DSG3|{ { <tao> ABS } } } "]; dwo [label="DWO3|{ { <ofci> 1 Freq CV | <ori> 1 Rst }| { <oso> 1 Sin | <oqo> 1 Sq | <oto> 1 Tri | <tso> 2 Sin | <tqo> 2 Sq | <tto> 2 Tri | <two> 2 Saw } } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; key [label="Keychain |{ { <rci> CV 1 | <gci> 2 | <bci> 3 | <rki> Key 1 | <gki> 2 | <bki> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB } } } "]; }}
patch 2
digraph structs {node [shape=record]; { dsg:oso -> prob:ari dwo:oso -> swa:ipi prob:ro -> dwo:ori prob:go -> fkg:kri fkg:rgbo -> esg:rgbi dwo:tso -> DWO_SUM_out DWO_SUM_in -> pro:bri dsg:tao -> dwo:tfci pro:ro -> smx:ari pro:go -> smx:bri pro:bo -> smx:cri smx:rgbo -> fkg:fgrgbi dsg:tmao -> pro:abi pen:ao -> pro:ari pen:bo -> pro:agi penb:co -> dwo:tlci swa:crgbo -> fkg:bgrgbi prob:bo -> swa:qpi esg:co -> "main out" dsg [label="DSG3|{ { <tmao> MAX | <oso> 1 SUM | <tao> ABS } } } "]; dwo [label="DWO3|{ { <ori> 1 Rst | <tfci> 2 Freq CV | <tlci> 2 lin CV }| { <oso> 1 Sin | <tso> 2 Sin } } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB } } } "]; pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; penb [label="Pendulum 2|{ { <co> C } } } "]; pro [label="Proc |{ { <bri> B 1 | <ari> A 1 | <agi> A 2 | <abi> A 3 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; prob [label="Proc 2 |{ { <ari> A 1 } | { <go> 2 | <bo> 3 | <ro> Out 1 } } } "]; swa [label="Swatch |{ { <qpi> Q+ | <ipi> I+ }| { <crgbo>Clamp RGB } } } "]; fkg [label="FKG3|{ { <fgrgbi> FG RGB | <kri> Key R | <bgrgbi> BG RGB }| { <rgbo> RGB } } } "]; }}
patch 3
digraph structs {node [shape=record]; { fkg:rgbo -> esg:rgbi dwo:oso -> swa:ipi dwo:oto -> swa:imi swa:crgbo -> fkg:bgrgbi dwo:oqo -> key:rki dwo:owo -> key:rci key:ro -> swa:yi tbc:brgbo -> fkg:krgbi pen:ao -> dwo:tfci dwo:two -> smx:ari dwo:tqo -> smx:agi dwo:tto -> smx:abi smx:rgbo -> fkg:fgrgbi esg:co -> "main out" fkg [label="FKG3|{ { <bgrgbi> BG RGB | <fgrgbi> FG RGB | <krgbi> Key RGB }| { <rgbo> RGB } } } "]; dwo [label="DWO3|{ { <tfci> 2 Freq CV }| { <owo> 1 Saw | <oqo> 1 Sq | <oso> 1 Sin | <oto> 1 Tri | <two> 2 Saw | <tqo> 2 Sq | <tto> 2 Tri } } } "]; swa [label="Swatch |{ { <yi> Y | <ipi> I+ | <imi> I- }| { <crgbo>Clamp RGB } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 } | { <ro> Out 1 } } } "]; tbc [label="TBC2 |{ { <brgbo> B RGB } } } "]; pen [label="Pendulum |{ { <ao> LFO A } } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <agi> G | <abi> B }| { <rgbo> RGB } } } "]; }}
Swatch 3 patches
patch 1a
digraph structs {node [shape=record]; { esg:co -> "main out" tbc:argbo -> swa:rgbi swa:crgbo -> smx:argbi smx:rgbo -> esg:rgbi swa:ipo -> pro:ari pro:ro -> Iout Iin -> swa:ipi dwo:tso -> pro:bri swa:qpo -> pro:agi pro:go -> Qin Qout -> swa:qpi swa:yo -> con:ri con:ro -> Yout Yin -> swa:yi con [ label="Contour |{ { <ri> Filter 1 } | { <ro> Out 1 }}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 | <bri> B 1 } | { <ro> Out 1 | <go> 2 }}}"]; dwo [label="DWO3|{ { <tso> 2 Sin }}} "]; smx [label="SMX3|{ { <argbi> A RGB }| { <rgbo> RGB}}}"]; esg [ label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; tbc [ label="TBC2 |{ { < argbo> A RGB }}}"]; swa [label="Swatch |{ { < rgbi> RGB | <yi> Y | <ipi> I+ | <qpi> Q+ }| { <crgbo>Clamp RGB | <yo> Y | <ipo> I+ | <qpo> Q+ }}}"]; }}
patch 1b
digraph structs {node [shape=record]; { tbc:argbo -> swa:rgbi swa:crgbo -> smx:argbi smx:rgbo -> esg:rgbi swa:yo -> con:ri con:ro -> pro:bri pro:ro -> Yout Yin -> swa:yi esg:co -> "main out" swa [label ="Swatch |{ { <rgbi > RGB | <yi> Y }| { <crgbo>Clamp RGB | <yo> Y }}}"]; esg [ label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; con [ label="Contour |{ { <ri> Filter 1 } | { < ro> O ut 1}}}"]; pro [ label="Proc |{ { <bri> B 1 } | { <ro> Ou t 1 }}}"]; tbc [ label="TBC2 |{ { <argbo> A RGB }}}"]; smx [label= "SMX3|{ { <argbi> A RGB }| { <rgbo> RGB }}}"]; }}
patch 1 C
digraph structs {node [shape=record]; { tbc:argbo -> swa:rgbi swa:crgbo -> smx:argbi smx:rgbo -> esg:rgbi swa:qmo -> Qout Qin -> swa:qpi swa:imo -> Iout Iin -> swa:ipi esg:co -> "main out" swa [ label="Swatch |{ { < rgbi> RGB | <ipi> I+ | <qpi> Q+ }| { <crgbo>Clamp RGB | <imo> I- | <qmo> Q- }}}"]; esg [label = "ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; smx [label="SMX3|{ { <argbi > A RGB} | { <rgbo> RGB}}}"]; tbc [label="TBC2 |{ { <argbo> A RGB }}}"]; }}
patch 2
digraph structs {node [shape=record]; { tbc:argbo -> swa:rgbi swa:crgbo -> smx:argbi smx:rgbo -> esg:rgbi swa:yo -> sta:ri sta:so -> pro:bri pro:ro -> Y_proc_out Y_proc_in -> swa:yi swa:ipo -> pro:agi pro:go -> I_proc_out I_proc_in -> swa:ipi swa:qmo ->pro:abi pro:bo -> Q_proc_out Q_proc_in -> swa:qmi dsg:oao -> pro:bbi swa:qpo -> sta:si swa:imo -> sta:pi esg:co -> "main out" dsg [label="DSG3|{ {<oao> A ABS }}} "]; pro [label="Proc |{ { <bri> B 1 | <abi> A 3 | <agi> A 2 | <bbi> B 3} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; sta [label="Stairs |{ { < ri> R | <si> Steps | <pi> Phase }| { <so> /16 }}}"]; swa [ label="Swatch |{ { <rgbi> RGB | <yi> Y | <ipi> I+ | <qmi> Q - }| { <crgbo>Clamp RGB | <yo> Y | <qpo> Q+ | <imo> I- | <qmo> Q- | <ipo> I+ }}}"]; esg [label = "ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; smx [label="SMX3|{ { <argbi > A RGB }| { <rgbo> RGB }}}"]; tbc [label="TBC2 |{ { <argbo> A RGB }}}"]; }}
patch 3
