As beta testing of the OSX WP DSK build has started, I was wondering what folks have been doing (or are planning on doing) to enable payback of video files thru the DSK SW? I figure using OBS Virtual Cam will be the default solution (which also enables Syphon interfacing), but are there any other solutions out there?
I’m still struggling to get video input. But will certainly be using OBS.
https://alternativeto.net/feature/virtual-camera-output/
https://www.softwaretestinghelp.com/top-webcam-software/
actually tbh obs virtual cam is probably not the best over all if all you want to do is just grab video from the desktop or a window. theres currently an absolute ton options for light weight and simple virtual cam programs
Andrei - that’s what I thought would be the case, too. (Thanks for the links to the lists…)… Unfortunately most all of the existing apps won’t run under the new virtual camera model and enhanced security of MacOS 14.x Sonoma. Of the ones that do, almost everyone of them (except OBS) have heavy monthly or annual subscription fees - including Manycam, Ecamm Live, mimoLive6… There are a few (such as the new Camera Graph - relatively low cost sub.) that allow for a shared (&cropped) window grab for injection into cam output, so you could capture another program’s video output window for output. But that is getting Rube Goldberg-esque compared to just defaulting to the OBS swiss army knife.
There are also potential Syphon-based solutions - such as playing video files thru Signal Culture’s Input Amp app and catching the Syphon stream via iGlasses virtual camera app for output.
Does anyone out there know of any other window-grabbing Virtual Camera apps compatible with the new Apple MacOS 14 security regimes?
…the in-system Quicktime-Screen-Recorder?…
No, unfortunately: the QT screen recorder is a record to disk function, not something that feeds live into (or as) a Virtual Camera.
By the way, Camera Graph works fine in this mode (video window grab to virtual camera output) and its lifetime license is not too expense → $49. Cheaper than most other options…
From the WP DSK ReadMe_WPDSK_OSX.txt.
dont bother with obs virtual camera (and don’t bother filing a support form about it either). it won’t work and i’m also uninterested in reading about it anymore.
Pretty disappointed in this, and if this is going to set the tone for software support going forward.
Turns out that OBS Virtual Camera does work: latest Mac OS version and latest release version of OBS loaded, and computer restarted. OK. Works fine. Using it with the Waaavepool DSK release. I’m not sure what the issue is (is it a Windows VC problem?), but I’m sure that Andre isn’t interested in providing customer support for OBS or other 3rd party headaches. It’s up to us users to get creative here and search for appropriate solutions…
Neither the author of the software or myself have gotten it to work, so please share everything about your setup so we can troubleshoot.
I think its pretty clear in my previous post the I am using the latest MacOS version (not a PC), so here are the specific details: Sequoia 15.6.1 (pretty close to latest unless there’s been a security patch I missed…), and what was the latest a few weeks ago (and may still be) ARM version of OBS for MAC - version 31.1.0 … running on a 32GB M1 Studio Mac.
I’m on M1 Sequoia 15.4.1, OBS 31.1.1. I will try updating the OS.
Can you share the information about your OBS output settings for the Virtual Camera ? I think there is a resolution, Color Space, or video format mismatch that is causing the issue.
if an issue is very well known to the developer and clearly isn’t immediately and easily fixable, getting spammed with support requests on this issue don’t actually help and instead hinder actual development.
OK so the details here are interesting. I am using OBS 30.1.0 still. And I flipped out a bit when I loaded WaaavePool 1.01 with OBS virtual camera running - andI could select it but nothing was showing up in the video output window. Then I realized that most of the time I am also running with a program called CAMO which manages virtual camera - I use if to interface to one of several video digitizers (SD or HD) so I can make REZ adjustments, proc amp adjustments, and zoom/move around the video (if need be)… Well, of course this turns out to be the missing link that enables OBS virtual camera to run properly in WP. [Camo Studio Pro] is what to search for… They’ve recently updated the interface to make it less video artist friendly and more geared towards video meetings, but it doesn’t take much to get it configured.
Looks like it’s Camo Studio for Mac/PC, and Camo Camera for IOS.
Your mileage may vary but I disliked the update so much that I rolled back to the Camo version I had been using (2.1.8) which was released to fix any lingering MacOS 15 camera issues that some people had reported. (The current version 2.3.2 works fine, I just dislike the UI changes which annoy me compared to what I am used to using with the previous version.)
I can’t find old versions online anywhere. They just offer a generic Camo_installer.zip; with whatever current version. I didn’t even see old versions on Archive.org. ![]()
Well, the current version does work. But not a nice UI and perhaps harder for me to unlearn than someone starting fresh. (I reloaded from my Time Machine Backup). That said, I have a support request in to their support folks and I’ll see what can be done about having access to the earlier revision (previous rev). I imagine if you are a paying customer for the PRO version, they would be able to supply a back link to the previous release. We’ll see what they say.
