Whats everyone working on these days?
I am a beginner, right now I am saving up to build a two lofi-future VGA Feedback generators, and a dirty mixer to put between them. I am really excited to explore this new hobby :smiley:
That’s awesome! Anything with an RCA out would be great. one of those VGA feedback things and a car camera into a dirty video mixer gives you a ton to start with on an aliexpress budget. Just be ready for some dropouts sending it to digital inputs. :upside_down_face:
I was working on some reverse engineering and repair a while back. I wrote up my findings here - Roland DIF-AT - RECESSIM
Recessim has a great yt channel also, with lots of RE related content.
I made this from recycled components - everything taken from discarded electronic devices - After finding the MCU I decided to try and make a fully recovered board. I ported this PCB design to kicad from Eagle. It will fit most of the STM32Fxx MCU, in 64pin package.
I’m only missing the TVS diode package; it’s a rare one to find outside of portable USB electronics.
Been having fun with various clips from home made video synthesizer and adding some EFXs in DaVinci Resolve. Music by the legendary Kim Cascone:
i organized a “week of patching” on the fediverse and i made a bunch of stuff in touch designer, including some virtual scan processing/wobbulation. i kept a log of my processes here:
…over last weekend: Electronic Attack Party near Hannover - Germany - visuals by Florian Anwander (who also leads our Munich-based ambioSonics-group with monthly gigs in a venue in Munich downtown) and starting off with an improvised modular liveset by me:
…i had wanted to record the visuals also, but as the artist preferred to have them just sent to the beamer the visuals are recorded and visible just in the background from the screen; equipment used were a couple of Roland P-10 and Korg Kaoss-Pad Entrancers combined with live-input from several separate low-res cameras
Begrudgingly exposing NZSIS
Just created this music video for the 30th anniversary of Navigator by Forma Tadre
I’m currently developing a differential transmit / receive system that uses XLR cabling for composite video transmission. The idea came last year while planning for a local festival. The main benefit was running the video from FOH to the stage through the 15 meter XLR multicore, along the audio signals. This spared the whole effort of running a BNC cable all the way. It works surprisingly well! The system ran 3 days outdoor without a problem or any interference.
The two white boxes in all the chaos is the transmission system. It’s still work in progress but will be tested again next weekend.
If someones interested here is the git repo: eigene_sachen / Composite XLR Transceiver · GitLab
However there is not much besides the KiCad project right now.
i started a new thing called “Paloma Kop’s AV Club”, where i’ve been posting monthly snippets (two so far):
recently, as part of one of the posts, i shared a TouchDesigner component i made that emulates an aspect of analog video synthesis. i also made a demo video showing how it works:
i also made a web demo so people who don’t use TD can try it out also. per a request from @Kandid, i also plan to add the ability to switch cameras soon. lab.palomakop.tv/freqphasemod
freqPhaseMod_web_demo
analog chaos at home as usual
Over the past few weeks, I’ve been programming modifications for the CYPHER module. This CYPHER module can generate short blanking intervals within the lines of the composite video signal. It is actually designed for text overlays. The input video signal remains intact for areas not blanked, except for some artifacts, because the CYPHER provides an monochromatic signal on top of the original video signal.
My graphical modifications allow simple black or white patterns to be animated: a cellular automaton, colliding rings, and a “function plotter”. It’s all pretty retro. These modifications are best used together with an nanoKONTROL2.
Background:
The module contains an RP2040 microcontroller. When writing modifications just keep in mind that this microcontroller has limited RAM. Its processing power is also only a fraction of that of a desktop CPU.
One thing was that i tried was to port a Fortran IV program from the 1980s to CYPHER in order to display a “function plotter” on the screen. That was surprisingly complicated and only worked partially. If i recall correctly, the mainframe had 64 kilobytes of RAM. The Issue was not the amount RAM it’s more the syntax of Fortran IV and it’s power to express numerical operations.
Yes, i could port even more of that ’70s aesthetic to the CYPHER module.
And together with “analog Not analog” i use it in video feedback loops too.
…wow! - that is really great stuff you’re doing with the TELEVØYANCE modules there!!..
…i just managed to get some text to show up - and i also managed to connect a device called ‘InputStick’, which can be connect to the CYPHERs USB-port and then the companion app on iOS or Android is able to send text and commands via Bluetooth to the stick which passes this on to the module via USB…
…also in the works is an Adafruit MacroPad, which i am ‘programming’ to send pre-configured text to the CYPHER-module on button-press…
…fun stuff all this!..
These input devices are an interesting tip for me. I’m still looking for a way to continuously send parameters to the CYPHER module. Then I could use low-frequency oscillators in SuperCollider or or nessages send from „analog Not analog“. Maybe i can use a Pico W to receive the parameters via Wi-Fi and relay them as MIDI to CYPHER. I still have a Pico W lying around in a drawer. It looks like it can be done with Circuit Python. Will take me a while to get this up and running.
I repurposed a discarded router to be a midi looper - definitely some avenues to explore here, re: networking some devices, a small IoM : ) the looper can be used headless with midi transport /cc commands, and of course network midi available. I compiled other software so it has Orca-C on there too. Some small sticking points, dropped/sticking notes sometimes, I have some things to try and resolve. Its a fairly limited router, 128mb RAM and Flash, but this seems fine for midi only no audio.
…uhm? not doing too much - not more than putting a few screws through some Eurorack-Panels and then plugging in some cables:
…the next TELEVØYANCE-delivery has happened today!..