digraph structs {node [shape=record]; { dwo:oso -> key:rki dwo:tso -> key:rci key:ro -> sta:si dsg:oao -> sta:ri sta:so -> swa:yi key:bo -> pro:ari pro:ro -> swa:ipi dwo:oto -> swa:qpi sta:eo -> swa:imi key:go -> swa:qmi pen:ao -> pro:bri pen:bo -> sta:pi swa:crgbo -> esg:rgbi esg:co -> "main out" pen [ label="Pendulum |{ { <bo> LFO B | <ao> LFO A }}}"]; pro [ label="Proc |{ { <ari> A 1 | <bri> B 1} | { <ro> Out 1 }}}"]; swa [label="Swatch |{ { <imi> I- | <yi> Y | <qmi> Q- | <ipi> I+ | <qpi> Q- }| { <crgbo>Clamp RGB }}}"]; dsg [label= " DSG3|{ {<omao> A MAX }}} "]; esg [ label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; dwo [ label="DWO3|{ { <tso> 2 Sin | <oso> 1 Sin | <oto> 1 Tri }}} "]; key [ label="Keychain |{ { <rci> CV 1 | <rki> Key 1 } | { <ro> O ut 1 | <go> 2 | <bo> 3}}}"]; sta [label="Stairs |{ { < ri> R | <si> Steps | <pi> Phase }| { <eo> /8 | <so> /16 }}}"]; }}
Proc 3 patches
patch 1
digraph structs {node [shape=record]; { dsg:omao -> pro:ari dsg:tmao -> pro:bri pro:rgbo -> esg:rgbi dsg:tso -> pro:bbi dsg:tao -> pro:bgi esg:co -> "main out" dsg [label="DSG3|{ { <omao> 1 MAX | <tmao> 2 MAX | <tao> 2 ABS | <tso> 2 SUM } } } "]; pro [label="Proc |{ { <ari> A 1 | <bri> B 1 | <bgi> B 2 | <bbi> B 3} | { <rgbo> RGB out} } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; }}
patch 2
digraph structs {node [shape=record]; { dsg:oao -> pro:abi pro:bo -> key:rki key:ro -> esg:ri pen:ao -> pro:bbi pen:bo -> pro:bri dsg:tmao -> pro:ari pro:ro -> key:rci pro:go -> key:gki key:go -> esg:gi "audio rate osc" -> pro:bgi esg:co -> "main out" dsg [label="DSG3|{ { <tmao> 2 MAX | <oao> 1 ABS } } } "]; pro [label="Proc |{ { <ari> A 1 | | <abi> A 3 | <bri> B 1 | <bbi> B 3 | <bgi> B 2 } | { <ro> Out 1 | <bo> 3 | <go> 2} } } "]; pen [label="Pendulum |{ { <bo> LFO B | <ao> LFO A } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 | <gki> Key 2 } | { <ro> Out 1 | <go> 2 } } } "]; esg [label="ESG3|{ { <ri> R | <gi> G }| { <co> Component } } } "]; }}
patch 3
digraph structs {node [shape=record]; { dsg:omao -> smx:ari dsg:oao -> smx:bri dsg:tmao -> smx:cri smx:rgbo -> dis:rgbi pro:rgbo -> fkg:fgrgbi fkg:rgbo -> esg:rgbi dis:orgbo -> pro:argbi dis:twrgbo -> fkg:bgrgbi "audio rate osc" -> pro:bri pen:ao -> pro:bbi pen:bo -> fkg:ti esg:co -> "main out" dsg [label="DSG3|{ { <omao> 1 MAX | <oao> 1 ABS | <tmao> 2 MAX } } } "]; pro [label="Proc |{ { <argbi> A 123 | <bri> B 1 | <bbi> B 3} | { <rgbo> 123 out } } } "]; pen [label="Pendulum |{ { <ao> LFO A | <bo> LFO B } } } "]; fkg [label="FKG3|{ { <bgrgbi> BG RGB | <fgrgbi> FG RGB | <ti> Thresh }| { <rgbo> RGB } } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB } } } "]; dis [label="Distributor |{ { <rgbi> RGB }| { <twrgbo> 1 RGB | <orgbo> 2 RGB } } } "]; }}
Stairs 3 patches
patch 1
digraph structs {node [shape=record]; { "audio_rate_osc" -> sta:ri sta:fo -> esg:ri sta:eo -> esg:gi sta:sxo -> esg:bi dsg:tmao -> sta:si esg:co -> "main out" dsg [label="DSG3|{ { <tmao> MAX } } } "]; esg [label="ESG3|{ { <ri> R | <gi> G | <bi> B }| { <co> Component } } } "]; sta [label="Stairs |{ { <ri> R | <si> Steps }| { <fo> /4 | <eo> /8 | <sxo> /64} } } "]; }}
patch 2
digraph structs {node [shape=record]; { "audio_rate_osc" -> sta:pi dsg:tmao -> sta:si dsg:oao -> pro:bgi dsg:tao -> pro:bri pro:ro -> sta:ri pro:go -> sta:gi pen:ao -> sta:bi sta:to -> esg:ri sta:sxo -> esg:gi esg:co -> "main out" dsg [label="DSG3|{ { <tao> ABS | <oao> ABS | <tmao> MAX } } } "]; esg [label="ESG3|{ { <ri> R | <gi> G }| { <co> Component } } } "]; pro [label="Proc |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 } } } "]; pen [label="Pendulum |{ { <ao> LFO A } } } "]; sta [label="Stairs |{ { <ri> R | <gi> G | <bi> B | <si> Steps | <pi> Phase }| { <to> /2 | <sxo> /64} } } "]; }}
patch 3
digraph structs {node [shape=record]; { dsg:tao -> sta:ri sta:fo -> esg:ri sta:eo -> pro:ari pen:ao -> pro:bri pro:ro -> "Proc_R out" "Proc_R in" -> sta:bi sta:to -> "Stairs_two_out" "Stairs_two_in" -> sta:pi "audio_rate_osc" -> pro:bgi sta:sxo -> pro:agi pro:go -> "Proc_G out" "Proc_G in" -> sta:si esg:co -> "main out" dsg [label="DSG3|{ { <tao> ABS } } } "]; esg [label="ESG3|{ { <ri> R }| { <co> Component } } } "]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 | <bri> B 1 | <bgi> 2} | { <ro> Out 1 | <go> 2 } } } "]; pen [label="Pendulum |{ { <ao> LFO A } } } "]; sta [label="Stairs |{ { <ri> R | <bi> B | <si> Steps | <pi> Phase }| { <to> /2 | <fo> /4 | <eo> /8 | <sxo> /64} } } "]; }}
Keychain 3 patches
patch 1
digraph structs {node [shape=record]; { dsg:oso -> key:rki dsg:tso -> key:rci key:ro -> esg:ri key:go -> esg:gi key:bo -> esg:bi esg:co -> "main out" esg [label="ESG3|{ { <ri> R | <gi> G | <bi> B }| { <cvo> CVBS | <co> Component } } } "]; dsg [label="DSG3|{ { <oso> 1 SUM | <tso> 2 SUM } } } "]; key [label="Keychain |{ { <rki> Key 1 | <rci> CV 1 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; }}
patch 2
window key
digraph structs {node [shape=record]; { dsg:oao -> key:rki key:ro -> pro:ari dsg:oso -> pro:agi pro:ro -> "window_key_out" "window_key_in" -> key:gci key:go -> pro:bgi pen:ao -> key:rci pen:bo -> pro:bri pro:go -> smx:ari key:bo -> smx:bri dsg:omao -> smx:cri smx:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; dsg [label="DSG3|{ { <ohi> 1 H | <ovi> V | <thi> 2 H | <tvi> V }| { <oao> 1 ABS | <oso> SUM | <omao> MAX } } } "]; key [label="Keychain |{ { <rci> CV 1 | <gci> 2 | <rki> Key 1 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pen [label="Pendulum |{ { <bo> LFO B | <ao> LFO A } } } "]; pro [label="Proc |{ { <bri> B 1 | <ari> A 1 | <bgi> B 2 | <agi> A 2 } | { <ro> Out 1 | <go> 2 } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB } } } "]; }}
patch 3
digraph structs {node [shape=record]; { dsg:oao -> key:rki key:ro -> pro:bbi key:go -> pro:abi pro:bo -> smx:ari key:bo -> smx:bri pro:ro -> "dual_CV_control_out" "dual_CV_control_in" -> key:rci smx:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R }| { <rgbo> RGB} } } "]; dsg [label="DSG3|{ { <oao> 1 ABS } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pro [label="Proc |{ { <bbi> B 3 | <abi> A 3 } | { <ro> Out 1 | <bo> 3} } } "]; }}
