Some days ago I uploaded a video named “monitor-camera-feedback-loop-1608578433” to videos.scanlines.xyz
But when I try to watch it in Firefox, Opera or Chromium this video did not play. “The media could not be loaded, either because the server or network failed or because the format is not supported.” I am working on Debian 10.
What can i do avoid this?
How should i prepare the my videos with ffmpeg before uploading?
Hi Kandid and welcome to Scanlines! I get the same error when trying to play your video.
First, let’s first check the file you uploaded. What codecs is it using?
You can figure this out by playing the file with VLC and then pressing CTRL + J, or via menu Tools > Codec Information.
Here’s a VLC screenshot relative to a video I’ve succesfully uploaded to video.scanlines.xyz. As you see, the codec h264 is being used. It’s not necessarily the best option but it’s a widely used one (and the default one when recording with OBS as I do).
I am using this bash script to compress a image sequence:
#!/bin/bash
timestamp=$(date +%s)
ffmpeg -framerate 25 -pattern_type glob -i ‘ana_*.png’ -vcodec libx265 video-$timestamp.mp4
Tryed to upload a H264 video today. But run problems with login:
The H.264 compressed video can be played. In my workflow, I first create hundreds of lossless compressed PNGs. Then I use ffmpeg to convert those series of images into a video format. Possibly several times because of pixel details or size …
But that can’t be avoided. If I record with a screen recorder directly while the animation is running, the details are lost.
Live streaming of glitch effects is not possible for me because i live in the hinterland. Using a very slow connection.