Angles 3 Patches
patch 1
digraph structs {node [shape=record]; { dsg [label = "DSG3|{ { <oao> A ABS | <tao> B ABS }}} "]; key [label="Keychain |{ { <rki> Key 1 | <gki> 2 | <bki> 3} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; smx [label= "SMX3|{ { <ari> A R | <agi> G | <abi> B | <bbi> B B }| { <rgbo> RGB }}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; pro [label="Proc |{ { < ari> A 1 | <agi> 2 | <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; pen [label="Pendulum |{ { < ao> LFO A | <bo> LFO B }}}"]; ang [label="Angles|{ { <bi> B | <di> D }| { <wo> 24 345 | <no> 14 210 | <bo> 2 30 | <eo> 5 75 } } } "]; dsg:oao -> pro:ari dsg:tao -> pro:agi pen:ao -> pro:bri pen:bo -> pro:bgi pro:ro -> ang:bi pro:go -> ang:di ang:wo -> key:rki ang:no -> key:gki ang:bo -> key:bki key:ro -> smx:ari key:go -> smx:agi key:bo -> smx:abi ang:eo -> smx:bbi smx:rgbo -> esg:rgbi esg:co -> "main out" }}
patch 2
digraph structs {node [shape=record]; { ang [label="Angles|{ { <bi> B | <di> D }| { <to> 300 | <vo> 330 | <io> 135 | <ho> 120 | <so> 285 | <uo> 315 | <lo> 180 } } } "]; dsg [label = "DSG3|{ { <omao> 1 MAX | <tmio> 2 MIN }}} "]; dwo [label="DWO3|{ { <ofci> 1 Freq CV | <tfci> 2 Freq CV }| { <oso> 1 Sin | <tso> 2 Sin }}} "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 | <bci> CV 3 | <gci> CV 2 } | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; smx [label= "SMX3|{ { <ari> A R | <agi> G | <abi> B | <bri> B R | <cri> C R }| { <rgbo> RGB | <ro> R | <go> G | <bo> B}}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; pen [label="Pendulum |{ { <ai> A--D | <bi> B--C }| { <co> C }}}"]; dsg:tmio -> ang:di dsg:omao -> ang:bi dwo:oso -> key:rci dwo:tso -> key:rki ang:so -> key:gci ang:ho -> key:bci ang:uo -> smx:bri ang:lo -> smx:cri ang:io -> dwo:tfci pen:co -> dwo:ofci ang:to -> pen:ai ang:vo -> pen:bi key:ro -> smx:ari key:go -> smx:agi key:bo -> smx:abi smx:rgbo -> esg:rgbi esg:co -> "main out" }}
patch 3
digraph structs {node [shape=record]; { ang [label="Angles|{ { <ai> A | <bi> B |<ci> C | <di> D }| { <bo> 30 | <do> 60 | <jo> 150 } } } "]; dsg [label = "DSG3|{ { <oao> 1 ABS }}} "]; dwo [label="DWO3|{ { <oso> 1 Sin | <tso> 2 Sin }}} "]; key [label="Keychain |{ { <rci> CV 1 | <gci> 2 | <bci> 3 | <rki> Key 1 } | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; smx [label= "SMX3|{ { <ari> A R | <agi> G | <abi> B }| { <rgbo> RGB }}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; pro [label="Proc |{ { < ari> A 1 | <bri> B 1 } | { <ro> Out 1 }}}"]; pen [label="Pendulum |{ { < ao> LFO A | <bo> LFO B }}}"]; pen2 [label="Pendulum |{ { < ao> LFO A }}}"]; dwo:oso -> pro:ari dwo:tso -> pro:bri pro:ro -> key:rki pen:ao -> ang:ai pen:bo -> ang:bi dsg:oao -> ang:ci pen2:ao -> ang:di ang:bo -> key:rci ang:do -> key:gci ang:jo -> key:bci key:ro -> smx:ari key:go -> smx:agi key:bo -> smx:abi smx:rgbo -> esg:rgbi esg:co -> "main out" }}
Contour 3 patches
patch 1
digraph structs {node [shape=record]; { con [label="Contour |{ { <gci> CV 2 | <bci> CV 3 | <rci> CV 1 | <ri> Filter 1} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; dsg [label="DSG3|{ { <tao> 2 ABS }}} "]; esg [label = "ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; dwo [label="DWO3|{ { <oso> 1 Sin | <tso> 2 Sin }}} "]; key [label="Keychain |{ { <rki> Key 1 } | { < ro> Out 1 }}}"]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo > RGB}}}"]; pen [label="Pendulum |{ { <ao> LFO A }}}"]; sta [ label="Stairs |{ { <ri> R }| { <fo> /4}}}"]; dsg:tao -> sta:ri sta:fo -> con:ri con:ro -> key:rki key:ro -> smx:ari con:go -> smx:bri con:bo -> smx:cri dwo:tso -> con:rci pen:ao -> con:gci dwo:oso -> con:bci smx:rgbo -> esg:rgbi esg:co -> "main out" }}
patch 2
digraph structs {node [shape=record]; { con [label="Contour |{ { <rci> CV 1 | <gci> 2 | <bci> 3 | <ri> Filter 1} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; dsg [label="DSG3|{ { <tao> 2 ABS | <omio> 1 MIN }}} "]; esg [label = "ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; dwo [label="DWO3|{ { <oso> 1 Sin | <tso> 2 Sin }}} "]; key [label="Keychain |{ { <rki> Key 1 | <gki> 2 } | { < ro> Out 1 | <go> 2 }}}"]; smx [label="SMX3|{ { <ari> A R | <bri> B R }| { <rgbo > RGB}}}"]; sta [ label="Stairs |{ { <ri> R }| { <sxo> /64}}}"]; pro [label="Proc |{ { <ari> A 1 | <bri> B 1 | <agi> A 2 } | { <ro> Out 1 | <go> 2 }}}"]; dsg:omio-> sta:ri sta:sxo-> con:ri dsg:tao-> con:bci con:ro -> pro:ari con:go -> pro:bri pro:ro-> key:rki key:ro-> smx:ari con:bo -> pro:agi pro:go-> key:gki key:go-> smx:bri dwo:oso -> con:rci dwo:tso -> con:gci smx:rgbo -> esg:rgbi esg:co -> "main out" }}
patch 3
digraph structs {node [shape=record]; { con [label="Contour |{ { <ri> Filter 1 | <rci> CV 1 | <gci> CV 2} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; esg [label = "ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; dwo [label="DWO3|{ { <tso> 2 Sin }}} "]; key [label="Keychain |{ { <rki> Key 1 | <rci> CV 1} | { <ro> Out 1 }}}"]; smx [label="SMX3|{ { <argbi> A RGB | <bri> B R | <cri> C R }| { <rgbo > RGB}}}"]; tbc [label="TBC2 |{ { <argbo> A RGB | <ayo> A Y }}}"]; dist [label="Dist|{ { <ri> R }| { <oro> 1 R | <twro> 2 R }}}"]; tbc:argbo -> smx:argbi tbc:ayo -> dist:ri dist:oro -> con:ri dist:twro -> con:rci con:ro -> smx:bri con:go -> key:rki con:bo -> key:rci key:ro -> smx:cri dwo:tso -> con:gci smx:rgbo -> esg:rgbi esg:co -> "main out" }}
EDIT: done with the 3 patches videos
i dont have even have any lzx and loving every one of these ! :heart_eyes_cat:
thank you so much!
I have a page in my patch notebook that is dedicated to recur setups that I love. I’m excited to get this kind of setup mapped as well
A collection of just our patches. We will do a full patch book treatment starting pretty soon. I’ll make a version for the web that includes video and pictures along with some patch notes as well as an offline version to print that will have everything but the video.
toon filter riff
digraph structs {node [shape=record]; { dsg:omio -> "DSG_self_out" "DSG_self_in" -> dsg:thi dsg:omao -> sta:ri dsg:tmio -> sta:gi dsg:tao -> key:rki key:ro -> pass:tbi key:go -> pass:bi pass:bo -> smx:ari key:bo -> smx:bri dsg:tmao -> smx:cri sta:to -> pass:tgi baj:do -> pass:gi pass:go -> "mod_mix_out" "mod_mix_in" -> pass:ri pass:ro -> "mod_final_out" "mod_final_in" -> key:rci smx:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB} } } "]; dsg [label="DSG3|{ { <thi> 2 H }| { <omio> 1 MIN | <omao> MAX | <tmio> 2 MIN | <tao> ABS | <tmao> MAX} } } "]; key [label="Keychain |{ { <rki> Key 1 | <rci> CV 1 } | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; pass [label="Passage |{ { <ri> In 1 | |<gi> 2 | <tgi> Thru 2 | <tbi> 3 | <bi> In 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; sta [label="Stairs |{ { <ri> R | <gi> G }| { <to> /2} } } "]; baj [label="Baja |{ { <do> 0 } } } "]; }}
Lumia type patch
digraph structs {node [shape=record]; { dsg:oao -> “self_modulation_out” “self_modulation_in” -> dsg:thi dsg:tmio -> mult:i mult:ro -> sta:ri mult:bo -> key:rki mult:go -> fkg:kri fkg:ro -> smx:ari sta:tho -> smx:bri key:ro -> smx:cri smx:rgbo -> fkg2:bgrgbi dsg:omao -> fkg2:kri dsg:omio -> fkg2:kgi dsg:oso -> fkg2:kbi fkg2:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <bri> B R | <ari> A R | <cri> C R }| { <rgbo> RGB} } } "]; dsg [label="DSG3|{ { <thi> 2 H }| { <omao> 1 MAX | <omio> MIN | <oso> SUM | <oao> 2 ABS | <tmio> MIN } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 } | { <ro> Out 1 } } } "]; mult [label="mult |{ { <i> In} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; sta [label="Stairs |{ { <si> Steps | <ri> R }| { <tho> /32 } } } "]; fkg [label="FKG3|{ { <kri> Key R | <ti> Thresh }| { <ro> R } } } "]; fkg2 [label="FKG3|{ { <kri> Key R | <kgi> G | <kbi> B | <ti> Thresh | <bgrgbi> FG RGB }| { <rgbo> RGB } } } "]; }}
dsg tricks 2
dsg tricks 2
digraph structs {node [shape=record]; { dsg:oso -> key:rki dsg:tao -> fkg:kri dsg:omao -> sta:ri con:ro -> smx:ari key:go -> smx:bri sta:eo -> smx:cri key:ro -> con:ri con:bo -> "filter_modulation_out" "filter_modulation_in" -> fkg:ti con:go -> “filter_feedback_out” “filter_feedback_in” -> con:rci fkg:ro -> "DSG_key_out" "DSG_key_in" -> dsg:ovi "baja_1" -> key:rci "baja_2" -> sta:pi "baja_3" -> fkg:si smx:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB} } } "]; dsg [label="DSG3|{ { <ovi> 1 V }| { <oso> 1 SUM | <omao> MAX | <tao> 2 ABS } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1} | { <ro> Out 1 | <go> 2 } } } "]; sta [label="Stairs |{ { <ri> R | <pi> Phase }| { <eo> /8 } } } "]; fkg [label="FKG3|{ { <kri> Key R | <ti> Thresh | <si> Soft }| { <ro> R } } } "]; con [label="Contour |{ { <rci> CV 1 | <ri> Filter 1 } | { <go> Out 2 | <bo> 3 | <ro> 1 } } } "]; }}
triple shape DSG
digraph structs {node [shape=record]; { dsg:oso -> sta:ri dsg:omao -> fkg:kri dsg:tao -> fkg2:kri sta:to -> key:bki sta:so -> key:rki key:ro -> con:ri key:bo -> fkg:fgri con:ro -> smx:ari key:go -> smx:bri fkg:ro -> smx:cri smx:rgbo -> fkg2:fgrgbi fkg2:rgbo -> esg:rgbi esg:co -> "main out" esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB} } } "]; dsg [label="DSG3|{ { <oso> 1 SUM | <omao> MAX | <tao> 2 ABS } } } "]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 | <bki> 3} | { <ro> Out 1 | <go> 2 | <bo> 3} } } "]; sta [label="Stairs |{ { <si> Steps | <pi> Phase | <ri> R}| { <so> /16 | <to> /2 } } } "]; fkg [label="FKG3|{ { <fgri> FG R | <kri> Key R | <ti> Thresh | <si> Soft }| { <ro> R } } } "]; fkg2 [label="FKG3|{ { <fgrgbi> FG RGB | <kri> Key R | <ti> Thresh | <si> Soft }| { <rgbo> RGB } } } "]; con [label="Contour |{ { <rci> CV 1 | <ri> Filter 1 } | { <ro> Out 1 } } } "]; }}
stairs + submixer shape get workflow 1
digraph structs {node [shape=record]; { dsg:omao -> fkg:bgri dsg:omio -> sta:ri sta:fo -> con:ri con:ro -> fkg:kri "baja_120" -> sta:si "baja_180" -> sta:pi sta:eo -> sub:tli sta:so -> sub:tri sta:tho -> sub:bli sta:sxo -> sub:bri sub:fo -> fkg:fgri sub:bo -> fkg:fggi sub:po -> fkg:fgbi fkg:ro -> smx:ari fkg:go -> smx:bri fkg:bo -> smx:cri smx:rgbo -> esg:rgbi esg:co -> "main out" con [label="Contour |{ { <ri> Filter 1 } | { <ro> Out 1 } } } "]; dsg [label="DSG3|{ { <omao> MAX | <omio> 1 MIN } } } "]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component } } } "]; fkg [label="FKG3|{ { <bgri> BG R | <fgri> FG R | <fggi> G | <fgbi> B | <kri> Key R }| { <ro> R | <go> G | <bo> B } } } "]; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB } } } "]; sta [label="Stairs |{ { <ri> R | <si> Steps | <pi> Phase }| { <eo> /8 | <so> /16 | <tho> /32 | <sxo> /64 | <fo> /4 } } } "]; sub [label="Submixer |{ { <tli> TL | <tri> TR | <bli> BL | <bri> BR } | { <fo> Fold | <bo> Bottom | <po> + } } "]; }}
Noise
this one is built up to a noise with some density type controls via the DWO and DWO freq CV knob
but there is a very nice colorizer hidden in there too that patch is below
digraph structs {node [shape=record]; { dwo [label="DWO3|{ { <ofi> 1 Freq CV }| { <oso> 1 Sin }}} "]; pro [ label="Proc |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; swa [ label="Swatch |{ { <rgbi> RGB | <ipi> I+ | <qpi> Q+ }| { <crgbo> Clamp RGB }}}"]; sta [ label="Stairs |{ { <rgbi> RGB }| { <eo> /8 | <fo> /4 | <sxo> /64 | <tho> /32 }}}"]; dsg [label="DSG3|{ { <ovi> 1 V | <ohi>1 H }| { <oso> 1 SUM }}} "]; fkg [label="FKG3|{ { <fgrgbi> FG RGB | <kri> Key R | <ti> Thresh }| { < ro> R | <go> G }}}"]; esg [ label="ESG3|{ { <ri> R }| { <co> Component }}}"]; tbc [ label="TBC2 |{ { <brgbo> B RGB | <aro> A R | <ago> G | <abo> B }}}"]; smx [ label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R } | { <rgbo> RGB }}}"]; tbc:aro -> smx:ari tbc:ago -> smx:bri tbc:abo -> smx:cri smx:rgbo -> sta:rgbi sta:tho -> fkg:ti sta:sxo -> fkg:kri sta:eo -> pro:bri sta:fo -> pro:bgi pro:ro -> swa:ipi pro:go -> swa:qpi dwo:oso -> dsg:ohi fkg:ro -> dsg:ovi fkg:go -> dwo:ofi dsg:oso -> esg:ri tbc:brgbo -> swa:rgbi swa:crgbo -> fkg:fgrgbi esg:co -> "main out" }}
colorizer
digraph structs {node [shape=record]; { pro [ label="Proc |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; swa [ label="Swatch |{ { <rgbi> RGB | <ipi> I+ | <qpi> Q+ }| { <crgbo> Clamp RGB }}}"]; sta [ label="Stairs |{ { <rgbi> RGB }| { <eo> /8 | <fo> /4 }}}"]; esg [ label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; tbc [ label="TBC2 |{ { <brgbo> B RGB | <aro> A R | <ago> G | <abo> B }}}"]; smx [ label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R } | { <rgbo> RGB }}}"]; tbc:aro -> smx:ari tbc:ago -> smx:bri tbc:abo -> smx:cri smx:rgbo -> sta:rgbi sta:eo -> pro:bri sta:fo -> pro:bgi pro:ro -> swa:ipi pro:go -> swa:qpi tbc:brgbo -> swa:rgbi swa:crgbo -> esg:rgbi esg:co -> "main out" }}
ect vibes
DWO range 1 knob in position 3 for locked Vertical
DWO range 2 knob in position 1 for locked Horizontal
FREQ knobs set at max on DWO
dial in the associate RST knobs on submixer to get desired effect
playing with threshold and softness on FKG really bring in and out the bars
FKG threshold mode = window
FKG keyer source = Key
FKG keyer mode = Luma
digraph structs {node [shape=record]; { dwo [label="DWO3|{ { <ofci> 1 Freq CV | <tfci> 2 Freq CV | <ori> 1 Rst | <tri> 2 Rst }| { <two> 2 Saw | <owo> 1 Saw }}} "]; esg [ label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; fkg [label= "FKG3|{ { <fgrgbi> FG RGB | <kri> Key R | <kgi> Key G }| { <rgbo> RGB }}}"]; tbc [label="TBC2 |{ { <brgbo> B RGB | <byo> B Y }}}"]; sub [label="Submixer |{ { <tli> TL | <bri> BR } | { <po> + | <mo> - | <bo> Bottom | <lo> Left | <to> Top }}"]; fkg:rgbo -> esg:rgbi tbc:brgbo -> fkg:fgrgbi tbc:byo -> sub:tli sub:to -> "mult out" "mult in" -> sub:bri sub:bo -> dwo:ori sub:lo -> dwo:tri sub:po -> dwo:ofci sub:mo -> dwo:tfci dwo:two -> fkg:kri dwo:owo -> fkg:kgi esg:co -> "main out" }}
Switcher PiPiP cross
digraph structs {node [shape=record]; { swi [label="Switcher|{ { <frgbi> 4 RGB | <orgbi> 1 RGB | <trgbi> 2 RGB | <thri> 3 R | <thgi> G | <thbi> B | <bai> Select B0 | <bbi> Select B1 }| { <brgbo> B RGB | <aro> A R } } } "]; swib [label="Switcher|{ { <aai> Select A0 | <abi> Select A1 | <bdi> B Disable } } } "]; rib [label="Ribbons |{ { <adci> ADC }| { <daco> DAC | <do> D0-2 } } } "]; stk [label="stacker |{ { <hti> H 2 | <vthi> V 3 | <hoi> H 1 | <voi> V 1 } | { <koo> Out 1 | <kto> 2 | <ktho> 3} } } "]; tbc [label="TBC2 |{ { <byo> B Y | <argbo> A RGB | <brgbo> B RGB | <ayo> A Y }}}"]; sta [label="Stairs |{ { <ri> R }| { <to> /2 | <eo> /8 | <so> /16 }}}"]; pro [label="Proc |{ { <bri> B 1 | <bgi> 2} | { <ro> Out 1 | <go > 2 }}"]; dwo [label="DWO3|{ { <oso > 1 Sin | <oto> 1 Tri }}} "]; dsg [label="DSG3| { { <ovi> 1 V }| { <oso> 1 SUM | <omao> MAX }}} "]; key [label="Keychain |{ { <rki> Key 1 | <rci> CV 1 } | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; cro [label="Crossfader |{ { <ci> CV | <argbi> A RGB | <bri> B R | <bgi> B G | <bbi> B B } | { <rgbo> RGB | <lo> Luma }}"]; ang [label="Angles|{ { <co> 45 | <io> 135 | <ao> 15 | <go> 105 } } } "]; sub [label="Submixer |{ { <tli> TL | <tri> TR } | { <fo> Fold }} "]; esg [label="ESG3| { { <rgbi> RGB }| { <co> Component }}}"]; list [label=" { { <r> TBC2 }| { <c> DWO3 }| { <c> Angles }| { <c> Ribbons }| { <c> keychain }| { <c> DSG3 }| { <c> Proc }| { <c> Switcher }| { <c> Stacker }| { <c> Stairs }| { <c> Crossfade }| { <c> ESG3 }| { <c> Submixer } }}}"]; tbc:argbo -> swi:orgbi tbc:brgbo -> swi:trgbi tbc:ayo -> key:rki key:ro -> swi:thri key:go -> swi:thgi key:bo -> swi:thbi tbc:byo -> rib:adci rib:do -> swi:frgbi swi:aro -> sta:ri sta:to -> cro:bri sta:eo -> cro:bgi sta:so -> cro:bbi swi:brgbo -> cro:argbi rib:daco -> cro:ci ang:ao -> stk:hoi ang:go -> stk:voi ang:co -> pro:bri ang:io -> pro:bgi pro:ro -> stk:hti pro:go -> stk:vthi stk:koo -> swib:aai stk:kto -> swib:abi dwo:oso -> key:rci dwo:oto -> dsg:ovi dsg:oso -> swi:bbi dsg:omao -> sub:tri cro:lo -> sub:tli sub:fo -> fold_out Fold_in -> swi:bai cro:rgbo -> esg:rgbi stk:ktho -> swib:bdi esg:co -> "main out" }}
Switcher PiPiP cross 2 main
digraph structs {node [shape=record]; { ang [ label="Angles|{ { <ai> A | <bi> B }| { <hro> H | <vro> V | <hrio> Inverted H | <vrio> inverted V | <ao> 0 | <go> 90 } } } "]; pro [label="Proc |{ { <abi> A 3 | <bbi> B 3 | <ari > A 1 | <agi> A 2 | < bri> B 1 | <bgi> B 2 } | { <bo> 3 | <ro> Out 1 | <go> 2 }}}" ] ; prob [label="Proc 2 |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | < go> 2 }}}"]; dwo [label="DWO3|{ { <oso> 1 Sin | <tso> 2 Sin }}} "]; dsg [label="DSG3|{ { <ohi>1 H | <ovi> 1 V }| { <oso> 1 SUM }}} "]; key [label="Keychain | { { <rki> Key 1 | <gci> CV 2 | <bki> CV 3} | { <ro> Out 1 | <go> 2 | <bo> 3}}}"]; rib [label="Ribbons |{ { <adci> ADC }| { <daco> DAC | <do> D0-2} } } "]; con [label="Contour |{ { <ri> Filter 1 | <rci> CV 1 } | { <rgbo> RGB }}}"]; dis [label="Dist|{ { <rgbi> RGB}| { <orgbo> 1 RGB | <trgbo> 2 RGB }}}"]; stk [label="stacker |{ { <rhi> H 1 | <rvi> V 1 } | { <bko> 3 } } } "]; sta [label="Stairs |{ { <rgbi> RGB | <si> Steps }| { <to> /2 | <eo> /8 | <so> /16 }}"]; swi [label="Switcher|{ { <bai> Select B0 | <bbi> Select B1 | <frgbi> 4 RGB | <trgbi> 2 RGB | <orgbi> 1 RGB | <thrgbi> 3 RGB | <bdi> B Disable }| { <brgbo> B RGB } } } "]; cro [label="Crossfader |{ { <ci> CV | <argbi> A RGB | <bri> B R | <bgi> B G | <bbi> B B } | { <rgbo> RGB | <lo> Luma }}"]; tbc [label="TBC2 |{ { <ayo> A Y | <byo> B Y | <argbo> A RGB | <brgbo> B RGB}}}"]; esg [label="ESG3| { { <rgbi> RGB }| { <co> Component }}}"]; ang:hro -> pro:bri ang:vro -> pro:bgi pro:ro -> H_Ramp_out pro:go -> V_Ramp_out H_Ramp_in -> ang:ai V_Ramp_in -> ang:bi ang:ao -> PiP_H_out PiPP_H_in -> swi:bai ang:go -> PiP_V_out PiP_V_in -> swi:bbi ang:hrio -> prob:bri ang:vrio -> prob:bgi mult_H1_in -> stk:rhi mult_V1_in -> stk:rvi stk:bko -> swi:bdi prob:ro -> mult_H_out prob:go -> mult_V_out mult_H2_in -> dsg:ohi mult_V2_in -> dsg:ovi dsg:oso -> key:rki key:ro -> dsg_key_out dsg_key_in -> pro:abi DUMMY -> pro:bbi pro:bo -> window_key_out window_key_in -> key:gci key:go -> dsg_window_key_out dsg_window_key_in -> cro:ci tbc:ayo -> key:bki key:bo -> con:ri rib:daco -> con:rci con:rgbo -> swi:frgbi tbc:byo -> rib:adci rib:do -> swi:trgbi dwo:oso -> pro:ari dwo:tso -> pro:agi tbc:argbo -> swi:orgbi tbc:brgbo -> swi:thrgbi swi:brgb -> dis:rgbi dis:orgbo -> cro:argbi dis:trgbo -> sta:rgbi sta:to -> cro:bri sta:eo -> cro:bgi sta:so -> cro:bbi cro:lo -> sta:si cro:rgbo -> esg:rgbi esg:co -> "main out" }}
Switcher PiPiP cross 2 variation
digraph structs {node [shape=record]; { ang [ label="Angles|{ { <ai> A | <bi> B }| { <hro> H | <vro> V | <hrio> Inverted H | <vrio> inverted V | <ao> 0 | <go> 90 } } } "]; pro [label="Proc |{ { <abi> A 3 | <bbi> B 3 | <ari > A 1 | <agi> A 2 | < bri> B 1 | <bgi> B 2 } | { <bo> 3 | <ro> Out 1 | <go> 2 }}}" ] ; prob [label="Proc 2 |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | < go> 2 }}}"]; dwo [label="DWO3|{ { <oso> 1 Sin | <tso> 2 Sin }}} "]; dsg [label="DSG3|{ { <ohi>1 H | <ovi> 1 V }| { <oso> 1 SUM }}} "]; key [label="Keychain | { { <rki> Key 1 | <gci> CV 2 | <bki> CV 3} | { <ro> Out 1 | <bo> 3 | <go> 2 }}}"]; rib [label="Ribbons |{ { <di> Disable | <adci> ADC }| { <daco> DAC | <do> D0-2} } } "]; con [label="Contour |{ { <ri> Filter 1 | <rci> CV 1 } | { <rgbo> RGB }}}"]; dis [label="Dist|{ { <rgbi> RGB}| { <trgbo> 2 RGB | <orgbo> 1 RGB }}}"]; stk [label="stacker |{ { <rhi> H 1 | <rvi> V 1 } | { <gko> 2 | <bko> 3 } } } "]; sta [label="Stairs |{ { <si> Steps | <rgbi> RGB }| { <to> /2 | <eo> /8 | <so> /16 }}"]; swi [label="Switcher|{ { <bai> Select B0 | <bbi> Select B1 | <frgbi> 4 RGB | <trgbi> 2 RGB | <orgbi> 1 RGB | <thrgbi> 3 RGB | <bdi> B Disable }| { <brgbo> B RGB } } } "]; cro [label="Crossfader |{ { <bri> B R | <bgi> B G | <bbi> B B | <argbi> A RGB | <ci> CV } | { <lo> Luma | <rgbo> RGB }}"]; tbc [label="TBC2 |{ { <ayo> A Y | <byo> B Y | <argbo> A RGB | <brgbo> B RGB}}}"]; esg [label="ESG3| { { <rgbi> RGB }| { <co> Component }}}"]; ang:hro -> pro:bri ang:vro -> pro:bgi pro:ro -> H_Ramp_out pro:go -> V_Ramp_out H_Ramp_in -> ang:ai V_Ramp_in -> ang:bi ang:ao -> swi:bai ang:go -> swi:bbi ang:hrio -> prob:bri ang:vrio -> prob:bgi mult_H1_in -> stk:rhi mult_V1_in -> stk:rvi stk:bko -> cro:ci stk:gko -> swi:bdi stk:gko -> swi:bdi prob:ro -> mult_H_out prob:go -> mult_V_out mult_H2_in -> dsg:ohi mult_V2_in -> dsg:ovi dsg:oso -> key:rki key:ro -> pro:abi DUMMY -> pro:bbi pro:bo -> window_key_out window_key_in -> key:gci key:go -> rib:di tbc:ayo -> key:bki key:bo -> con:ri rib:daco -> con:rci con:rgbo -> swi:frgbi tbc:byo -> rib:adci rib:do -> swi:trgbi dwo:oso -> pro:ari dwo:tso -> pro:agi tbc:argbo -> swi:orgbi tbc:brgbo -> swi:thrgbi swi:brgb -> dis:rgbi dis:orgbo -> cro:argbi dis:trgbo -> sta:rgbi sta:to -> cro:bri sta:eo -> cro:bgi sta:so -> cro:bbi cro:lo -> Luma_fdbk_out Luma_fdbk_in -> sta:si cro:rgbo -> esg:rgbi esg:co -> "main out" }}
reinterpret
digraph structs {node [shape=record]; { tbc [label="TBC2 |{ { <argbo> A RGB }}}"]; sta [label="Stairs |{ { <ri> R }| { <fo> /4 }}}"]; rib [label="Ribbons |{ { <adci> ADC }| { <idaco> Inverted DAC } } } "]; swa [label="Swatch |{ { <rgbi > RGB | <yi> Y }| { <crgbo>Clamp RGB | <yo> Y }}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; tbc:argbo -> swa:rgbi swa:yo -> sta:ri sta:fo -> rib:adci rib:idaco -> processed_luma_out processed_luma_in -> swa:yi swa:crgbo -> esg:rgbi esg:co -> "main out" }}
new 23 colorizer
digraph structs {node [shape=record]; { tbc [label=" TBC2 |{ { <ayrgbo> A YRGB }}}"]; dist [label="Dist|{ { <yrgbi> YRGB }| { <oyo> Y | <orgbo> 1 RGB | <twrgbo> 2 RGB | <twyo> Y | <thyo> Y }}}"]; rib [label=" Ribbons |{ { <adci> ADC }| { <daco> DAC } } } " ]; fac [label="Factors |{ { <rgbi> RGB | <cvrgbi> CV RGB } | { <rgbo> RGB}}}"]; pro [label= "Proc |{ { <bri> B 1 | <ari> A 1 } | { <ro> Out 1 }}}"]; key [label="Keychain |{ { <rgbi> RGB | <rci> CV 1 } | { <rgbo> RGB}}}"]; cro [label="Crossfader |{ { <bri> B R | <argbi> A RGB } | { <rgbo> RGB }}"]; esg [label="ESG3|{ { <rgbi> RGB }| { <co> Component }}}"]; tbc:ayrgbo -> dist:yrgbi dist:orgbo -> fac:rgbi dist:twrgbo -> key:rgbi key:rgbo -> fac:cvrgbi dist:thyo -> rib:adci dist:twyo -> pro:bri rib:daco -> pro:ari pro:ro -> key:rci fac:rgbo -> cro:argbi dist:oyo -> cro:bri cro:rgbo -> esg:rgbi esg:co -> "main out" }}
scrolls gen3 shape position and scale
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <ofci> Freq CV | <tfci> 2 Freq CV }| { <tbmo> 2 B mod | <oamo> 1 A mod | <obmo> 1 B mod | <tamo> 2 A mod | <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 | <cvri> CV 1 | <cvgi > 2 } | { <ro > Out 1 | <go > 2 }}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 | <bri > B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 }}}" ]; ang [label="Angles|{ { <ai> A | < bi> B }| { <mo> 180 | <no> 195 | <oo> 210 | <so> 270 | <to> 285 | <uo> 300 | <po> 225 | <vo> 315 } } } "]; stk [label="stacker |{ { <hoi> H 1 | < hti> H 2 | <hthi> H 3 | <voi> V 1 | <vti> V 2 | <vthi> V 3} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; swi [label="Switcher|{ { <argbi > 1 RGB | <bri> 2 R | <aai> Select A0 }| { <argbo> A RGB } } } "]; cro [label="Crossfader |{ { <argbi> A RGB } | { <rgbo> RGB | <lo> Luma }}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; key [label="Keychain |{ { <rci> CV 1 | <rki> Key 1 } | { <ro> Out 1 }}}"]; con [label="Contour |{ { <rci > CV 1 | <gci> 2 | <bci> 3 | <ri> Filter 1 | <gi> 2 | <bi> 3} | { <ro> Out 1 | <go> 2 | <bo> 3 }}}"]; rib [label="Ribbons |{ { <adci> ADC }| { <daco> DAC } } } "]; dsg [label="DSG3|{ { <ohi> 1 H | <ovi> 1 V }| { <oso> 1 SUM }}} "]; sta [label="Stairs |{ { <ri> R }| { <fo> /4 }}}"]; dwo [label="DWO3|{ { <oto> 1 Tri | <tto> 2 Tri }}} "]; dwob [label="DWO3 B|{ { <oto> 1 Tri | <tto> 2 Tri }}} "]; scr:oamo -> con:rci scr:tamo -> con:bci scr:obmo -> con:gci scr:tbmo -> "scrolls mod out" "scrolls mod in" -> key:rci scr:oto -> fac:ri scr:tto -> fac:gi fac:ro -> pro:ari fac:go -> pro:agi pro:ro -> ang:ai pro:go -> ang:bi ang:mo -> stk:hoi ang:so -> stk:voi ang:no -> stk:hti ang:to -> stk:vti ang:oo -> stk:hthi ang:uo -> stk:vthi ang:po -> dsg:ohi ang:vo -> dsg:ovi dsg:oso -> sta:ri sta:fo -> rib:adci rib:daco -> key:rki key:ro -> swi:aai dwo:oto -> pro:bri dwo:tto -> pro:bgi dwob:oto -> fac:cvri dwob:tto -> fac:cvgi stk:koo -> con:ri stk:kto -> con:gi stk:ktho -> con:bi con:ro -> smx:ari con:go -> smx:bri con:bo -> smx:cri smx:rgbo -> swi:argbi swi:argbo -> cro:argbi cro:rgbo -> esg:rgbi cro:lo -> "luma_feedback_out" "luma_feedback_in" -> swi:bri esg:co -> "main out" }}
current working patching
thanks very much for these, I will try them soon!
I’m making some basic templates that I can use to speed up some workflows I find myself coming back to depending on what the desired result is.
I have these built as multi actions on the Elgato stream deck so that I can just press a button and the full patch gets built then I can patch from there.
gen3 basic positionable shape gen
digraph structs {node [shape=record]; { ang:ho -> pro:bri ang:vo -> pro:bgi pro:ro -> dsg:ohi pro:go -> dsg:ovi dsg:oso -> key:rki key:ro -> esg:ri esg:co -> "main out" ang [label="Angles|{ { <ho> H | <vo> V} } } "] ; dsg [label="DSG3 |{ { <ohi>1 H | <ovi> 1 V }| { <oso> 1 SUM }}} "]; esg [label="ESG3|{ { <ri> R }| { <co> Component }}}"]; key [label="Keychain |{ { <rki> Key 1} | { <ro> Out 1 }}}"]; pro [label="Proc |{ { <bri> B 1 | <bgi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; }}
Scrolls gen3 basic base
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 } | { <ro > Out 1 | <go > 2 }}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; stk [label="stacker |{ { <hoi> H 1 | <voi> V 1} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; scr:oto -> fac:ri scr:tto -> fac:gi fac:ro -> pro:ari fac:go -> pro:agi pro:ro -> stk:hoi pro:go -> stk:voi stk:koo -> smx:ari stk:kto -> smx:bri stk:ktho -> smx:cri smx:rgbo -> esg:rgbi esg:co -> "main out" }}
Scrolls gen3 expanded base
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; ang [label="Angles|{ { <ai> A | <bi> B }| { <mo> 180 | <no> 195 | <oo> 210 | <so> 270 | <to> 285 | <uo> 300 } } } "]; stk [label="stacker |{ { <hoi> H 1 | <hti> H 2 | <hthi> H 3 | <voi> V 1 | <vti> V 2 | <vthi> V 3} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; swi [label="Switcher|{ { <argbi> 1 RGB }| { <argbo> A RGB } } } "]; cro [label="Crossfader |{ { <argbi> A RGB } | { <rgbo> RGB }}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; scr:oto -> fac:ri scr:tto -> fac:gi fac:ro -> pro:ari fac:go -> pro:agi pro:ro -> ang:ai pro:go -> ang:bi ang:mo -> stk:hoi ang:so -> stk:voi ang:no -> stk:hti ang:to -> stk:vti ang:oo -> stk:hthi ang:uo -> stk:vthi stk:koo -> smx:ari stk:kto -> smx:bri stk:ktho -> smx:cri smx:rgbo -> swi:argbi swi:argbo -> cro:argbi cro:rgbo -> esg:rgbi esg:co -> "main out" }}
Scrolls gen3 basic base dual ribbons
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; ang [label="Angles|{ { <ai> A | <bi> B }| { <mo> 180 | <no> 195 | <oo> 210 | <so> 270 | <to> 285 | <uo> 300 } } } "]; rib [label="Ribbons |{ { <adci> ADC }| { <daco> DAC } } } "]; ribb [label="Ribbons 2 |{ { <adci> ADC }| { <daco> DAC } } } "]; stk [label="stacker |{ { <hoi> H 1 | <hti> H 2 | <hthi> H 3 | <voi> V 1 | <vti> V 2 | <vthi> V 3} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; scr:oto -> fac:ri scr:tto -> fac:gi fac:ro -> pro:ari fac:go -> pro:agi pro:ro -> rib:adci pro:go -> ribb:adci rib:daco -> ang:ai ribb:daco -> ang:bi ang:mo -> stk:hoi ang:so -> stk:voi ang:no -> stk:hti ang:to -> stk:vti ang:oo -> stk:hthi ang:uo -> stk:vthi stk:koo -> smx:ari stk:kto -> smx:bri stk:ktho -> smx:cri smx:rgbo -> esg:rgbi esg:co -> "main out" }}
Scrolls gen3 expanded base dual ribbons
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; ang [label="Angles|{ { <ai> A | <bi> B }| { <mo> 180 | <no> 195 | <oo> 210 | <so> 270 | <to> 285 | <uo> 300 } } } "]; rib [label="Ribbons |{ { <adci> ADC }| { <daco> DAC } } } "]; ribb [label="Ribbons 2 |{ { <adci> ADC }| { <daco> DAC } } } "]; stk [label="stacker |{ { <hoi> H 1 | <hti> H 2 | <hthi> H 3 | <voi> V 1 | <vti> V 2 | <vthi> V 3} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; swi [label="Switcher|{ { <argbi> 1 RGB }| { <argbo> A RGB } } } "]; cro [label="Crossfader |{ { <argbi> A RGB } | { <rgbo> RGB }}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; scr:oto -> fac:ri scr:tto -> fac:gi fac:ro -> pro:ari fac:go -> pro:agi pro:ro -> rib:adci pro:go -> ribb:adci rib:daco -> ang:ai ribb:daco -> ang:bi ang:mo -> stk:hoi ang:so -> stk:voi ang:no -> stk:hti ang:to -> stk:vti ang:oo -> stk:hthi ang:uo -> stk:vthi stk:koo -> smx:ari stk:kto -> smx:bri stk:ktho -> smx:cri smx:rgbo -> swi:argbi swi:argbo -> cro:argbi cro:rgbo -> esg:rgbi esg:co -> "main out" }}
Triple Scrolls gen3 base
digraph structs {node [shape=record]; { scr [label="Scrolls|{ { <oto> 1 tri | <tto> 2 tri }}} "]; scrb [label="Scrolls 2|{ { <oto> 1 tri | <tto> 2 tri }}} "]; scrc [label="Scrolls 3|{ { <oto> 1 tri | <tto> 2 tri }}} "]; fac [label="Factors |{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; facb [label="Factors 2|{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; facc [label="Factors 3|{ { <ri> In 1 | <gi> 2 } | { <ro> Out 1 | <go> 2}}}"]; pro [label="Proc |{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; prob [label="Proc 2|{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; proc [label="Proc 3|{ { <ari> A 1 | <agi> 2 } | { <ro> Out 1 | <go> 2 }}}"]; stk [label="Stacker |{ { <hoi> H 1 | <voi> V 1 | <hti> H 2 | <vti> V 2 | <hthi> H 3 | <vthi> V 3} | { <koo> Key 1 | <kto> 2 | <ktho> 3} } } "] ; smx [label="SMX3|{ { <ari> A R | <bri> B R | <cri> C R }| { <rgbo> RGB}}}"]; swi [label="Switcher|{ { <argbi> 1 RGB }| { <argbo> A RGB } } } "]; cro [label="Crossfader |{ { <argbi> A RGB } | { <rgbo> RGB }}"]; esg [label="ESG3|{ { <rgbi> RGB }| { < co> Component }}}"]; scr:oto -> fac:ri scr:tto -> fac:gi scrb:oto -> facb:ri scrb:tto -> facb:gi scrc:oto -> facc:ri scrc:tto -> facc:gi fac:ro -> pro:ari fac:go -> pro:agi facb:ro -> prob:ari facb:go -> prob:agi facc:ro -> proc:ari facc:go -> proc:agi pro:ro -> stk:hoi pro:go -> stk:voi prob:ro -> stk:hti prob:go -> stk:vti proc:ro -> stk:hthi proc:go -> stk:vthi stk:koo -> smx:ari stk:kto -> smx:bri stk:ktho -> smx:cri smx:rgbo -> swi:argbi swi:argbo -> cro:argbi cro:rgbo -> esg:rgbi esg:co -> "main out" }}
TBC2 base full
digraph structs {node [shape=record]; { tbc [label="TBC2 |{ { <ayrgbo> A YRGB }}}"]; dist [label="Dist|{ { <yrgbi> YRGB}| { <orgbo> 1 RGB }}}"]; swi [label="Switcher|{ { <argbi> 1 RGB }| { <argbo> A RGB } } } "]; cro [label="Crossfader |{ { <argbi> A RGB } | { <rgbo> RGB }}"]; esg [label="ESG3 |{ { <rgbi> RGB }| { <co> Component }}}"]; tbc:ayrgbo -> dist:yrgbi dist:orgbo -> swi:argbi swi:argbo -> cro:argbi cro:rgbo -> esg:rgbi esg:co -> "main out" }}
